Question about Envision 19" Widescreen Flat Panel LCD Monitor
My monitor shows blue
I can not work with this monitor . the monitor is not clear
  • 814 Answers
This is a problem with the backlight circuits either the lamps are going bad or the inverters. This will cause blue screens and loss of detail.The unit need to be tested and serviced in a service center. Hope this helps.
Posted on Apr 14, 2009
I have hp w1907 computer monitor. After window startup my screen go black, the monitor light is blue, so it's on. If I press the the monitor button off then back on.....the screen will show for a second...
x2 test monitor on other pc.
if its ok we fix pC>
if the pc drops the sync lines H/V the monitor goes to sleep mode.
and tells you that.
the old monitors 2004 have timer inside,
does the OSD menu button on front of monitor work
with PC on,? it must.
OSD = on screed display from monitor brain
if yes, makes sure any menu there has the sleep timer off.
if it has it.
this monitor is old older than 2010. and has CCFL backlamps then and older.
so use flash light to see if data is on the screen if yes.
then the CCFL tubes are bad or the HV card inside dead.
yup your your service manaual
advanced OSD page clearly show the power saver clock
turn it off now.
of you cant get the OSD to work find a good PC
plug it in and turn this off below.
sevice manual google is your friend, sometimes.
Sep 11, 2017 | HP f1905 19" Flat Panel LCD Monitor
Inherited Compaq FS740 but after hooking up monitor will show green for a short time and then color is yellow? Is it dead? Has set up for a while
Check the pins on the cables. Single color presentation but clear picture indicates the pin for a particular color is borken on teh cable. Remember Red Green and Blue are mixed to make other colors. If you have predominantly one color then its due to cable not haveing all pins inserted properly or damaged.
Jun 28, 2010 | Compaq fs740 17" CRT Monitor
Blue on indicator light not working
If turned on and working good, just the indicator light that does not show.
This indicates that the indicator bulb is bad or burnt.
All you need to do is to replace the indicator bulb of your monitor.
Take care.
Apr 25, 2010 | LG Flatron L1919S LCD Monitor
Hello My PC monitor/CRT 17 inch. not getting
check the signal cable bend it in on condition and look what difference in color occurs if so then replace the cable if not that fault then ther is a dry solder on the base of monitor find out and clear it
Apr 05, 2010 | Samsung SyncMaster 753S 17" CRT Monitor
Normal screen is white background, but lately I am getting a blue tint that clears up sometimes and sometimes not. Please advise
Try hooking up another knowng working monitor to the computer and see if the blue tint comes back intermittently.
If it still comes up then you know your video card is the culprit. If the blue tint goes away then you know the original monitor is bad.
Aug 04, 2009 | Samsung Syncmaster 730B 17" Flat Panel LCD...
Acer aspire one second display monitor blue
Look onto your keyboard. There is a key that looks like 2 oval one shaded the other clear. Press FN and that key with the symbol on it. It will turn off your LCD and put it into the other. Then hit it again, both screens will have power, but slightly dim, press it once more to turn it off.
Good Luck
Jun 18, 2009 | Acer Computers & Internet
Blue hue on screen
Try a different known working monitor on the vga port of your laptop. If the replacement monitor works then you definitely know its a problem with your original monitor. If the replacement monitor shows the same blue hue then you know the vga port is bad on the laptop which would mean replacing the motherboard since its connected to the laptop.
May 30, 2009 | Acer AL2016W 20" LCD Monitor
I have an Advent 7115 & it was working perfectly yesterday & i transferred lots of work onto it, today the screen wont come on?? Any Ideas?
FN+F1-10 key.
One of them should have a picture of a clear and blue monitor on that. Which ever key that is press it after pressing and holding FN. It also might show a positive and negitave a on it. Remeber all these symobls and FN key are blue.
Jul 18, 2008 | Computers & Internet
CRT Monitor Not displaying blue components
Your moniter's video circuit is faulty .
Jul 08, 2008 | Gateway FPD2275W LCD Monitor
Monitor is not clear and no sound (win 98) pentium 2 board
Your problems sounds like you are missing the drivers, can you provide the model number of your motherboard.
or you can go to
and download the correct drivers for your motherboard
Dec 27, 2007 | Intel Motherboard
Envision 19" Widescreen Flat Panel LCD Monitor Logo
88 people viewed this question
Top Envision Computers & Internet Experts
Martin Murray
Dimitar Todorov
Are you an Envision Computer and Internet Expert? Answer questions, earn points and help others
