Question about Frigidaire 14 Cycle Tumble Action Washer
Frigidaire 2 way tumble action model number fwtr445rfs1 serial number xc91198120 Doesnt matter what cycle I run it seems to get stuck in between cycles and makes a little hmming noise.. I have to manualy advance it maybe 2-3 times a load
  • sha9ben Feb 16, 2009
    and where would this be? I am female sorry lol
  • sha9ben Feb 17, 2009
    No I have no manual, my machine has nothing on the front of it except a door I looked to the bottom and there is a part that you screw off would it be under that? and what am I looking for about the pump? ohh my thank you for your patients
  • 121 Answers
Check water filter on pump
Posted on Feb 16, 2009
  • dalibor skrbin
    dalibor skrbin Feb 16, 2009
    it must be on down left or right side of machine,on front.
    You must droop down to see it.Or if have manual reed it.
Washing machine spins to slow to drain all water
Your drain hose might be clogged. Disconnect it and try to run water through it.
Dec 01, 2012 | Frigidaire 14 Cycle Tumble Action Washer
HOW TO CLEAR THE LOC CODE ON MY FRIGIDAIRE WASHER
This means that the child lock (control lock) feature is active. There will be a button (or pair of buttons) depending on the model that you need to press and hold to toggle off the feature. If it is a single button, there will be a tiny padlock icon on the button. If you need to press and hold two buttons, the padlock symbol will be in a line indicating both buttons.
A likely combination is the Select and Option buttons. These should be held together for 10+ seconds. (This is the combination for some Affinity washers.)
If this doesn't work and you can't see a lock icon, please add a comment with the model number of your washer. I'll be glad to check what the combination is for your washer. The model number is usually on a plaque on the rim of the door for front loading washers or at the back at the top of the drum for a top loading washer.
I hope this helps.
(the control lock prevents someone from accidentally changing the cycle or a child starting a wash cycle with the cat or another child in the unit)
Nov 23, 2011 | Frigidaire 14 Cycle Tumble Action Washer
On my 6.3 yr old frigidaire front load washer (model GLTF1670ASO), the wash cycle does not dispense the water, but the rest of the cycle works fine. In other words, the washer tumbles dry clothes thr
sounds like the pressure switch is stuck its located inside the washer it has a small tube on it that is connected to the pressure chamber on the outer tub these block up with old soap ext and you have got to take the tube off and blow or unblock with a small wire
Nov 21, 2011 | Frigidaire GLTF1670A Front Load Washer
Frigidaire top load washer model number FWS6600ES0: during the wash and rinse cycles... whether it's filling or agitating on either... water seems to be draining causing the machine to stop and start...
If it has detected SUDs it may be trying to rid them. Is your drain hose at least 30 inchs above the floor? If is ain't then gravity may be causing the problem. Is the drain hose jammed tightly into the drain? This may cause a siphoning effect.
Oct 29, 2010 | Frigidaire FTF2140ES King Size Front-Load...
Frigidaire Tumble Action Washer buzzing door lock
you might have a damaged door lock mechanism.it might be jammed in the closed position,and should be changed
Feb 06, 2010 | Frigidaire 14 Cycle Tumble Action Washer
Questions about control panel-Frigidaire tumble washer
if you look in the internet you can download info and instruction free
by giving the right model
anyway ther are green cycke temperature cycles and others the temperature byt the lightest will go for about ann half hour and hottest to an hour and hour and half
try with first cycle and then all others if not sure with a rag that you do not need
ther can be cool cycles also
most machine are the same
try and go to a shop and ask as you want to buy one and if on auction as ebay ask other copy of manuals
Jul 16, 2009 | Frigidaire 14 Cycle Tumble Action Washer
I called in an electrician/plumber - thanks !
Jul 01, 2008 | Frigidaire 14 Cycle Tumble Action Washer
Frigidaire Gallery Front-loading Dryer Stops Tumbling
I have a stacking Frigidaire washer/dryer. The dryer will not start at all.
Thanks for any info you can offer.
Dec 23, 2007 | Frigidaire GLEH1642DS Front Load Stacked...
Frigidaire 14 Cycle Tumble Action Washer Logo
372 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
