Question about Bosch Power Tools Sanders Orbital Sanders
  • David Ford
    David Ford May 11, 2010
    K lets start from the beginning what is not running as well the rotation or is the motor running slower than usual. And by bushings do you mean the bearings? Please let me know with a model number and I will try and help
  • 86 Answers
It's usually not the brushes but the commutator that needs cleaned. The commutator is the surface the brushes ride on. Go to Walgreens and buy a multi-surface nail file, one of the soft ones that are about 3/4" square with different colors for different grits. Don't start at the coarse grit!! Start at the medium grit and lightly drag it over each section in a smooth arcing motion, when the commutator surface is shiny it's clean, then replace the brushes with new ones.
Posted on Mar 01, 2009
How to stop the sand paper coming off my bosch psb75a belt sander?
The rubber compound on the drive roller is missing and is smooth hard plastic ??? replace the drive roller or your bushings are worn is the front rol not bent by a fall?
Nov 07, 2015 | Bosch Tools & Hardware - Others
I have a sander in good condition apart from the two rubber bushes which have perished. I seem unable to get replacements for these. Can anyone provide a source. Regards Chris
What kind of sander. You can't expect an answer to such a generic question. The more details you provide, the better the answer you will receive.
Mar 25, 2015 | Sander Tools & Hardware - Others
Ihave replaced the brushes on my 9404 belt sander and it is running as if it still needs the brushes changing. Any ideaS?
If there is excess sparking from the brushes then the armature is shorted. Also a bad field can make a tool run slow.
Aug 07, 2012 | Makita 9404 4'' x 24'' Belt Sander
The pad between the bottom plate and sanding belt is worn, torn, and folded/disfigured on one corner. What is it's function and where can I get a replacement?
That pad is usually made of cork or graphite It's used to give the back side of the sanding belt a soft and slippery surface to run on so it won't over heat/tear and fail. The part you need is P/N 2601098037 Any Bosch service center will be able to get one for you. Go to and look under "find a service center"
Feb 01, 2010 | Bosch 1274DVS 3" x 21" Belt Sander
My bush mp3 doesnt isnt working and if i plug it in computer it doesnt show any devices?
i have a similar problem, i've e-mailed tech support because i cant find the receipt or box to return for replacement, but am waiting for a reply..... since then i have lifted the top perspex to expose the screws, taken it apart and found after putting across my tester that the small printed circuit board attached to the battery is at fault.
i,ll let you know the best course of action once i've worked out what's next or if bush tech support get back to me.
kind regards. Wayne.
Nov 07, 2009 | Bosch Audio Players & Recorders
Bosch 3 x 21 Belt Sander
Remove the dust bag and unplug sander for now. Everywhere you see an access hole (fan area, dust port, back of sander blow thru the tool to remove lodged dust that clogged the system, Also look for broken belt pieces in the back of sander. Then while running (remove belt) blow again thru all the ports to try and reomve as much contamination as possible. When finished you can feel to see if air coming from dust bag port, it not you still have a clog that might need more work. If I have clarified your request would you please rate this response accordingly and thank you.
Sep 10, 2009 | Bosch 1274DVS 3" x 21" Belt Sander
Bosch ROS not powering on
Checked the net for answers and got a couple of maybe's. 1.) Brushes, 2.) variable speed control, which some were direct wiring.
I tried the brushes firs and that has solved the problem for now. I guess the brushes stuck or somehow lost contact.
I got a parts diagram and found the brushes (will be covered with dust). Took the springs out and stretched them a little, replaced and the sander turned on. You will need to remove the top cover to do this. Verdit is still out as to long term performance. Not a great start.
My particular sander was lightly used (second project) and it has not been abused.
Jul 11, 2009 | Bosch 1295DVS 5" Palm Variable Speed...
Dryersmells smokey/hot.
Lint buildup inside the unit can cause all kinds of problems. Have it taken apart for a good cleaning and inspection. A dryer fire is no fun.
Apr 07, 2009 | Bosch Nexxt WTMC 3300 Electric Dryer
Bosch Power Tools Sanders Orbital Sanders Logo
292 people viewed this question
Top Bosch Tools & Hardware - Others Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Bosch Tool and Hardware - Other Expert? Answer questions, earn points and help others
