Question about JCPenney Armitron Sport Link Bracelet Watch
Aspen watch band too big
I bought an aspen watch, but am unable to make the metal watch band small enough to fit my wrist.  it is model 74045.  i used the clasp, but it is still too large.  Is there anything else I can do?
  • 2,334 Answers
You may or may not have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Feb 16, 2009
SIZE ADJUSTMENT
If this watch has a metal watch band then links can be removed to make the band smaller.
OR
You maybe able to fit a new smaller watch band to the watch. A watch/jewellery shop will be able to fix or fit a new watch band.
Dec 12, 2012 | Calvin Klein Hypnotic K5424120 Womens...
Can't adjust the wrist band on citizec C651
Look where the band connects to the fold-over clasp. There are several holes on the clasp. Use a plastic headed thumbtack or some other small pointed object to push the pin in and move to desired hole to fit your wrist.
If the longest adjustment is still not big enough you will need to add a link to the band. You can contact Citizen Watch at 800-321-1023 they will send you 3 links at no charge.
Oct 21, 2010 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
I am trying to figure out how to shorten the wrist band on my Casio Edifice EFA-119.
mcdevito75 here, If your Casio has a metal band, you can remove 1--2 links, this takes a special tool called a link remover, best bet is to look for a small watch repair shop in your area. If your Casio has a strap, the buckle may be able to move up the strap to fit your wrist, if so, move the buckle up the strap to fit your wrist and cut offf the exccess strap. If not, you"ll have to replace the entire strap. Hope this helps.
Aug 03, 2010 | Casio Edifice EFA109-7AV Wrist Watch
Watch strap a little big
mcdevito75 here, Maybe a link or 2 can be reoved from the metal band, or an adjustment at the clasp can be done. Look for a small watch repair shop in your area, they can help.
Jul 08, 2010 | Casio A168W Wrist Watch
I just bought a diesel watch from ebay model no DZ7068 and for some reason the wrist band doesn't tighten.. i got confused is there any solution for this? thanks chris
mcdevito75 here, Without seeing the watch NO. Best Bet, visit a small watch repair shop in your area and see about band adjustment, Most likely your missing something on the band you have to use to adjust for your wrist size.
Jun 28, 2010 | Watches
Hi I have a quartz woman's watch that I bought at Big Lots store the other day.. the wristband is too big for me.. how do i shorthen it ? that band is metal...stretching whatever I call-- I need to remove...
Save your nerves and your money. Visit your nearest watch repair shop and ask to get links out. If you will try to do it yourself, you will loose your strap as you wont be able to put it back together. If you anyway decided to do it yourself, click on my profile and check out my solutions. I do explained all this tricky job to one customer about a year ago, so, you will definitely find it if you have enough patience to go through all my solutions. Rate me plz.
Mar 02, 2010 | Citizen Cortina Eco-Drive BM8194-50L Wrist...
Remove links on this watch
Most bands have removable links on the end of the band. You can tell because they have small holes on the side to remove the pins that hold them together. The links that don't have holes are not removable. This is standard on most metal bands.
May 09, 2009 | Timex Atlantis 100 77517 Wrist Watch
My grandson has had two Ironman watches with a
good day,
hope this link below will solve your problem.
watches
Feb 19, 2009 | Timex Ironman 30 Lap 53952 Wrist Watch
Armitron mens watch band link removal
Try http://www.webjeweller.com/jewellery/removelinks.shtml
Dec 25, 2007 | Watches
Shortening the Length of a Metal Wrist Band
I just did this for my wife's new Kenneth Cole wrist watch rather easily. You don't need a screwdriver, but a short section of a paper clip will do. I just set the band on a raise surface to allow room for the pin to be pushed out using the paper clip. For this watch, one side of the pin resembles the slotted side of a small screw - but it is not a screw. This is the side that bulges up a bit to help the pin stay in place. I believe if you punch it out from the opposite side it will fall off quickly, but if you do from the bulged side it, too, will come out but with some resistance. To reattach the band you need to punch the pin into the slot in such a way that its bulged side is on top otherwise you may end up with a bent pin. You must also first line up the hole with the paper clip before reinserting the pin. Good luck.
Nov 06, 2007 | Kenneth Cole KC3289 Wrist Watch
JCPenney Armitron Sport Link Bracelet Watch Logo
258 people viewed this question
Top JCPenney Watches Experts
Ansel Alberto
Ansel Alberto
Are you a JCPenney Watch Expert? Answer questions, earn points and help others
