Question about Whirlpool GS6NBEXRS Side by Side Refrigerator
Controls for the fridge on the side by side fridge freezer
Cleaned the fridge and freezer, now the fridge will not come on. There are no figures on the side of the control panel. Does anyone know which buttons to press? no instruction manual.
    Problem Solver:
  • 10 Answers
If you have digital controls and if it works like a Kitchenaid you push and hold the increase temperature button.
Posted on Feb 16, 2009
Frigidaire frs26lh5dso freezer works great, fridge side is warm.
make sure door to refrigerator is all the way up, so when it is closed it turns the cooling part on. I have to check mine all the time and screw it up if it's down, which is quite often. Mine is a side by side and I just make sure it's even with the top of refrigerator and even with the freezer door.
Jul 16, 2012 | Frigidaire Refrigerators
My regrigerator (GE Profile) is not cold on the fridge side, but ok on the freezer side. I found ice buildup in the freezer so I defrosted and dryed it completely, cleaned it- including coils...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 16, 2010 | GE Refrigerators
Freezer is frozen fridge is warm
Your model is most likely the Profile Artica style. Most times the defrost heater is burned out behind the rear of the freezer wall. Manually defrost and look at the defrost heater to see if burned out. That model possibly has the glass covered defrost heater and will be easy to spot if burned out because the element is inside a glass tube, If you replace the defrost heater also replace the defrost thermostat, Please send me your model number located near floor of the fresh food compartment door seal and kick plate, Thanks Sea Breeze
Oct 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Freezer cold but other is not
In my somewhat limited experience there is usually a fan that blows cold air from the freezer side to the fridge side. I've had that fan go out before and cause this problem. I want to say that it was only like $20 to buy a new fan and put it in.
But yeah, if I'm not mistaken there isn't actually any cooling done on the fridge part of the refrigerator. It's all done on the freezer part. And then there is some sort of thermostat that controls how much cold air is blown from the freezer to the fridge.
Aug 20, 2009 | Maytag Refrigerators
Freezer works refrigerator does not
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Feb 15, 2009 | Kenmore 50522 / 50524 Side by Side...
Kenmore Side by side Model #53271... not cold
you have a defrost problem in the freezer,it is one or more of 4 things,freezer fan,defrost timer,defrost bimetal switch or defrost heater,check all until you find your bad part-mike
Jan 07, 2009 | Kenmore 53262 / 53264 / 53269 Side by Side...
Freezer Working, but Fridge side is not cold.
ou most likely have a defrost problem is there a large build up of frost in the back wall; of the freezer??
Jan 26, 2008 | Frigidaire FRS26KF5C Side by Side...
Indesit Fridge Freezer
Check freezer... for Frost build up and if Fan is blowing, Check condenser... To make sure clean, and the fan is blowing (by compressor), Check recirclating Vents in refrigerator... to make sure theres no blockage, CONTROLS ...should be in the middle setting, YOU CAN TRY turning FREEZER CONTROL To A WARMER FREEZER SETTING Allowing.. MORE AIR.. to refrigertor side
Sep 08, 2007 | Engel Freezer 22 Qt. Fridge/Freezer
Freezer not cold enough
check freezer for frost build up on back wall and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, controls should be in the middle setting,
Sep 03, 2007 | Danby (DAR604BLS) Refrigerator
Whirlpool GS6NBEXRS Side by Side Refrigerator Logo
263 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
