Question about GE 29488GE2 Corded Phone
Handset has no sound
THE HANDSET HAS NO SOUND.THE SPEAKER PHONE WORKS FINE. DISPLAY SHOWS STATION 3 AND I CAN'T CHANGE IT ALSO WHERE CAN I DOWNLOAD THE MANUAL THANKS
    Problem Solver:
  • 7 Answers
Manual:
http://www.fixya.com/support/p129790-ge_29488ge2_corded_phone/manual-13384/page-17
First for the handset sound you want to check and see if the cord to the handset is bad. Check this by switching this cord with one from a working phone. If this works but a new cord.
Second, sometimes the receiver switch is the problem. Gently try slight side to side force on the receiver switch (button that get pushed in when you hang up the receiver). I have found that often the receiver switch is the problem. To fix this, if you feel comfortable, you will need to open up the phone and try to readjust the switch from the inside.
I discovered this problem myself on phones where people slammed down the receiver one to many times. I could lift the receiver to stop a ringing phone but either I or the other party on the phone could not hear me. The switch was the fix in addition to telling people to not slam the phone if they get mad.
Posted on Dec 29, 2009
Why do I see Base no power on display which also shows Charging?
Your phone is trying to connect via radio to a "base station". If you don't have one, your handset cannot work.
If you have a base station, your handset may need to be "registered" to it.
Apr 12, 2016 | Panasonic KX TGA680B DECT Accessory...
Please advise as to how to increase the VOLUME on my DECT 6.0 phone.
To adjust the ringer volume:
  1. With the phone in standby, press ^ or v. The display shows the current volume level and the handset sounds the ringer at that level.
  2. Use ^ to make the ringer volume louder or use v to make it softer or turn it off completely.
  3. When you hear the ringer volume level you want to use, stop pressing keys. The handset will use the new ringer volume starting with the next incoming call.
Note: If you set the ringer volume to Off, the handset won't ring. If you have any accessory handsets, other handsets will ring according to their individual settings.
To adjust the earpiece volume:
You can choose from six volume levels for the handset earpiece. To adjust the earpiece volume while on a call, press ^ to make it louder or v to make it softer. The handset display shows the current volume level for the earpiece.
To adjust the speaker volume:
You can choose from six volume levels for the handset speaker while on a speakerphone call. To adjust the handset speaker volume, press ^ to make it louder or v to make it softer. The handset display shows the current volume level for the handset speaker.
Note: The handset earpiece and the handset speaker have separate volume settings.
Apr 06, 2011 | Uniden DECT 6.0 Cordless Telephone...
System error #1 Panasonic kxtg2770
1)On handset, press MENU, 0, 0, 1.
Handset display shows as follows.
*Skip this step when handset already shows as above.
2) On base unit, press LOCATOR for 3 sec until CHARGE LED flashes.
3) On handset, press OK button. Then wait until the handset display changes as follows.
If you receive an error message indicating the maximum number of handsets have been registered, you will need to deregister the handset from the base unit, then try to register again.
*If this does not work, your unit is defective. Please send your unit for service.
Panasonic Services Company Customer Servicenter
Suite B 4900 George McVay Drive
McAllen, TX 7850
McAllen, TX 7850
1) Press FUNCTION on handset. Then, using the Navigator key, press Down (V) 4 times, Right (>) 1 time, Down (V) 7 times, Right (>) 2 times.
2) On base unit, press MUTE. (MUTE LED flashes.)
Dec 04, 2010 | Panasonic KX-TG2770 Phone System w/...
How do I change time and date on Toshiba DKT2020SD
Toshiba DKT2020 set work with a lot of different Toshiba systems. That being said this should get you in the right direction.
Date
  • From receptionist station, without lifting the handset, press "Intercom"
  • Dial "#651"
  • Dial the time in YY:MM:DD format.
  • Press "Redial" or "#".
  • Press speaker.
Time
  • Dial "#652"
  • Dial the time in military format HH:MM:SS.
  • Press speaker.
Day of the Week
  • Dial "#653"
  • Dial the day of the week (1-7).
  • Press speaker.
Nov 09, 2010 | Toshiba Lands Phones
My phone says no link to base but I am right beside it.
Sounds like the antenna on the base station is not receiving, or the cordless handset is not transmitting -OR- the sets have never been registered to the base station (please look up registering to base station, if the set has never been registered)
Did the cordless set work before?
The base station or the handset may just have a hick up, I would un-plug the base station and leave it un-plugged... now get all the cordless set(s), and take out the batteries from the cordless set(s). Wait for about 15 seconds for all the power to drain out of the sets, then re-install the batteries.
Once all the cordless sets are back up and working, plug in the base station and wait for about 1 minute.
This forces the base station to re-establish and link between the base station and the cordless sets.
Good luck
May 11, 2009 | Panasonic KX-TGA101S Cordless Handset
Wharfedale digital orb twin phone
TO REGISTER A HANDSET
[At the base]
1. Press and hold the the PAGE button on the base station for at least 3 seconds. You have 90 seconds in which to register a handset.
[At the handset]
2. Press MENU and scroll to ADVANCED SET and press MENU
3. Scroll to REGISTRATION and press MENU
4. If necessary scroll to display REGIST.BASE and press MENU
5. BASE 1 2 3 4 is displayed and the registered base number is flashing.
6. Enter the number of the base you wish to register to your handset. If you have only 1 base station, press 1. If you have 2 base stations, press 1 or 2, etc.
7. When the display shows PIN---- , enter the base pin.
8. When the handset is registered to the base it is assigned a handset number.
If you have forgotten your PIN you will need to:
Reset your ORB
1. Press MENU, scroll to ADVANCED SET and press MENU
2. Scroll to RESET UNIT and press MENU
3.CONFIRM? is displayed. Press MENU
[NOTE: Entries stored in the phonebook and new answering messages are retained. You PIN will return to the Default setting 0000]
To Set the PIN
1. Press MENU and scroll to ADVANCED SET and press MENU
2. Scroll to PIN and press MENU
3. Enter the current 4 digit master PIN and press MENU. [Default setting is 0000]
4. Enter the new PIN and press MENU
Hope this has been helpful!
Rob
Dec 28, 2008 | Uniden Cordless Phone
Audioline cordless phone
answering machine not working on the base station
Jan 13, 2008 | Philips CD6452B/37 Twin Cordless Phone
Answering machine replay is garbled
Your handset battery will have no effect on the answering machine audio, providing your regular audio is fine (its fine when you make a phone call right?), I will assume yes. I have seen this problem in these models, and your problem lies in your base station, and the only fix you can attempt is to go into base programming and delete as much as you can out of the memory, greetings, old messages, etc.. Power down, then power back up again. Call in and leave a message. See if it sounds better through the handset or the speaker on the base when you play it back. If its garbled both ways (reviewing through the handset or on the speaker base) , then your problem is in your base memory. If it is just garbled on your handset, then it may be a radio module problem with the base, either way it probably needs to go in for repair. I don't know if Panasonic still repairs that model, but if you google Panasonic cordless telephone repair, you will find someone. Good Luck, CG
Jan 11, 2008 | Panasonic KX TC1731 Cordless Phone
Cordless Handset fails to Link to main corded phone
Here it is, 2008, March and still no answer! LOL! I am having the same problem! It linked fine when I first got it, and now since I can't find the manual I can't get it to link again! Can anyone help? Please
Apr 13, 2007 | GE 27957GE1 Phone
GE 29488GE2 Corded Phone Logo
118 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
