Question about Ricoh Office Equipment & Supplies
Copier won't work
The copier turns on but will not make copies. The LCD display says U 6. The list of symbols does not have a translation for this problem. Please help me fix this. Also how can I obtain a manual for this copier. Thank you.
It's always more helpful if you include the exact model number of the machine; however I believe this only applies to some of the older analog units: U6 means that the fuser is not locked in properly.
If you're not sure where that is...inside front cover, brown handle on left hand side, held in (usually) by a blue lever on it's left.....give it a little shove, It was probably removed for a paper jam and never reseated properly.
I can email you a manual. advise me the proper model number (for example FT4522). You can get my info here:
Posted on Feb 17, 2009
Canon ir 2016j display scanning without printing
frist remove the Ram & then reinstall it if the problem presist then cross check the i.p board
Jan 03, 2013 | Canon iR 2016i Black and White Copier
I have a Toshiba estudio 202L copier. It has been working fine. When I turn it on, I hear it turning on like usual and see the light come on under the paper tray, there are no error messages, display...
try formatting the HDD (make sure you backup templates and address book if you use them.) To format HDD hold 0 and 8 while turning on the copier, when the machine comes ready key in 690 and hit start. It will then display "2 2", hit start again. Wait for it to say please reboot the machine, turn it off and back on. Hopefully this will work but if not, your HDD will need replacing.
Jun 14, 2011 | Toshiba e-Studio 202L Copier
How to change destination settings?
go to cod condition(# interrupt c interrupt) LCD turns off.enter 26 press copy enter 6 press copy enter 4
then copy.
May 20, 2010 | Sharp AR-5316 Advanced Digital Imager...
How do i change IP address for network printing
you mean the ip address of the copier?
it is under general settings key operator mode
here's how to do it:
1. set the machine to copy mode (ready to copy displayed on LCD)
2. press FUNCTION
3. press 1
4. press SET
5. press 9
6. press 000 (as a default key operator password)
7. press 1 and 9 ( 19 )
8. the tcp/ip mode will display
you may press clear to erase the current ip address;
just press the number that corresponds to your desired ip address and asterisk (*) corresponds to dot ( . ); after you input the new ip address dont forget to press SET to save the settings
that's it :)
Mar 30, 2010 | Panasonic Workio DP-1820E Copier
Sharp al 1631 not working properly
That is the drum replacement light reset it by pressing these keys: Clear, then the far left key, then Clear again then far left again.
So C, far left, C, far left
If done quickly like within 4 secomds the display should go blank. If so then key in 24 as if you were making 24 copies.
Now press the print button.
Now key in 7 and hit print again.
You should now be getting flashing zero's
Turn the machine off then on and the light should be gone and the copier is ready to use.
You can reset your drum life at least once with no problems.
Jan 05, 2010 | Sharp AL 1631 Copier
Canon Copier Key Panel Problem
Replace display touch control panel
Deshpande +919420906982
Oct 19, 2008 | Canon imageRUNNER 400S Copier
CANON iR C2105!! no display on the LCD!
try adjusting the contrast, open front door and look under the panel there should be an adjustment screw for the contrast, if it doesnt work I suspect it is the panel itself that is bad.
Sep 12, 2008 | Office Equipment & Supplies
An orange light blinking
you are absolutly right. It needs toner. That symbol is the universal symbol for toner. ( dont ask me how they came up with that but its true.)
The reason the copier runs on when you turn it off and on is because it thinks you may have added toner and is trying to auger toner out of the cartridge into the machine. After a time it gives up and assumes the cartridge is empty..
Jul 23, 2008 | Canon NP 7130 Black and White Copier
Copier wont work
true, the l error codes ar efor the laser l6-00 is the polygon motor, you should change this if you know how to, you need to take a lot apart
Oct 30, 2007 | Sharp AR-5320 Black and White Copier
112 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
