Question about KitchenAid KERC507 Electric Kitchen Range
KitchenAid kerc507hbs3 won't self clean
I have a kiechenAide kerc507hbs3 range and the self cleaning function does not work. It gives me an error code after heating up for about 10 minutes. Now when we try to cook at 450 degrees or above the over door locks and you have to wait for things to cool down to get the door open. I have had a repair man fix it one time and it worked for one self cleaning. The next time we tried to self clean (about a year later) it started giving the error again. I don't know what he replaced last time because he replace alot of things trying to get it to work. I don't think he really knew what to do either.
catriver
  • 878 Answers
SOURCE: Clean cycle in oven doesn't work: FO EO
Oliversmom, Im not coming up with any information on the model number posted. However on the kitchenaid the F0 E0 is default for no error. Press the cancel button to put the range in idle state. Then in this order press cancel-cancel-start. See if an error code comes up different from the F0 E0. The F0 is what is throwing this whole deal off. If it was F1, F2, F3 etc...it would make more sense. See if you have a complete model number you can post along with the error code after doing the above key dance. We'll see if we can solve the issue....Catriver..post back.
Posted on Apr 03, 2007
aborcass
  • 2651 Answers
SOURCE: GE Range Problem
f3 is a faulty oven sensor, 2 scxrews and a wire connection, located in the top left corner of inner cavity, pull it out and bring it to a local part warehouse, change yourself for 50-75 bucks
Posted on Mar 31, 2008
aborcass
  • 2651 Answers
SOURCE: KGRA806PSS00 oven dead after self cleaning
heres the part number for the saftey thermostat 8300802
Posted on Apr 08, 2008
  • 4 Answers
SOURCE: KitchenAid oven shut down during self-cleaning
I've had the same problem and have had the thermo-protector switch replaced four times. After the last time I was so ********** I wrote to the CEO at Whirpool/Kitchen Aid in Benton Harbor, MI with my complaint. Today I received a call from an extremely nice lady in his office who said that they were sending me an updated kit for repair free of charge. The part number is 9759243. She offered that this was a known problem but was limited to just one production run - my luck!
If you are having this problem with your KGSA906PSS write to the CEO at Whirlpool!
Posted on Feb 02, 2009
  • 17 Answers
SOURCE: I have a kitchenaid gas range and the door is stuck in lock
hold the oven door lite switch closed and put it on selfclean it should activate the door lock
Posted on Nov 14, 2009
Error code FO5...oven dead
Duel fuel? Which one does the self-cleaning? I'd bet electric. If so, the gas mode must not be used, and it may be telling you that.
Apr 10, 2015 | KitchenAid KDRP407HSS Dual Fuel (Electric...
Oven lite won't go off and when turn on self cleaning it says door
The door switch has gone bad. This will keep the oven light on and the self clean won't work because it thinks the door is open.
Dec 12, 2011 | KitchenAid KESC307 Electric Kitchen Range
Self Clean will not work. F5E1 Latch not operating
Before you go working too hard to get you oven to go into the self clean (self destruct) mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
May 21, 2010 | KitchenAid KERA205P Electric Kitchen Range
Kitchenaid DF Range F04 error code
I have a dual fuel kitchenaid convection range and I put it in self cleaning mode last night. Afterwards it said F 04 on the display. The doors open again, but neither of the ovens work
Nov 17, 2009 | KitchenAid KDRP487MSS Dual Fuel (Electric...
Kitchenaid Range KGRA806PSS Control Panel Not Functioning
You're right about not using the self clean option. Your oven gets up to over 800 degrees when you use that feature. You can choose to simply keep your oven wiped out, rather than self clean it. The timer is most likely going out if the "stop" button doesn't work after cleaning. Please call or email us and we will be sure toget the right part for you. I hope this solves your problem. Ella
Sep 09, 2009 | KitchenAid KGSI901PBS Gas Kitchen Range
E3F3 on kitchen aId Model KGSS907SSS00 while self cleaning
doorlock will not disingage after self clean cycle is through
Mar 20, 2009 | KitchenAid KGSA906PSS Gas Kitchen Range
I have a KGST300 gas freestanding range. I tried to run self clean, but immediately after starting I canceled, as I forgot to remove the oven racks. The process stopped, and the door unlatched, but I...
The manual for your range suggests you call 1-800-422-1230 for error assistance.
sorry i couldn't be of more assistance but this should get you on the right direction
Dec 01, 2008 | KitchenAid KGST300 Gas Kitchen Range
By the way the door lock error will stay there until the oven cools. Once it has cooled it will go away. the reason is in a self clean the oven is supposed to get very hot to clean. The door lock is for your protection. once it has cooled down enough the door lock will go away.
Dec 01, 2008 | KitchenAid Kitchen Ranges
KitchenAid gas range kgst307
Check the trouble shooting section of your owner's manual for any and all error codes. This may direct you on your next course of action.
Oct 01, 2007 | KitchenAid KGST307 Gas Kitchen Range
Self clean inoperative
Dear Superglide, An error code "F5 E1" means "door latch not operating". In such situation I would recomend to replace the oven lock assy (part # 9782611 ) which is located on the back panel.If you are going to do it yourself - DO NOT forget to unplug the power cord first. About service manual - try to call Kitchen Aid directly.
Dec 13, 2006 | KitchenAid KESC307 Electric Kitchen Range
KitchenAid KERC507 Electric Kitchen Range Logo
345 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
