Question about HP Pavilion dv4000 Notebook
HP Pavillion dv4000 cto won't start
So my 3 year old hp will not start. I've tried taking the battery out and just the ac cord plugged in and vice versa. removed the ram, removed wifi card, but none of these will fix it.
  • HP Master
  • 13,433 Answers
Hey,
if the computer doesn't beep at all, and noting comes on the screen.
Lets do this first,
Remote the ram from the computer, start up without ram.
turn the laptop off and unplug, did you hear beeps?
Place the other memory module back in and try starting up.
if the computer starts up then all is ok you can plug in the other ram and start up again. if it doesn't start up then repeat the previous process.
if this has no effect and you don't get any beeps from the computer the motherboard most likely has a problem.
I would suggest you call hp or your dealer to check your warranty.
If you are outside of warranty the repairs will cost you.
Discuss repairs with hp and see if its worth it.
Let me know if you need anything else.
Thanks,
Ekse
Posted on Feb 16, 2009
  • Ekse Feb 16, 2009
    theres no miracle repairs here my friend.
HP Pavillion dv6700 - won't power up
Hi have you tried to power up without battery?
Feb 16, 2013 | HP Pavilion Computers & Internet
Is there any sata slot available on HP Pavillion dv4000 laptop, i mean can i install a sata hard disk in my hp Pavillion dv4000 laptop?
hi this depends on the age if it is older than 3 1/2 year old approx, then you maybe able to put one in, other than that the easiest way to find out is to take the old one out, just look at the back end where it connects to the board, if it has pins in the back its ide if it has just a line of contacts then its sata...hope this helps
Jun 05, 2010 | HP Pavilion dv4000 Notebook
My hp pavillion laptop won't start at all whats wrong?. It hasn't been dropped.
Remove the battery and the AC adapter then press and hold the power button for 30 secs. Put back battery and plug back AC then power ON as normal.------
Also try with ONLY battery (AC removed) and vice-versa.--
Basically I would check output of my AC adapter first. If everything is OK with that, I will check the power button.
---- This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Feb 24, 2010 | HP Pavilion dv6000z Notebook
HP Pavillion dv4000 is stuck with a 'disk read error'
try with Disk Manager so Format with Low Level Format...run in under DOS
Oct 23, 2009 | HP Computers & Internet
No audio driver for xp
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-46934-1&lc=en&dlc=en&cc=us&lang=en&os=228&product=468789
download from hp this driver to your my_documents folder and install the software for the driver... then restart your computer
does this work... solution
or goto start > control panel > system > device manager show up
look at your audio device in the list... does it have a yellow explaination point.. no driver installe
a red mark mean on the audio device means that the sound chip is bad... and you need to ship the board to a repair shop ... or rma the laptop for repair if still under warranty
also go under the bios to be sure the sound is turned on .. there sometimes is an option to turn off the sound functionality
Sep 25, 2009 | HP Pavilion dv4000 Notebook
HP Pavillion dv2500 laptop won't turn on
Kinda strange. Not turning on indicates a hardware problem, you made software changes. If the software changes caused a problem, it would start, just not boot to windows. I would first tryy to reset the laptop. Unplug it and remove the battery, hold down the power button for 60 seconds, then try again. If still no go, start removing hardware one at a time, hard drive, rem, wireless card, dvd rom. You may have a bad hard drive. Your pc should boot to bios if there is no hard drive installed. If that happens, run a diagnostic on your hard drive from your bios. Let me know if you need anything else.
seth
Jul 29, 2009 | HP Pavilion dv2610us Notebook
I have a HP Pavillion DV4000 and it does not charge
pls check if it runs ok during power supply AC and also check Battery contacts on both side laptop side and battery contacts see if rust or residue is sticking there try to scratch it out by some rust removing cream or something normally it happens other wise if the adapter supply is ok AC one then ur battery is faulty try replacing it there is a battery checking utility on HP support software try it , i think it will help u cjeck the batt
pls rate me if i fixed it
Feb 27, 2009 | HP Pavilion dv4000 Notebook
Faulty Connection
I have HP DV6000, I used it without the battery. it worked until I was able to purchase a new battery. It might work on the HP dv4000...
Jan 05, 2009 | HP Pavilion dv4000 Notebook
Battery charging
Does the machine boot and work just on AC?
If it does then you may have a bad battery - Does the old battery charge?
If it does not work on AC then try another AC adapter - even the generic universal kits should be enough to test it.
hopefully that's all thats wrong. let us know.
Dec 27, 2007 | HP Pavilion dv4000 Notebook
HP Pavilion dv4000 Notebook Logo
460 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
