Question about Rta International Patio Heater
I need a "dump switch" or "tilt switch" for my patio heater.
I was told by target that the heater originated from RTA International.
3 Suggested Answers
johnychel
  • 796 Answers
SOURCE: RTa iNTERNATIONAL propane patio heater
may be the pressure is not sufficient enough,,
check for the pipes...
Posted on Apr 13, 2008
  • 185 Answers
SOURCE: I have an RTA International
Gas Valves are not meant to be repaired only replaced. So I would have them replace the part and have them warranty there work. If the heater is very old and the replacement part is going to be half the cost of a new one You might want to put that Money on a new one and get a New manufactures warranty in the deal. Just another point of view....... Hope this helps
Posted on Feb 07, 2011
Can i bypass the dump switch on my patio heater
No, everything on it is there for a reason. If it blows up and shatters all your windows and fries your kids is that OK?
Feb 06, 2016 | Plumbing
Not getting any propain to my patio heater
First check the gas, connect the regulator to the cylinder but unclip the hose and do not light the heater. Turn the gas on for a second to see if the regulator is working OK. Next make sure there are no blockages in the pipes up to the burner. If all clear then vent the pipes to clear all air. If still not getting any gas the problem could be a faulty tilt switch cutting the gas supply or a worn thermocouple. Short out the tilt switch to test and if not fixed then change the thermocouple. Found this site very useful with tips patio heater problem solving.
Sep 01, 2011 | Rta International Patio Heater
Can establish pilot flame but cannot get main flame on my jumbuck tall patio heater. everything switches off. is it the tilt switch? how do I fix this
The first thing to wear out is a thermocouple, these will cause the pilot to go out when you turn to full. To check if the tilt switch is working just short it out by joining the leads up. Found this site very useful in solutions to Patio Heater Problems.
Jul 24, 2011 | Rta International Patio Heater
I have a RTA patio heater and on the box says it will work with LP or Propane but in the manual doesnt go into how to hook it or what needs to be done to LP connection can this be hooked into a home supply...
You didn't specify which model you have (Table Top or Tall Patio Heater). In any event, it doesn't matter, as LP and Propane are one in the same. However, it can not be converted to Natural Gas. Rita makes a separate Natural Gas model for that type of hookup.
Feb 10, 2011 | Rta International Patio Heater
I have an RTA International Patio Heater, Model 385.001 with a clogged pilot light valve. I need a way to fix the problem or a new replacement part. I have a commercial gas heating repair company working...
Feb 07, 2011 | Rta International Patio Heater
I have a propane patio heater that is not getting gas to the igniter how do i fix...
I've been told spiders can block outdoor gas lines,try to remove any blockage
Dec 11, 2010 | Rta International Patio Heater
GAS is to getting to ignitor for my patio heater model # 385.001
I assume you meant gas is not getting to the ignitor, take apart the head, if you are comfortable with it, and check for a blockage in the pilot assembly. If this does not fix the problem, try replacing the regulator.
Jun 24, 2009 | Rta International Patio Heater
Bad thermocouple in RTA International Pation Heater
try national energy they do spare s never worked on one fitted one , thermocouples are nornaly just two nuts sorry cant help much more
Jan 22, 2009 | Rta International Patio Heater
RTA International Patio Heater Won't Burn Properly
I would check the burner is not blocked and check the injector as well.
May 06, 2017 | Rta International Patio Heater With Table
Rta International Patio Heater Logo
1,032 people viewed this question
Top Rta International Heating & Cooling Experts
Mike
Steve Wood Plumbing...
Level 1 Expert
Paul Carew
Are you a Rta International Heating and Cooling Expert? Answer questions, earn points and help others
