Question about Kenmore 73952 Gas Dryer
Whirlpool gas dryer two years old does not heat.
Model LGC9000PWo Serial MS2804813. Can an ordinary person check the heat system? Where is the fuse?
    Novelist:
  • 117 Answers
If you remove the rear cover on your dryer after unplugging it, look for a small white piece of plastic about 1.5 inches long with two wires attached to it. This is the fuse. Can I help with anything else?
Eric Campion
Posted on Feb 16, 2009
Whirlpool gas dryer takes longer to dry though it heats up and turns, yet it has a humming/buzzing noise. What could be the problem?
Had the same problem. There was a bit of a kink in the vent duct which caused lint to build up in duct and also inside the dryer itself over years. I replaced the duct and took dryer apart and cleaned out the air passages.It works great now. As for the humming, mine started about 2 1/2 years ago and I still don't know why.
Jun 04, 2012 | Whirlpool Dryers
Model LGQ88800JQ0 Serial number MK1801241 It is not drying. I check the thermal fuse and it has continuity. Could you please help. email: pachy92@hotmail.com phone 262.521.9369 Francisco Martinez
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
Jul 18, 2011 | Whirlpool LGQ9857L Gas Dryer
We have a 10 year old Whirlpool Dryer Model #LGB6200KQ0 drum is turning but no heat. Could you please advise?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 02, 2011 | Whirlpool LGV4634JQ Gas Dryer
My whirlpool dryer, model LGC6646AWO will not heat. It doesn't sound like the electonic ignition lights up. what part most likely needs to be replaced? this dryer is 16 years old
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 25, 2010 | Whirlpool Dryers
Our dryer has no heat. The drum turns and we checked the vents. All clean. Also we checked the fuse. Is there a heating device? It's 5 years old. Thanks Cathy
heatman101
Oct 23, 2010 | Whirlpool LEB6300 Electric Dryer
My dryer is about 7 years old...it runs but no heat isnt spewing out....and it only works on the "timed" settings......Its a Roper super capacity.....model number RGX5634KQ2....serial...
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 23, 2010 | Whirlpool Dryers
Gas Dryer no longer putting out heat.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
heatman101
May 14, 2010 | Whirlpool GEQ9858J Dryer
Frigidaire dryer no heat thermal fuse seems ok? dryer is a 2005 model. model number and serial numbers worn off tag?
check your vent, make sure it is not plug with lent. If it is not then your heating elements.
Dec 06, 2009 | Frigidaire Dryers
Runs normal but no longer heats anything. model # JVM1451BA 001 serial # RT9227675
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Oct 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Kenmore 73952 Gas Dryer Logo
115 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
