Question about IBM ThinkPad T42 Notebook
T42 only boots occasionally
When you attempt to power on, the system won't boot. Every once in awhile, it does boot and works normally. Problem is that its booting less and less often - there are some light changes when you attempt to boot, so doubt the power button is at fault. When it doesn't work, have to remove power plug and battery to reset. Anyone know what may be wrong?
  • IBM Master
  • 3,051 Answers
Hi there
have u tried to do a system restore on it ? back to a week before you noticed this happening also you may want to try to run sfc.ece to scan the registry for any problems .
Posted on Feb 16, 2009
  • 265 Answers
Sound like the bios battery might not be charging, try changing this, its located on the motherboard.
you will have to refer to user manual if out of warrenty
Dell inspiron 1300 won't boot
If you want to keep your important data, use some softwares can solve thewindows won't startproblem most quickly, and no data will lose. Besides, it is very easy, even the people who lack of computer knowledge can deal with windows won't boot issue.
Sep 21, 2012 | Dell Computers & Internet
Compaq presario 56000cl won't boot up / red light flashing in the back.
When you press the power button do you hear the fan running, hear the disk drive running, see any lights, do you hear the cd drive click once and see the light come on briefly on the cd drive door? If you see all the aforementioned then it is surely trying to boot. Computers don't boot mainly because of the following problems. 1) Bad Power Cord or Power Supply. 2) Electro Static Buildup. 3) Bad Motherboard 4) Bad boot or system files.
Remove the Power Cord and the battery if it's a laptop. Press and Hold the Power Button for 30 Seconds. Then replace only the Power Cord and try hitting the Power Button. If it boots you had an Electro Static Buildup. If you have boot or system files that are missing or corrupt normally the system will be telling you that on an error message that appears on the screen. Does your system show you anything on the screen when you press the Power Button? If not you have a Power Supply or Motherboard issue.
Mar 18, 2012 | Compaq Computers & Internet
Laptop boots up fine but will get a black screen after about 5 minutes of use and won't reboot normal after that for awhile
I fixed a similar problem by doing the following. With your computer on and plugged in, remove the battery. Then press the power button to do a cold boot. Once it's off unplug it and wait about a miniute then plug it back in and restart it w/o the battery in it. Once it is re-booted reinstall the battery. Hope this helps.
May 21, 2010 | HP Compaq nx5000 Notebook
My laptop will not boot - Operating System Not Found, cannot enter BIOS system - nothing at all. When I try to access the BIOS, the key keeps beeping. It is a Type 2373. Thank You -- IMCND
How are you attempting to enter the setup (BIOS)? Here are the steps:
Press the blue Access IBM button when the message "To interrupt normal startup, press the blue Access IBM button" is displayed to enter the ThinkVantage Productivity Center, then select Start setup utility to open the BIOS Setup Utility.
Feb 18, 2010 | IBM ThinkPad T42 Notebook
My previously healthy Thinkpad T42, will not post.
The Thinkpad T42 doesn't have a reset button on it like the older IBM's used to.
There could be a problem with the battery. With the machine turned off remove AC power and then the battery. Plug in AC power again and see if the laptop will boot without the battery.
If it boots let it load up as normal and then shut it down again, reinsert the battery and try to boot it up. If it boots fine, if not then there is a problem with the battery.
Please post back if you need anymore advice.
Good luck.
Jan 14, 2010 | IBM ThinkPad T42 Notebook
IBM thinkpad t42 boot up problem.
The sympton is rather vague, but I suggest the following options, to be followed one by one, until one of them works for you.
1) Boot your system in Safe Mode (if Windows is your OS) by pressing F8 after the usual "beep" provided by the BIOS after it detects all is fine. If it boots up, which takes a little longer than usual, then your system is probably Ok, although it may have a configuration problem.
Reboot the machine from the shut down menu and hopefully it will work Ok. If not, then, depending on whether you have Windows Vista (or better), try:
2) Boot again pressing the F8 key, but this time locate the option that reads something like "Last known good configuration". Highlight it with the arrow keys and press Enter.
If you have System Restore set on your drive(s) your laptop should boot up normally.
3) The last option would be for you to go into your system BIOS and run at least a HD detection test, followed by a memory test, etc., but I would only recommend doing this if you know what you're doing. If not, ask a friend for help.
Aug 17, 2009 | IBM Thinkpad T40 Thinkpad T41 Thinkpad T42...
Wireless N PC Card connection issue on Think Pad T42 after bootup
Hi
Please scan your system with proper anti-virus & don't use trendnet wireless software always use windows setting
Harry
Jul 14, 2009 | IBM ThinkPad T42 Laptop
System won't boot - show's green battery icon only
Contact with notebook repairing engineer. Might be coz of some short circuit, BIOS corruption or any malfunction of the hardware.
Regards;
Hassan
Jul 07, 2009 | IBM ThinkPad T42 Notebook
IBM A31 2652 Video garbled video at boot
This is very possibly a hardware problem, namely a crack in the motherboard. Sorry, no easy or cheap fix for it if that's the case.
Feb 18, 2009 | IBM ThinkPad T42 Notebook
IBM ThinkPad T42 Notebook Logo
118 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
