Question about Kenmore 53852 / 53854 / 53859 Side by Side Refrigerator
I have a Kenmore side-by-side refrigerator, model #106.53854300. I just installed a replacement water filter, Kenmore #1090, following all directions to the letter. Ever since, whenever you open the refrigerator door the "accelerate ice" light comes on and beeps. After a few seconds it goes off and beeps. It keeps repeating this while the door is open, or if you close it and open it again. The Status of the filter light shows it as good. What can I do to stop the beeping and light from coming on and off? Is it trying to tell me of another problem? Max Calkins maxcalkins@comcast.net
  • maxcalkins Feb 18, 2009
    Thank you for your suggestion. I didn't really see just how to accomplish the fix you recommended, but after a few days, believe it or not, the problem went away. It stopped beeping and the light does not come on and off any more. Maybe it will come back, if so I will get back with you.
    Thanks again. I hope I am not charged for something I couldn't use.
    Max Calkins
    Sergeant:
  • 326 Answers
The leds you replaced is the on/off switch for the ice maker. When they are dead, they need replaced. The next thing I would do is to be sure the water supply is turned on and then I would manually fill the ice maker mold with some water to see if it cycles by itself.
need to determine if the water valve is defective or the module inside the ice maker. At the end of the harvest cycle(ice maker dumps ice), it sends 110 volts down to the water valve at the rear of the refrigerator. If it is a dual valve, it will be the valve with the smaller plastic water line attached on the output side of the valve.
You would have to put water in the ice maker and wait for it to cycle...then you should already have your voltage meter in place with the probes in the ends of the electrical connections on the valve. For about ten seconds, there should be 110 volts.
if it is not giving proper voltage then the ice maker module is faulty.
Posted on Feb 16, 2009
    Sergeant:
  • 250 Answers
Remove all the ice tray from it and totally clean it internally check out for any loose wiring connection .and check out all the ventilations its getting blocked any where in between.
  • yavier Feb 18, 2009
    if the problem presists try the instyructions given.as now or then it will come back.as the circuit got completed any how.
I have a Kenmore side-by-side ultrafresh refrigerator model # 5255210, serial# SM0649567. I cannot find the water filter. Where is the water filter located on this refrigerator ?
Owning 1 of these refrigerators will require you to replace the water filter from time to time, in order to keep the water fresh and the refrigerator running efficiently. Kenmore refrigerators are made by Amana, Frigidaire, GE, LG, and Whirlpool, so it is important to find out which manufacturer made your Kenmore refrigerator, in order to make sure you order the right part. Kenmore refrigerators use filters that are located in the bottom, front panel of the refrigerator. Details can be found on WiKi how to change a water filter on a Kenmore Refrigerator.
May 24, 2016 | Kenmore Refrigerators
On my Frigidaire Gallery side by side refrigerator, my filter keeps popping out. When it is engaged, I get water but no ice.
replacement water filter keeps popping out of fridge - Shop ...
www.shopyourway.com > Manage My Life > Questions
Kenmore fridge water filter replacement #9911 looks a little different than the last one and pops out after a few minutes of installation ... How do I fix my Kenmore water filterthat keeps popping out? ... Side-by-Side Refrigerator - Stainless Steel.Missing: gallery
Frigidaire Pure Source 2 water filter keeps popping out. - Fixya
www.fixya.com/support/t2000027-frigidaire_pure_source_2_water_filter
... filter keeps popping out. I am posting this again because there were no responses to - Refrigerators question. ... I am trying to replace my water filter with a newFrigidaire Pure Source 2. I have a side by side Frigidaire. I removed the old ... When I press the water lever the Pure Source 2 filter pops out. I called Frigidaire and ...
Dec 26, 2015 | Frigidaire Refrigerators
Low water pressure & ice maker problem
Hi! you don't say how old the refrigerator is, but if it has a water filter, the problem may be that the water filter needs replacement. If there is a water filter, it may be inside the refrigerator side, usually up top towards the back.
If you see a filter, you can buy a replacement at Sears. While your there, check out their water filter subscription. They'll send a water filter to your house on schedule, so you can replace it when needed.
Oct 28, 2013 | Kenmore Refrigerators
Red light on to replace water filter, how to do this?
Knowing just who made your Kenmore refrigerator may some day be important because Kenmore does not make the brands they sell. I am going to try to get you as many different ways the water filter can be changed as I can but if you can you locate the model number of your Kenmore it may make things much easier should you need parts or a manual some day. The number should look like this 521.345678 and located around the inside of the fresh food section door.
Here nis what I have found on different models and water filters from Whirlpool How to Replace In-Grille Refrigerator Water Filter - Push Button
How to Change the Water Filter in Your Refrigerator
Whirlpool Part UKF7003
How to Change a Kitchen Aid Refrigerator Water Filter
Read more:
If by chance you are able to find your model number that looks like the 513.235647 I mentioned before this will solve just what instructions you need or you can post a photo here or swend one to my email appliancepartsse (@) yahoo.com and I will be glad to help you get a manual and instructions for changing your water filter, Thanks Sea Breeze
How to Replace Interior Refrigerator (Filter1) Water Filter
Jun 25, 2012 | Kenmore Side by Side Refrigerator
I have a kenmore model 106 side by side and after changing water filter I have no water and no ice
Check water volume at wall cutoff
Did you install the filter backwards?
If it is an inline filter in the back you can install it wrong way.
Check for kink in water line in back
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 06, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Leaking water and replace filter light not resetting after filter replacement
are you sure that the filter is installed corectly
remove the filter and reinstall it to be sure
May 11, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Refrig with Filters water and ice dispenser- water is dripping when not in use, no flow when activated
valve needs to be replaced. it is located in the back, just follow the water line to it. to shut off water there is eaither a shutt off behind ref or in the basement. again try to fallow the water line
Oct 22, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore 53852 / 53854 / 53859 Side by Side Refrigerator Logo
26 people viewed this question
Top Kenmore Refrigerators Experts
Sal De GO PATS
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
