Question about Transcend 4GB JetFlash 110 USB 2.0 Flash Drive (TS4GJF110) Media
Win98se doesn't recognize transcend jf v30 4gb device
I'm sure theres an answer. But I already wasted to much time on this issue. Any and all help is really appreciated.
Thanks Timeoff
  • timeoff Feb 18, 2009
    Thankyou very much.
    Deboo
    Scholar:
  • 77 Answers
Download unzip and install the Win98SE driver for JetFlash V30 frm transcend:
http://www.transcendusa.com/Support/DLCenter/Driver/JF_win98driver.zip
HTH,
Regards,
Deboo
Posted on Feb 17, 2009
Tip
Hi I have JF V30/8GB Transcend And my Computer suddenly doesn't recognize it....
FAULTY FLASH DRIVES
Sometimes when a flash memory stick or USB external hard drive fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory USB hard drive device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash or USB hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
You need to format the flash or external drive. Format the drive as primary drive and in FAT32. (FAT32 will allow data to be exchanged between MACs and PCs also between XP/Vista and earlier versions of Windows).
Otherwise format the USB flash drive in NTFS.
Insert the flash or external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Many people still don't realize this, but flash memory wears out the more you delete and write files to it. How quickly it wears out will depend on the specific flash drive. Like anything, there is a wide range of quality in currently available flash memory-based drives. You can make a rough correlation with the cost/quality of the device (what you pay is what you get), but even that tends to change over time. Depending on usage and quality it could be talking as short as months or as long as several years. In extreme cases of misuse it could lasting as little as a few weeks.
on Mar 08, 2011 | Electronics - Others
Hello friends, i have one Transcend JF v30/2GB Pen Drive. But when i insert Pendrive then i can't access that. It show the error for fromat the drive. Then i go for do that. Then it display error...
This might happen due to an error or corrupted MBR, which is the sector that allow you pen to be readable and the PC might not recognize the system file being used.
I would try to connect it to another PC with a different Operating system and format it from there.
alternative you can also use Transcend recovery tool. You can download from HERE
Sep 24, 2010 | Electronics - Others
Computer does not recognize Portable Harddrive
restart you system then plug it into different port if still not working then change the wire of ur hardrive...
Plz dont forget to rate
Sep 07, 2009 | Electronics - Others
USB flash drive un recognized -transcend JF v30/8GB. i have tried a couple of computers (VISTA/XP-sp2) same problem yet previosuly was working. can i recover the drive + data?
Have you tried to manually install the device? Do you see any changes on the screen when you insert the USB device? Do you see any lights on the Flash Device when it is inserted into the computer?
Ryan Frame
Creative Energy Associates Technical Center
Sep 03, 2009 | Transcend (589307) Media
Transcend JF v302GB doesn't work on Laptop
try on another usb port. this helps some times. U can check ur pen drive on another system. If it is not working there tehn get the pen drive replaced. If the pen drive is ok, reinstall ur o/s
Aug 12, 2009 | Electronics - Others
Transcend connection
For all of you who are unable to make USB drives work or still are getting the “USB Device not recognized”, try this method.
Download usbstor.inf and usbstor.pnf files (links are below) and copy them to
C:\ windows\inf  folder.
(click yes to overwrite the files if windows asks)
Remove the Unknown device from the Device Manager - Other Devices.
Inserted the USB drive and lo and behold! It should be recognized in a jify!
usbstor.inf and usbstor.pnf can be downloaded from here:
http://www.infdump.com/download-inf-files_new.php/inffiles/U/USBSTOR.INF/5.1.2600.0/download.html
http://www.pnfdump.com/download-pnf-files.php/pnffiles/U/usbstor.PNF/download.html
Hope this helps for everyone whose USB drives are still not recognized.
Regards,
Deboo
Jan 22, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Usb transcend not detected by the computer
If getting the “USB Device not recognized” error, try this method.
Download usbstor.inf and usbstor.pnf files and copy them to
Remove the Unknown device from the Device Manager - Other Devices. (Start -> Run then type devmgmt.msc  and press Enter)
Insert the USB drive and lo and behold! It should be recognized in a jify!
HTH,
Regards,
Deboo
Jan 09, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I want to install driver of jf v30/1gb on my system
I formats the pen drive but due to the electricity cut off, format doesn't complete and pen drive doesn't recognize in computer
Dec 27, 2008 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Transcend JF V30/2gb not working in VISTA. the messege is Application not found,
hello
i have transcend JFV30/2GB pen drive , but its not open in any comuter ,
Aug 11, 2008 | Electronics - Others
Electronics - Others Logo
706 people viewed this question
Top Transcend Electronics - Others Experts
laikexpert
laikexpert
Brian Sullivan
Brian Sullivan
Are you a Transcend Electronics - Other Expert? Answer questions, earn points and help others
