Question about Miele K8452S Refrigerator
Termostat do not work properly the frige tun to a freezer
  • 30 Answers
Check Thermister bulb is properly attached to the Coil or Replace Specific Thermostate will be ok
Good Luck
Posted on Feb 16, 2009
  • Rizwan Noori Feb 16, 2009
    when solve pls let me know
    THX
Frige not cooling on bottom freezer frige
Check the air vents, from the freezer to fridge. Air travels through those vents. Sometimes, products get shoved under the vents, preventing air flow. It sounds like, the vents are clogged with something. I guess, the fan is working inside, of the freezer? Ice in the bottom, of the freezer pan, could be clogging the vents. You'll have to dig deeper. Good luck.
Aug 16, 2014 | Kenmore Refrigerators
Hot door seal
Hi
There could be few reasons for your problem….
If your refrigerator is running too long or more than normal:
You may need to clean the condenser coils. This should be done about every 6 to 12 months. You can use a condenser cleaning brush, this comes in handy for cleaning hard to reach areas. Your refrigerator may be running too long, check the door gaskets for proper sealing, especially the bottom section. Clean the gasket surface where your door gaskets meets the metal with warm soapy water.
However there is a part of the condenser called the mullion loop that adds heat to keep moisture from building up and causing the door gaskets to stick. If it's too hot to the touch, first check your frige and freezer temps. You'll obviously know if the frige is too cold, but you may not know if the freezer is too cold. The freezer should be between 5-10 deg above zero. Any colder and the frige will have to work harder and would create more heat. Also check the condenser coils. If they are dirty it will prevent the frige from removing the heat properly. The condenser should be cleaned at least annually. Most friges have a condenser fan motor. Make sure the motor is running and the fan blades are clean. Most frdiges also have a cardboard type panel on the back at the bottom. That panel directs the air flow across the condenser and must be in place. If it's missing or damaged its need to be replaced.
Let us know if you have something more to ask else please accept the solution.
Thanks for contacting fixya.com
Sep 01, 2010 | Whirlpool Refrigerators
Our freezer seems to be working fine, however, the fridge part doesn't seem to be cool at all
all you have to do is defrost the frige the freezer sometimes will freeze up with ice in the back of freezer where the air flows into frige
Mar 13, 2010 | Haier HTE18WAA Top Freezer Refrigerator
Whirlpool Wrn38rwg6 frige has decided to not cool properly
My first thought is it defrosting? Look into rear of the freezer and see if ice is building up on rear wall of freezer. If yes manually defrost and let me know what you find. If no I would want you to feel compressor for overheating or look and see if a fan has stopped working while compressor is running. Sea Breeze
Feb 20, 2010 | Refrigerators
Frige freezing solid
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jul 03, 2009 | Samsung RB2155 Bottom Freezer Refrigerator
Frige
check to see if the air chamber between freezer and frige is not blocked with ice or something else
Apr 13, 2009 | Kenmore 64812 / 64814 Top Freezer...
Freezer side cold, frige side warm
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
Nov 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
My freezer is working but my frige is not cooling
wrong model # ,defrost problem. remove freezer panel, check heater, check limit switch while still covered in ice, if both ohm infinity, replace defrost timer.
Sep 15, 2008 | Haier HTP18GAA Top Freezer Refrigerator
Refrigerator getting hot!
There is a part of the condenser called the mullion loop that adds heat to keep moisture from building up and causing the door gaskets to stick. If it's too hot to the touch, first check your frige and freezer temps. You'll obviously know if the frige is too cold, but you may not know if the freezer is too cold. The freezer should be between 5-10 deg ABOVE zero. Any colder and the frige will have to work harder and would create more heat. Also check the condenser coils. If they are dirty it will prevent the frige from removing the heat properly. The condenser should be cleaned at least annually. Most friges have a condenser fan motor. Make sure the motor is running and the fan blades are clean. Most friges also have a cardboard type panel on the back at the bottom. That panel directs the air flow across the condenser and must be in place. If it's missing or damaged it will need replaced.
Jul 20, 2008 | Refrigerators
Miele K8452S Refrigerator Logo
218 people viewed this question
Top Miele Refrigerators Experts
Starnley Johnwells
Starnley Johnwells
Oloyede Monsuru
Are you a Miele Refrigerator Expert? Answer questions, earn points and help others
