Question about Dryers
Whirlpool Senseon Dryer-drum doesn't spin & stuck on sensing mode
2001 Whirlpool Senseon Dryer (Model GEX9868JQ0).
The dryer provides its 'Drying Status' which includes: Sensing, Wet, Damp, Drying/Cool Down. When the 'Start' button is pressed, the drying status remains on the 'Sensing' status. Meanwhile, the drum does not spin while in the 'Sensing' mode. The dryer has power but is not going to a drying status.
What could cause the dryer to remain in the 'Sensing' mode?
Why is the drum not spinning while in the 'Sensing' mode?
  • 4 more comments
  • bsr407 Feb 16, 2009
    Would a broken belt also cause the dryer to stay in Sensing mode?
    Thanks Ronnieh49! I will investigate the belt and see if that's it. I will follow up with the results.
  • Anonymous Mar 17, 2014
    whirlpool cabrio wed7300wx sensing fault
    Unit will not start. Power going to it. sensing FAULT
  • Anonymous Mar 22, 2014
    Dyer drum will not spin
  • Anonymous Mar 24, 2014
    Model wed9200sq0 goes into sensing mode but does not move to the next phase of the drying process. Any ideas Matt
    Genius:
  • 2,920 Answers
The belt on the drum could be broken
Posted on Feb 16, 2009
  • 1 more comment
  • Ronnie Houston Feb 16, 2009
    yes it could.if the drum cant turn then it wont do anything else but what its doing now
    ok just let me know
  • Richard Apr 24, 2013
    What is your solution?
Why does my whirlpool senseon dryer start when i disconnect the thermistor wire but then shuts off after a minute?
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.html
Apr 08, 2015 | Whirlpool Dryers
How can I check the control panel for my dryer, to make sure that is the problem?
Obviously it ain't drying the clothes. Maybe it ain't even running?
Or it could be working just for not too long. If it has auto sensing then the moisture sensing strips might be clogged with something that is preventing the dryer from sensing wetness.1753c2e.jpg That is easy, just windex them sensing strips. If they can't sense wetness then the control will shut down quickly and the clothes will be wet. Lets see what else the crystal ball has...I have some manuals HERE
Sep 19, 2010 | Whirlpool Dryers
I have a Whirlpool Gas Dryer LGR6646BI-12 the clothes feel warm but not hot and they are still damp
The Dryness Level allows adjustment of how damp or dry the clothes are at the end of the cycle.
  1. Make sure the correct Cycle has been selected for the type of fabric being dried.
  2. If the correct cycle is selected and the clothes are still coming out too damp, use the Auto Dry Level button (Kenmore) or Dryness Level button to increase the Dryness level.
  1. If the highest Dryness Level setting was selected and the clothes are still damp, the Customer Focused Drying Mode settings that are built into the machine can be adjusted.
Dryers come from the factory set to Drying Mode 1 (default). Drying Modes 2 and 3, include additional drying time.
Note: This change will affect ALL Auto Dry cycles.
  1. Machine MUST be in Standby mode before beginning. (Standby mode = Plugged in, Power off)
  1. To select drying modes, momentarily press the Auto Dry Level button (Kenmore) or Dryness Level button (Whirlpool) again. The dryer will beep, and the display will flash and show the next drying mode number.
  1. With the door open and the display flashing the desired drying mode number, press the Start button to save the drying mode and exit diagnostics.
  1. Press the Pause/Cancel key at any time to cancel changes and exit from this mode.
Hope this works............
May 01, 2010 | Dryers
Dryer turns on and rotates. However, does not dry clothes completely. Cycle signals wet,then damp,cool down and finally dry,but clothes are still wet. Sometimes the dryer works fine and completely dries...
This problem may be the result of a dirty lent filter which if clogged will short cycle the dryer and the clothes will still be damp when done. Also a dirty exhaust pipe (usally 4") will prevent the clothes from drying correctly. Make sure that the air is leaving the machine. To do this you have to go outside when the machine is running.
Mar 21, 2010 | Kenmore Dryers
Whirlpool Duet Dryer, Dampness sensing only partially working.
inside dryer there is 2 metal strips clean tham off with a eraser if that dont cure it make sure vent clean going out of your home if both are done and still does it depends on dryer if its a sencer are control board
Oct 03, 2009 | Whirlpool GEW9250 Electric Dryer
Dryer will not start
Check the following:
Is the power cord plugged in?
Has a fuse blown, or has circuit break er tripped?
Was a regular fuse used? Use a time-delay fuse.
Is the dryer door firmly closed?
Was the START button firmly pressed?
Is a cycle selected?
Mar 07, 2009 | Whirlpool LGV4634JQ Gas Dryer
GGW9200 Dryer Does Not Dry. Status Light goes immediately to Wet
if the heat is only staying on for a few seconds and cutting out the vent line could be clogged,pull out the dryer,remove the vent line from the back and start it,if the heat stays on the vent is blocked,this is the easiest thing to start with,if the vent is clogged you can try a leaf blower and blow the lint out of the vent line
Aug 06, 2017 | Whirlpool GGW9200L Gas Dryer
Need help
This is some basic info I could find on your dryer. I will need you Serial Number in order to determine the year it was produced. Please post back with comments and let me know.
Whirlpool Duet GEW9250P 7.0 Cu. Ft. Super Capacity 8 Cycle Front Load Electric Dryer With AccuDry Sensing System. Dry clothes in the time it takes to wash them. The dryers uses AccelerCare™ technology to work just as fast as the washer (Up to a 9 lb. load), giving you more time to enjoy all the good things you've worked hard to achieve.
AccuDry™ Sensing System - Monitor remaining moisture and automatically stop the cycle when the load is dry, with the AccuDry™ sensor. Reduce overdrying and save time and effort, by not having to return to the dryer to re-check progress.
Senseon™ Drying System - Moisture-sensing strips and temperature sensors inside the dryer drum monitor how fast the load is drying, how hot the air should be and when clothes are dry. The system automatically stops the cycle to help save time and prevent overdrying. Senseon™ technology safely dries clothes faster than it takes to wash them.
Wrinkle Shield™ Plus Feature (120 Minutes) - The Wrinkle Shield™ Plus option automatically tumbles the load without heat to help prevent wrinkles from forming.
Whirlpool brand offers an ergonomic solution for its front-load washers and dryers to help reduce bending, stooping, or arching. Based on your height and laundry room needs, optional 10 in. and 15.5 in. pedestals make loading, unloading, and filling the dispensers easier. The 15.5 in. pedestal doubles as a storage drawer with a convenient sliding shelf to support your laundry basket.
Item Features:
  • Super Capacity Plus - 7.0 Cu. Ft.
  • AccuDry™ Sensor
  • Senseon™ Drying System
  • 8 Automatic Cycles
  • Bulky Items Cycle
  • Adjustable End-of-Cycle Signal
  • Wrinkle Shield™ Plus Feature (120 Min.)
  • 5 Temperature Selections
  • Quiet Dry Plus Noise Reduction
  • Dry Rack
  • Reversible Side-Swing Door
  • Dryer Door Window
  • Reversible Side Swing Door
  • Electronic Controls
  • Front-Mounted Lint Screen
  • Interior Drum Light
  • 4-Way Venting
  • Porcelain SpillGuard™ Top
  • Optional Storage Pedestals Available
  • Stackable Installation with Matching Washer
  • Matches Duet® Washer
Specs:
  • Warranty: 1 Year Parts & Labor
  • Capacity: 7.0 Cu. Ft.
  • Dimensions (HxWxD): 38 in. x 27 in. x 31 1/2 in; Depth with Door Open - 51.5"
  • Construction: Front Access, Reversible Side-Swing Door Style, Powder Coat Drum Material, Dry Rack, Extra Large Front Mount Lint Screen, Power Cord & Venting Accessories, Stackable
  • Controls: Electronic Controls
  • Electrical Requirements: 30 Ampere, 120/240 Volts, 60 Hertz (1/second). AC-ONLY. USE COPPER WIRE ONLY. A FOUR-WIRE OR THREE-WIRE, SINGLE PHASE ELECTRICAL SUPPLY REQUIRED. A TIME-DELAY FUSE OR CIRCUIT BREAKER AND SEPARATE CIRCUIT IS RECOMMENDED.
You can get an owner's manual replacement for your dryer at laundrymanuals.com. I believe there is a membership fee for the website, however. I hope this info helps you.
Nov 23, 2007 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
1,377 people viewed this question
Top Dryers Experts
