Question about Electrolux Ovens
How do i get my electrolux oven model EPSO MMS out of auto mode?
Hi, I was given this oven and now cannot get it out of auto mode. I understand that you have to push 2 of the 4 buttons in to do this. The only 2 that seem to do anything are the 1st 2 .Once I stop holding them in the clock and auto mode start flashing again .As I don't have a user manual so any help would be appreciated . Also if anyone has a manual I would love a copy if atall possible .
Many thanks in advance
Louise .
  • herbie7_6 Feb 17, 2009
    Hi ,Sorry I put in wrong model number it is an Electrolux single builtin fan oven EPSO MSS (not MMS as I had put).
    After many hours of trawling the net I managed without help to sort this :)
    It seems that pushing in the first 2 button whilst turning the wee timer knob worked to get it out of auto mode.
    Also have now managed to find copy of manual online , although their answer to this is to press the 4th button ( which didn't work in fixing it atall ) I've added where you can find this manual for anyone who needs it .
    http://www.serviceforce.co.uk/pdf_search... then in product number code (which I found on top of oven ) 949711039 this will open a pdf manual for you .
    Cheers from one happy lady ,
    Louise .
  • Jyackle5
    Jyackle5 May 11, 2010
    What is the model #
SOURCE: Instruction Manual Needed?
Hold cook time button and stop time button together and while both buttons pressed in, use + and - buttons to set time.
regards Paul.
Posted on May 23, 2008
  • 12 Answers
SOURCE: Gaggenau EB 270/271 Electric Clock
To set the clock:
1. Press the clock key 3 items until the hr/min icon flash.
2. Press the + or - key until it come to your desired time.
3. Press the confirmation (check) key.
You have your time.
If not, call the service support.
Posted on Sep 01, 2008
barkencoa
  • 3463 Answers
SOURCE: creda concept solar plus oven timer
Hold down the 2 left buttons together, and press the + or - button at the same time..
This should reset the timer.
Please leave a fixya rating for my solution.
Thanks.
Posted on Feb 12, 2009
dniro592006
  • 121 Answers
SOURCE: My Frigidaire electronic self cleaning oven (ES IV)is beeping and flashing F1 and I cannot get it to stop or reset.
Disconnect the plug to oven and let set for 30 secs then re plug into receptical
Posted on Jun 02, 2009
SOURCE: Kleenmaid Scala Oven. My oven will not turn on.
I had exactly the same problem. I followed the directions to reset the clock. That is the cooking button and finish cooking button. They look like a caserole dish and a casserole dish with a cross through it. Hold them down at the same time and the + and - button to advance the time. Be aware I had to try this a few times before it worked. Hope this helps, Dean
Posted on May 14, 2010
How do I fit a seal to an Electrolux oven with rounded corners and no clips
Good Afternoon friend, thank you for your post!
I understand that you need help with the seal on your Electrolux oven. Could you provide me with your model number, please? The serial tag is located on inside wall of your oven. With that information I can provide you further assistance. -Matt
Feb 12, 2015 | Electrolux Ovens
Electrolux model EKT6045x error code F9 on oven display
You may wish to try a reset by following these steps:
Processor is auto resetting
  • Disconnect oven from mains power
  • Wait five minutes with no mains connected
  • Reconnect oven and restart
Feb 10, 2015 | Electrolux Ovens
Electrolux oven racks how do they go in oven?
Hi Friend, that's a great question!
I see that your post is listed under Electrolux Wall-Oven. May I have your model number please? You can normally find the serial tag (which lists your model number) on the front of the oven, on the left side, as you open the door. With this material I can provide you the correct instructions on how to place the racks in your Electrolux wall-oven. Thank you! - Z
Jul 20, 2014 | Electrolux 30" Built-In Double Electric...
Electrolux oven wont stop beeping
Hi Friend, I am happy to assist you!
I understand your Electrolux oven is continuously beeping. Without knowing your specific model number, let's try resetting your oven. This can be done by either unplugging it or flipping the household circuit breaker to the off position. It is best to wait roughly ten minutes and then turn on your oven. If resetting the power does not correct the issue, then your range could possibly be experiencing a communication problem with the EOC (electronic oven control) or a potential wiring failure. Hope this helps! - Z
Jul 13, 2014 | Electrolux Ovens
How do I remove the oven door from my electrolux icon oven
Good Morning Friend,
I understand you are trying to remove the door on your Electrolux Icon oven, model# E30SO75ESS. Being, that this particular model is a microwave as well as an oven, I suggest contacting your local authorized technician. They have been trained on this particular model and will be able to assist the best. Hope this is helpful.
-Best Regards-
WP
May 29, 2014 | Electrolux ICON Designer E30SO75ESS Oven
Self oven cleaner
Hi Debbie, this is AP
I understand you are having trouble getting the self-clean mode on your Electrolux ICON wall oven to start. On this model, E30EW86GSS, you must remove the rack supports in order for the self-clean mode to start. To remove the oven rack support for
a self-clean cycle, pull up the support to disengage them from the brackets. If the rack supports are not removed, the self-clean cycle won't start. If you find that this does not resolve your concern and you following the self-clean instructions precisely I would recommend contact a local authorized technician to inspect your wall oven. I you need assistance locating a technician please visit the manufacture website for additional information. I hope this information helps to some degree - thanks for your question, and please do not hesitate to reconnect if you have additional information regarding your question.
Thanks,
Mar 18, 2014 | Electrolux E30EW85GSS Oven
Electrolux oven wont work after cleaning
Hi ja1078063,
I understand you having trouble getting your oven to work after using the self-cleaning mode. Does any part of the oven work? Confirm a fuse is not blown or a circuit breaker tripped. Test the power outlet with a lamp, hair dryer, etc.
Does "Loc" appear in the display if any button is pushed?
The Oven Lockout feature automatically locks the oven door, prevents most oven controls from being turned ON. Press and hold CLEAR/OFF for 3 seconds. A beep will sound. LOC will clear. The "DOOR LOCKED" will continue to flash until the oven door has completely unlocked.
Best Regards,
Jan 22, 2014 | Electrolux EW30EW65SS Stainless Steel...
Electrolux EOC68000X oven Demo mode only
If that model number EOC68000X is correct then in the manuals I have for that Model there is no Demo mode setting.If you can supply the PNC number then I will investigate further.Try relogging your call with this information.
Hope this helps.
Jun 06, 2010 | Ovens
Electrolux EOB 966 stuck in auto mode
Hi, try to switch it off at the main switch. Wait for 10 seconds, then switch the power back on, reset the clock, and you should be fine.
Cheers
Feb 12, 2009 | Electrolux EOB6696X Electric Single Oven
Ovens Logo
81 people viewed this question
Top Electrolux Ovens Experts
ashburton
Mack Baxter
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
