Question about Acer InviLink 802.11b (91.49C10.002) Wireless Adapter
Issues connecting acer 4420 to sharp aquos 32 720p lcd tv
When i connect my laptop through the vga cable to my tv the screen flashes every 3 seconds (vista is my OS), but when i connnectd a IBM R51 to the tv everything was great.. also i downgraded my acer to xp and the screen was not flashing, but i had to put vista back on it due to a whole slew of issues with xp on that model. the video card in the acer 4420 is a radeon express 1250, but i know its not the card i believe it is the catalyst control center, has anyone had this issue with the flashing on the tv... any fixes for it?
54 GTM implementation of the graft proposa of 802.11g
Posted on Feb 18, 2009
Hi i have a sharp aquos lc-37d43u tv and I can't get it to connect to my computer .I tried HDMI and VGA but I just don't seems to understand how to make it work ;( Please HELP
prob with sansui sty 0330 LCD TV
hi,i have a sansui sty 0330 tv and the screen is flashing 1 second flash, 1 second good, then 1 second flash, 1 second good is going like this contineously
Dec 18, 2013 | Sharp Aquos LC-37D43U 37 in. LCD HDTV
How do I connect my Acer Aspire 5742 to Sharp Aquos LCD TV
Which operating system? I know in XP I've had to set up a dual monitor screen before the OS will broadcast to the VGA/HDMI port.
Dec 31, 2011 | Acer Aspire 5742Z6682 Notebook
How do I connect my Sony Vaio PCG 6122M laptop to my Sharp Aquos LCD TV?
the should be a vga connector on your laptop,usually blue,then a matching one on your tv inputs,obviously you nee d to connect them with a vga cable,unless you have HD ports
May 13, 2011 | Computers & Internet
Can I hook up my Toshiba laptop to my Sharp Aqous TV, if so what connections do I need, ?S-video? I have an SGA connection on my laptop but not on the TV?
If this is the exact model Sharp Aquos television you have then you would have to have a laptop that has hdmi or dvi. You can try S Video on a laptop but the laptop's resolution would have to be so low that most laptops cannot accommodate this. You're right; this television does not have a VGA (RGB cable) input.
Nov 02, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Vga cable connects TV to HP laptop...then what?
You have to enable VGA port on the laptop. Press Fn + F5.
Nov 15, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Problem connecting my PS3 to my Sharp Aquos LC-C3237U LCD TV
Your PS3 set itself above the max resolution your LC-C3237U. Most likely the PS3 is doing 1080P, but the highest the Sharp can do is 1080i. So do this:
1. Connect PS3 to TV (you can use the current cable or analog cable)
2. Turn on TV and set input to port PS3 is on.
3. Make sure PS3 is connected via correct cable.
4. Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
Sep 15, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
How to use a sharp aquos as a monitor with my laptop
Hi. You haven't said how you have connected your laptop to your TV so I'll give you a couple of options:
1. VGA to VGA (This cable is a 15-pin cable like the one you would use to connect a computer monitor to the back of the computer box itself). The Sharp has a VGA connection at the back.
2. DVI to HDMI. If your computer has a DVI output, this would be the best connection.
On your remote, press menu.
Use the left/right arrows to select option
Then use the arrow up and down to select input source.
Depending on the TV you have, you will either see the actual name of the connection (ie. HDMI, DVI, VGA) or you may need to select Input 1, Input 2, etc... depending on which connection you used. The input number may be labelled on the back of your TV.
If none of this works, please let me know your model numbers and I can provide you with instructions specific to your models.
Jan 19, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
SHARP aquos 1080p HDTV: VCR image flickers when playback
I have the same model TV and the following worked for me. I am using A/V cables attached to Input1 on back of the TV.
On your Sharp TV remote control:
1. Select the Input (1-5) that is attached to your VCR.
2. Go to the menu and select options.
3. Change your color system to NTSC.
This should stop your picture frome flashing on and off.
You still may have a issue with the screen colors. I don't know of a way to address this, other than to make the picture monochrome.
Hope this helps.
Jun 26, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
VGA to SHARP flat sreen tv
1. vga to vga cable
2. vga to dvi cable
3. vga to dvi cable, then dvi to component cable
Your tv must have 1 of the following:
- vga connector
- dvi connector
- component connector
Feb 24, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Computers & Internet Logo
304 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
