Question about Canon Pixma MP500 All-In-One InkJet Printer
Paper in the main tray catches and then tries to go into the printer diagonally. I switched the button to the paper tray in front but usually it defaults back to the main tray.
  • Canon Master
  • 419 Answers
It's most like that there's something stuck (such as a bit of paper) that's causing the paper to skew like this so first port of call is to try and check the printer over for any errant blockages like this from all angles...
The paper tray path from the bottom is tricky to get to but it is possible and you'll probably need someone to carefully hold the printer on it's front while you examine behind the green flap. Whatever you do, don't pull on anything or you could break things.
As a work around though, the other tray can be defaulted to by doing the paper selection on the front as you already are but also on your computer(s) but selecting:
  1. START
  2. Printers & Faxes
  3. right click on [MP500 printer]
  4. Choose "Printing preferences"
  5. Setup the Paper source to use the "Auto Sheet Feeder" rather than cassette.
If you're using the printer via a machine that's sharing it you can default new machine connections by doing the same thing on the sharing machine except you get to printer preferences via:
  1. START
  2. Printers & Faxes
  3. Right click and choose "Properties"
  4. Choose the "Advanced" tab
  5. Click on "Printing Defaults"
  6. ... from here on in it's as above setting paper source, etc...
Hope that helps...
Posted on Feb 17, 2009
MP530 - paper not feeding. don't see a 'slot' or 'guide' where paper should go
samaddar07.jpg The above pictures show how to open and set the Pixma 530 printer and also where to set the papers.The paper tray is in the upper panel, when you open the panel it becomes the paper tray as shown in fig.
Mar 31, 2011 | Canon PIXMA MP530 All-In-One InkJet...
IMy wife pulled the paper tray completely out of
Loading your paper
Paper loading tips:
● Load paper with the side to be printed facing down.
● You can print photos and documents on a wide variety of paper sizes, from
8 x 13 cm (3 x 5 inch) up to 22 x 61 cm (8.5 x 24 inch). The 10 x 15 cm
(4 x 6 inch) photo paper is available with and without tabs.
● Before loading paper, pull the Main paper tray out (use the Main tray release or
the tray grips) and slide out the paper-width and paper-length guides to make
room for the paper. After loading paper, adjust the guides to fit close to the edges
of the paper without bending the paper. When finished loading paper, push the
Main tray back in all the way.
● Load only one type and size of paper at a time in the same tray.
● After loading paper, extend the Output tray extension to catch your printed pages.
Use the directions in the following table to load the most commonly used paper sizes
into the printer.
Paper type How to load Tray to load
Any supported
photo or plain
paper media
1. Extend the Main tray by
pulling it out with the Main
tray release or the tray
grips.
Load the Main tray
Chapter 2
(continued)
12 HP Photosmart 8200 series
2. Slide the paper-width and
their outermost positions.
3. Load paper with the side
Check that the stack of
paper is no higher than
the top of the paperlength
guide.
4. Adjust the paper-width
inward until they stop at
the edges of the paper.
5. Push in the Main tray all
the way in.
6. Make sure the light on the
Photo tray button is
turned off to enable
printing from the Main tray.
Load paper and adjust guides inward
1 Paper-width guide
2 Paper-length guide
1 Push the Main tray all the way in
Aug 03, 2010 | HP Photosmart 8250 InkJet Printer
Printer not catching paper
You may have to clean the pick up rollers with alcohol or put a new roller in your printer.
If you have a printer with a tray, make sure it is set correctly for the paper you have installed.
It will try to grab the paper a number of times and will usually give you a paper jam error after a number of tries.
Jul 13, 2010 | Dell 922 All-In-One InkJet Printer
The printer won't print, it's trying to pick up the paper inside
Pull out the paper tray, at the front of the tray, there's a translucent roller in the middle. Remove the roller and clean out any waste paper dust inside & wipe clean the roller before putting it back.
Dec 10, 2009 | Brother HL-2040 Laser Printer
Machine says there is a paper jam when there is no jam. Shows jam in exit but the paper never even starts to get picked up from the main paper cassette but it will feed fine frome the mp tray. any...
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Dec 08, 2009 | Samsung SCX-6320F All-In-One Laser Printer
How, where do you load 11x17 paper for brothers mfc-5890n
It goes in your main paper tray. There's a button in the front of the tray to release a catch so you can extend the tray to 17 inches. See page 9 of your manual. If you don't have the book, download it free from www.brother-usa.com.
The scanner can only handle originals up to 8.5 inches wide. Only the printer can handle the big stuff.
Nov 21, 2009 | Brother MFC-5840CN All-In-One InkJet...
Paper jams using nextech premium photo pape gloss finish
  1. Before you do anything else, turn the printer off and on by following these steps:
    1. Turn off the printer by pressing the Power button.
    2. If the optional HP Photosmart Internal Battery is not installed in the printer, unplug the printer power cord. Wait about 10 seconds, then plug the power cord back in.
    3. If the optional HP Photosmart Internal Battery is installed in the printer, unplug the printer power cord, if it is plugged in. Open the battery compartment cover and remove the battery. Wait about 10 seconds, then reinstall the battery. If desired, plug in the power cord.
    4. Turn on the printer. The printer checks for paper in the paper path and will automatically eject the jammed paper. Press OK to continue.
    If the error still occurs, go on to the next step.
  2. If the paper came part way through the front of the printer, gently pull the paper towards you to remove it.
  3. If the paper did not come part way through the front of the printer, try removing it from the back of the printer:
    1. Remove the paper from the In tray, then push in the catches to release the in tray. Figure 1: In tray catches c00256377.jpg
    2. Open the In tray to a horizontal position.
    3. Gently pull the jammed paper to remove it from the back of the printer.
    4. Before you lift the In tray to close it, make sure it is pushed all the way to the right on its hinges. Figure 2: Pushing the tray to the right before closing c00256378.jpg
    5. Lift the In tray up until it snaps back into paper-loading position.
  4. Open and close the pen door on the front of the printer to make sure it is securely latched. Figure 3: Opening and closing the pen door c00269435.gif
How to avoid paper jams
  • Make sure that the cartridge door on the front of the printer is securely closed.
  • If you experience paper jams while printing, try loading one sheet of photo paper at a time. Insert the paper as far as it will go into the In tray.
  • Do not add paper while the unit is printing.
  • Do not use paper that is too thin, too slick, or that stretches.
  • Do not use torn or creased paper. Paper that has been printed previously may cause jams.
Aug 04, 2009 | HP Photosmart 375 InkJet Printer
Supply Rec. Paper tray will not clear even with a whole ****
Ok try this - switch the machine off at the mains, empty the paper tray. Push the paper tray back in and switch on the machine with no paper in it. When it's finished warming up it should tell you the tray is empty. Then put paper in. This will usually clear it.
Jan 24, 2009 | Canon imageCLASS MF5550 All-In-One Laser...
Brother printer problem
Manual Feed Command.
1. Press the Job Cancel button to cancel the print job. Delete the print
job in the print queue on the computer. You can quickly access the print queue by double clicking the Printer icon in the task
tray or dock.
2. Turn the printer power switch OFF on the right side of the printer.
Check that the front cover is closed.
3. Turn the printer power switch ON while holding down the GO button
until the Toner, Drum, and Paper LEDs are lit.
4. Release the GO button. All LEDs will be off.
5. Press the GO button 8 times. The green Status LED will flash briefly
while the printer is reset. After the printer is reset the Status LED
will be lit green.
6. Print the Print Settings by pressing the GO button three times. If
the Print Settings pages do not print and the Paper LED is on again skip
to the next section - No Paper in the Paper Cassette.
If the Print Settings pages print, the problem is isolated to printing
from your computer. The Paper Source of the Brother printer driver or
program you are printing from may be set to MP Tray or Manual, instead
of Auto Select, Tray 1, or Tray 2 (if the optional paper tray is
installed). To check the Paper Source setting of most programs, click
File and Page Setup or Page Layout. You may need to click the Paper
Source tab or Paper tab depending on your software application. Verify
that in the Paper Source section does not list MP Tray or Manual. Choose
Auto Select, or another relevant source such as Tray 1. Click OK. Try printing the document again.
No paper in the paper cassette.
1. Pull the paper tray completely out of the printer.
2. Insert the letter or legal size paper into the paper tray with the
top edge of the paper first and the print side down. Make sure that the
paper is flat in the tray and below the maximum paper mark. If using a
paper size other than letter or legal, the paper should be loaded in the
MP Tray. The MP Tray can print on paper from 2.75 in. by 4.57 in. up to8.5 in. by 16 in.
3. While pressing the blue paper-guide release lever, slide the paper
guides to fit the paper size. Make sure that the guides are firmly in
the slots. For legal size paper, press the lever located at the back of
the tray and pull out of the back of the open tray.
4. ReinstalI the paper cassette back into the printer. Press the GO
button. If the alarm clears, no further troubleshooting is needed. If
the alarm continues, follow the steps below.
Paper Jam at Paper Pick-up.
1. Turn the printer power switch OFF on the right side of the printer.
2. Remove the paper cassette from the printer.
3. Elevate the front of the printer slightly to locate the jammed
paper.
4. Gently remove the jammed paper.
5. ReinstalI the paper cassette back into the printer.
6. Turn the printer power switch ON. If the alarm clears, no further
Oct 02, 2008 | Brother HL-2040 Laser Printer
Canon Pixma MP500 All-In-One InkJet Printer Logo
48 people viewed this question
old marine
old marine
