Question about D-Link 802.11g Wireless Router WBR-1310 (WBR1310)
Low id with dlink wbr 1310 usuing emule
Wondering how to get ports open on router or if there is something else hindering my download speed on Emule.
  • 40 Answers
Short answer? hmmmm
To successfully use port forwarding you must know the IP address of the computer on the INSIDE of your network BUT
your router is most likely using DHCP. This means your internal IP address isn't necessarily static. The "D" in DHCP is for dynamic.
First you need to ensure the the inside IP address of your machine isn't going to change. This can be accomplished 2 ways. 1) assign a static IP to your machine 2) Force specific DHCP IP address assignments by MAC (Hardware) address of your network port - this is the easiest way. Your router does NOT support this option (according to the manual) :-(
So #1 it is...
1) Your router defaults to allocate ALL inside address to DHCP - This will have to change. Alot of routers only use a subset of your internal range (eg: - Yours will too!
Determine how many addresses you wish to reserve for DHCP (for a house 50 should be more than enough). Figure out the range (say -
Also find out the DNS (Domain Name Servers) of your ISP, as you'll be needing them later.
Log into your router and go to Network settings / setup (pages 26 & 27 in the manual) make the changes and restart your router (and computer) you will now be using a DHCP address in the range you just specified! :-)
Now you will need to go to your network settings on your computer and change you r network setting from DHCP to manual. Enter a IP address such as, and your gateway (eg: and your DNS server information that you got earlier.
Now restart your computer to make the changes take effect. We could do something from the command line but I'm trying to keep this short ;-)
If everything is working and you can use the web, check email etc. and your network settings show you are using the manual address you assigned. If you don't have internet review your earlier work (especially the DNS servers) you can always change your computer to use DHCP until your get it resolved.
Congrats most of the tough work is done!
Now you will be using the port forwarding option (Page 28 in your manual) to assign which incoming ports to map to your IP address
Rather than regurgitate other peoples work... see:
I hope this was helpful!
Posted on Mar 03, 2009
How to forward port to get high ID in emule
Here is how to set up port forwarding for emule: If you use emule Plus see here:
Jun 07, 2009 | Linksys WRT160N Wireless Router
Dlink wbr-1310 quick installation guide,437
download it
Apr 17, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Change low Id High ID using eMule
Where are you Santiago, and Emule is still having conflics with its scripts, just change to a another Source, I will pull itup later on tonight and see where the Problem is,...
May 28, 2008 | Computers & Internet
Emule Show Low ID on Client Computer
Dear sir/madam,
You can update the servers it may be become fast. Go this site and add all servers (add to emule) click this link, they automatically update the servers.
OR try this
First of all you need to know the IP of the computer that you use with Emule.
Then go to the router configuration:
- Choose "NAT Settings", and "Virtual Server".
1- If it isn't enabled, enable the "Virtual Server".
2- In "Well-Known Applications" choose de option "User defined".
3- Now the crucial part. Under the Virtual Server List, in the "Local IP" you place the IP of your computer (on the example,, i.e. my emule computer ip), "Port Range" put 4662 and Protocol TCP. "Protocol nº." stays blank, and in the "description" you can put Emule Rule Nº1.
4- Click ADD, to add the rule to the table.
- Again you make the same passes from 3 to add the second rule:
3- In the "Port Range" you place 4672 instead 4662, and on Protocol you place UDP instead TCP. On "Description" you can place Emule Rule Nº2.
4- Click ADD.
5- After making the 2 rules, click Finish, and on the next screen click on Save&Restart button.
In the next time you start Emule, you can acess to the servers without Low ID.
Don't forget to rate the solution
Mar 23, 2008 | Computers & Internet
Emule lowid
I am sorry, but I would not listen to advice that you need to disable your Firewall for it to work!?!
Obviously as the response shows, even with the Firewall disabled it did not work [and would be vulnerable to attack]
There are two possibilities off hand:
  1. You have not taken into account forwarding ports in your Router as well as Software Firewall [if applies to you]
  2. Your ISP may be aware of using the ed2k protocol and try to stop you from using eMule
Remember to use the OBFUSCATION option.
This option in eMule allows you to connect to a server in a way
that masks or 'hides' the ed2k (eMule) protocol
Go To Options > Security
Here you'll tick the "Enable Protocol Obfuscation" box
Remember to only tick the first box under "Protocol Obfuscation"
You should be able to see your 'hidden' status on the right side
of the server window in eMule
If your ISP was in fact interfering, this should help you gain back your ability to use eMule without restriction
Oct 06, 2007 | D-Link DI-707P Router (DSDLDI707P)
Low ID on emule when am using Belkin F5D7230-4 router
You need to find out what port Emule uses for sharing, then enter the port number in you routers Firewall Virtual Servers menu in the settings and enable your pc's ip address to accept inbound connections.
Jan 20, 2007 | Belkin F5D7230-4 Kit (F5D7230V4SNPDQ)
Low ID on eMule
One more thing re low id on emule - try to choose ports between 10000 and 60000 - many isps block the standard ports that emule users choose, and you will see people saying to choose one over 5000, but I'd chosen ports between 5000 and 10000, and still had no luck until I went over10000.
Most isps don't monitor ports over 10000, so if you still have low id problems even after port forwarding and setting up your firewall, this may be the answer to your problem! (I got this info off, and it worked for me)
Feb 16, 2006 | D-Link DI-707P Router (DSDLDI707P)
Configure for emule
You must open ports on your router to allow incoming traffic while using eMule. eMule uses three ports*: 4662 (TCP) 4672 (UDP) 4711 (TCP) Visit eMule here. * To prevent getting a low ID (Firewalled), open additional TCP ports between 4661 and 4665. Also, limit the number of connections in the eMule software. You may need to change the TCP Clientport to something other than 4662.
There are several reasons why this is happening. Most likely the reason is simply because you are behind a router or firewall and the correct ports are not open.
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
D-Link 802.11g Wireless Router WBR-1310 (WBR1310) Logo
706 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
