Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
I having a sporadic knocking from the bottom of the reffer side
After about 4 years I have had a knocking from the bottom, This is not the ice maker! the repairman has been out 3 times to "try" and fix the problem. Just like your car the knocking NEVER  occurs when the repairman is here.  The knocking seems to occur mostly in the evening, each time it only last for about 20 40 seconds.  It strong enough to be felt when sitting in an easy chair about 6-9 feet away.  The last time the repairman "bent" some brass tubing behind the cardboard cover,,, telling me it was something to o with the new type of freon now being used.  this seemed to make a small difference, it did not knock for about 10 day. Now it has started back again, when it started again it was not as strong or as long in duration. But it was started ti increase in strength and duration,,,, so anybody got any solutions ???
  • 30 Answers
ProbabyTry to Change Rubber Base Groumet for Compressor motor and there is nothing with freon
Kindly inform me When Solved
Good Luck
Posted on Feb 16, 2009
GE side by side refrigerator-freezer daily makes loud grrrrrnng noise. Sporadic. Comes from area just above ice maker. Makes no difference if I turn ice maker off. Any ideas what is causing this?
Many ice maker sporadically turn to keep ice from freezing together and becoming a solid block of ice. This would occur even if the ice maker is turned off in order to keep the ice already made from freezing. It is generally short and not that loud. I'm surprised you find it disturbing.
Jun 27, 2016 | GE Refrigerators
We have a Samsung side by side refrigerator that we bought 1/22/2013. The ice maker is working but has begun making a very loud chattering noise. It is producing ice, the dispenser is fine, the only...
Turn ice maker off for 12 hr's. Next time you buy a ref. pay the extra $150 for a 5 yr. warrenty. Ice makers break all the time. All of them!
May 21, 2014 | Samsung Refrigerators
Whirlpool side by side frig, model #: ED2JHGXRBO2, serial #: ST2854810. We have had this frig for several years and almost from the get go when you open the right side door, the door gets so far and always...
I own a whirlpool fridge (side by side) model # ed2jhgxrt02. with a problem with the ice maker. the water is not being delivered to the ice makers. it seems that the switch to turn on the water to flow is not making contact. any suggestions?
Jan 04, 2011 | Whirlpool Refrigerators
Ice maker is not working. Worked sporadically for a while then quit. Filter has been replaced.
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
hdgdhg879
Jun 23, 2010 | KitchenAid KSSC48QMS Side by Side...
I have a one-year-old Kenmore Elite Trio 25 with an automatic ice cube maker in the bottom freezer. The unit makes ice just fine, but appears to fill the bin too full. When I pull the bin out to retrieve...
this particular model comes with an adjustable swing arm for ice prduction
pu the swing arm on the 2nd to last click
in the down direction
all the way down is off
Oct 07, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Icemaker stopped making ice
remove the front plastic cover on the icemaker and you will see a bunch of little holes make a jumper wire out #10 or 12 house wire strip about 1/4 inch off the ends an insert in the holes marked t&h this will start a test cycle make sure you hold the plastic insulation so you don't get bit if the ice maker starts cycling remove the wire and watch for it to stop listen for the icemaker valve to open if the ice maker finishes and the valve didn’t fill replace the water valves if the icemaker doesnt cycle and you may have to kind of twist the jumper back and forth to get it to make contact depending on the gauge you used then replace the ice maker motor module if you hear the valve open and the ice maker doesnt fill check for a frozen ice fill tube that should do it
May 24, 2008 | Whirlpool ED2FHEXN Side by Side...
Freezer on bottom cold but frig is warm
Just additional clues..(general). The defrost timers (on non-electronic) usually located at the bottom (underneath), have a tendency to fail. (One of mine is in the center, one was on the left side) There are usually about 5 wires connected to it. If it fails while defrosting.. the fridge will warm quickly and stop cooling, if it fails in cooling mode, you will have the icing up problem. (other) A squealing noise is usually a fan motor. -also- (Freon issues)..as freon is lost from a small leak, first the freezer will actually get colder, but the refrigerator section may be too warm (I know it sound stupid). When enough is lost the compressor will get hot and the fridge will not cool.
Jan 02, 2008 | Amana ARB8057CSL Bottom Freezer...
Frigidare side by side Gallery fridge
sounds like you water is spilling out instead of going into ice maker... check the inlet spout for ice or other blockage
Oct 10, 2007 | Frigidaire GLRS237ZA Side by Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
140 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
