Question about Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser
Water dripping from freezer when defrost kicks on.
Inside refrigerator, I believe when the defroster kicks on, water will drip from the roof of refrigerator/floor of freezer. The water will often freeze on the top shelf but sometimes works its way all the way down to vegetable crisper. I believe it is from the defrost unit as it does not do it all the time - but I really don't know. I have a 9 year old Kenmore Refrig. with no ice maker.
  • kingjay913 Feb 21, 2009
    Opened up the bottom of freezer and there was all ice. Broke most of the ice and then use a hair dryer on the rest of it. The plug was completely invisible under the ice. Once found, I used boiling water in a turkey baster to squirt into the plug. After several applications, the water flowed out. So far so good. Now I have to just wait and hope. But I am curious as to what caused the initial clog in the plug in the first place. If is was ice, why did the water freeze? Will post further in a few weeks and let you know how its going. Thanks.
  • 135 Answers
You probably have a plugged drain in the freezer compartment. Open that up and check it. Hope this helps!
Posted on Feb 16, 2009
Kenmore 10677181791 water dripping into refrigerator from freezer
probably an ice buildup around the drain tube not allowing proper flow thru to the drain. Try defrosting fridge for a while so the entire ice mass defrosts in between fridge and freezer
Feb 09, 2012 | Kenmore Refrigerators
The water is dripping from the inside roof
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 27, 2011 | Whirlpool Refrigerators
Our Crosley CS20 refrigerator/freezer has been dripping water on the floor and the bottom of the freezer has been full of ice. We defrosted the freezer, taking everything out of it, and saw there was ice...
Defrost drain is frozen. Poor hot water around it until it is clear. You will most likely have to take inside back wall of freezer off to access defrost drain. While you have it off, inspect metal pan to be sure holes aren't rusted in it. Some are aluminum, but some are steel.
Sep 05, 2017 | Crosley Refrigerators
Water dripping inside of freezer, forms ice-cicles, water doesn't dispense and temp. rises on both freezer and refrigerator.
Check rear inside wall of freezer for frost build up, this prob is an indication that you have a defrost problem, like a bad defrost heater or defrost control.
Sep 28, 2009 | GE Profile PSW26P Stainless Steel Side by...
The fridge is dripping water from the inside roof. seems like it is comming from the freezer, I dont have any of the water lines hooked up?
I believe your condensate defrost drain is either blocked or frozen over behind the rear panel of your freezer. There are many reasons for this happening for example water leaking from a water supply line for the dispenser or ice maker, a crack in the defrost pan, water leaking inside and draining through the refrigerator cabinet, but most are caused by a defrost drain line blockage. Below is a link that may be helpful so try to take it all in and use the parts that most refer to your specific problem, there is also a shot movie that makes the repair look easy, Thanks Sea Breeze
click on link below
Sep 28, 2009 | Whirlpool Refrigerators
There was a noise coming from the freezer area.water was dripping from the back and landing on a wire that was glowing red .could this be the self defrost possibly not shutting off . refrigerator side was...
The noise you are referring to is sizzling, popping and dripping noise. This is normal during a defrost cycle - there is a heating element that melts frost ont he evap coils - the water drips through a drain through a hose at the back of your freezer and onto a drip fan which later gets evaporated. The way the entire circuit is designed, in serie, is that once the defrost kicks in, it will cut off the contact to your compressor, once defrost stops the circuit si switched back on and your compressor starts..... It is possible for a defrost not to stop due to thermostat/limited problems in which case your unit would be stuck in this cycle and your food would melt and spoil :) In very rare cases will the defrost be stuck and your compressor running.
This can be fixed with a control board replacement at the back of your freezer.
Sep 25, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Our upright freezer drips water on the floor. We believe the seal is bad since ice also forms inside at the top of the door. Is the seal replaceable or should we buy a new unit?
Self-defrosting refrigerators/freezers dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates.
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator/freezer compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Aug 16, 2009 | Freezers
Water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
Jun 02, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Freezer is dripping water into the fridge
If your refrigerator has a ice maker or not I think the drain is clogged for the defrost water. We may need to unplug and look behind the freeze back wall to see what is happening. If you would please see if you can find the model number so I can help you better, Thanks Sea Breeze
seabreezehvac@yahoo.com
http://servicepartstec.blogspot.com/
Apr 21, 2009 | Refrigerators
Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser Logo
213 people viewed this question
Top Kenmore Refrigerators Experts
Sal De GO PATS
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
