Question about Acer AL1914B Black 19 in LCD Monitor
Acer AL1914 black screen, green light
When I turn on my computer I can see the normal boot screen for a few seconds then it turns black with the green light still on. After that I can see the windows logo with the loading bar, and again it turns black with the green light still on. Then it finally goes to the log in or "welcome" screen, but it goes black with the green light still on before I get a chance to log in.
I tried using a different monitor (Acer AL 1717) and it worked just fine. I never had any problems with my 1914 prior to starting my computer with the system restore disk. Is there any possible way to fix my monitor without getting it serviced?
  • Anonymous Feb 16, 2009
    You may be right gymowner but I can not figure out how to install the driver. I downloaded it from the Acer website but I can not figure out what to do with the .zip contents (.icm and a .inf extensions)
  • Anonymous Feb 21, 2009
    Same thing, anybody know what to do? Or, should I just buy another one?
  • 679 Answers
It sounds like a deleted driver? try getting the driver for the monitor, did you loose the Operating system at some point, if so try a system restore to a date when the computer was working properlly prior to the malfunction. It sounds like it restored you to a time before the driver for that monitor was installed.
Posted on Feb 16, 2009
My Acer Aspire V5-571 does not load up it shows acer screen when turning on the laptop then loading floating ball comes on screen for a few seconds then black screen ? can any one please help ?
Hi Jim,
this seems like a no boot / no video kind off issue and mostly is coz of corruptions in softwares or drivers, try booting the computer in safe mode. if it does, then take a data backup. i would not recommend experimenting in this issue as it can crash the computer.
hence call 1-877-805-1027 for expert help.
Aug 18, 2015 | Acer Aspire V5 571-6614 : 1.6GHz Core i5 ,...
I unplugged my Acer al1914 monitor from my computer and plugged a different acer al1914 in my computer and now when I transfer the screen from notebook to monitor it has a blue tint on the entire screen. I...
Check the color settings in the on-screen menu. You can choose between "Warm", "Cool" and "User". Maybe you used the "Warm" setting before and somehow it got changed to "Cool".
If this is not the case, you can try the "User" mode and reduce the intensity of the blue channel.
If even black areas show a blue tint, maybe running an auto configuration from the menu helps.
As a last resort, use the "Reset" menu item which resets all settings to factory defaults.
Mar 30, 2010 | Acer AL1914 19" LCD Monitor
Monitor Acer Al 1914, no signal
Check your connections to the PC. Make sure that they are nice and secure. If there is a resolution problem setting it should display the boot process and then go blank after starting the operating system.
Oct 28, 2009 | Acer AL1914 19" LCD Monitor
The screen goes black ACER Aspire
I have the same problem with my Acer 5684 laptop. Just bought display backup light (CCFL) from ebay. Hopefuly will arrive within next 5-10 days. I will let you know if this solves it.
Sep 30, 2009 | Acer AL1914 19" LCD Monitor
Monitor problems
The power supply has probbably blown. Not repairable by unskilled labour unless you would like to check the fuse which is a little round black item near the area where you plug the unit into mains. be careful when removing the back cover. first the screws then it unclipps from the grey front frame. do not put pressure on the screen itself. It may damage. Good luck, Kind Regards Justin (Justronics S.A.)
Sep 11, 2007 | Acer AL1914 19" LCD Monitor
Monitor sleeps after one second
Try connecting the wires properly. try changing the VGA cable. i had the same problem my screen goes black some times and pink i changed the VGA cable it was absolutely fine!!!
What is VGA cable
VGA Cables Adapters Converters and Devices C2G
visit a computer mechanic for further trobleshooting
Mar 17, 2017 | AcerView F51 15 in. Flat Panel LCD Monitor
Computers & Internet Logo
401 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
