Question about Hitachi 60SBX78B 60" Rear Projection Television
Digital tv does my tv have a digital tuner? a 60 inch hatachi progection tv 9 years old.
  • 4,234 Answers
You myust understand the difference between a digital tuner and a tuner that tunes digital signals. Given the age of your set, the tuner is in fact digital (tunes using numbers not a dial) and tunes NTSC analog broadcast signals. The changeover to "digital" is in reference to the broadcast signals which will now be ATSC or digital format. Your tuner WILL NOT tune to these signals. If you have cable or satellite, you will not be effected as those signals will be received by your tuner. The changeover only affects ovfer air reception (rabbit ears or antennas).
Hope this helps,
Dan
Posted on Feb 17, 2009
  • Hitachi Master
  • 5,138 Answers
Unless it says HDTV it is not digital.
Posted on Feb 16, 2009
I was just given a 36-inch RCA Gemstar Guideplus Gold TV. I do not have cable and am unable to tell if it is digital or not. I've been told it is less than 6 years old. It is a tube TV.
RCA made only two 36" televisions between 2004 - 2010 and neither one of them have digital (ATSC) tuners. They made ZERO CRT televisions before that with digital tuners.
Apr 23, 2011 | Televison & Video
Sanyo lcd-32k40 features
  • Model: Sanyo 32K40 Multi System LCD TV
  • World-Wide NTSC/PAL/SECAM Color System - Watch any video signal on this TV!!
  • World-Wide NTSC M, PAL BG, PAL I, Secam BG, DK/ PAL DK TV tuners
  • 32 inch LCD TV with 3 HDMI inputs and PC input
  • USB input for direct media playback
  • 45,000:1 Dynamic Contrast: While viewing either very bright or very dark scenes, it can be difficult to distinguish main images which blend into the background.
  • Dynamic Contrast dramatically mitigates this problem by adjusting the backlight intensity, providing up to a 4X improvement in contrast.
  • 6.5ms Response Time
  • Widescreen 16 X 9 Format
  • World-wide Dual Voltage 110-240 volts 50-60 hertz
  • HDTV monitor (HDTV tuner required for HD reception)
  • This is a multisystem TV. All Multi System TVs in the market do not have a digital TV tuner: What does this mean?
  • To watch digital channels (ATSC Broadcasting in US and DVBT broadcasting overseas) you need a digital source/tuner like a cable box, digital tuner, satellite service, etc.
  • To get the best quality video on this TV you need a source that has a digital connection like HDMI or component.
  • Wide Screen Mode allows you to watch conventional 4:3 aspect ratio broadcasts in wide screen (16:9) mode.
  • Steady Sound® equalizes volume levels so there is consistent output between programs and commercials.
  • Built-in hidden speakers includes 2 (5W x 2) speakers to deliver dynamic sound.
  • Component Video Input offers the best video quality for DVD (480p and 480i), and digital set-top box (1080p, 1080i, 720p, 480p and 480i) connections.
  • PC Input allows you to connect your PC and display the PC screen on your TV.
  • Surround Sound Audio Effect
Mar 04, 2011 | Sanyo 42 in. LCD TV
Wich video format supported
Released 2 years ago Included Units Stand-Alone Monitor, Amplifier
Supported Audio Formats MP3, WMA
TV Tuner Without TV Tuner
Radio Tuner AM, FM, Satellite, XM Ready
Aspect Ratio 16:9
Input Connectors AV x 1
MPN MAX685BT
Monitor Size 7 inch
Output Connectors AV x 1
Power Per Channel 50 Watts x
Supported Media Types DVD Video, DVD+R, DVD+RW, CD-R, CD-RW
Supported Video Formats DVD, DivX
Dolby Digital / AC3
I found all of this at http://wize.com/car-dvd-players/p469604-clarion-max685bt
Good luck.
Hope this helps!
Jan 21, 2011 | Clarion MAX685BT Car DVD Player
How do i tune in a 3 year old philips hd flat screen tv it is 3 years old bought from a friend.
my philips 32 inch flat screen doesnt give me freeview anymore when i scroll down to digital tuner i just get a blue screen
May 08, 2010 | Philips 32PFL7332D 32 in. LCD HDTV
Is the sony trinitron 23 inch tv hd ready
You will need a model number before anyone can even do any research.
In general, there were never many CRT (picture tube) TVs made with the required ATSC tuner and if your set is 5+ years old, it isn't compatible with digital reception.
Oct 11, 2009 | Televison & Video
I have philips 55 inch progection 2002 model i cant get multipoint to ajust up and down it will go left and right the multipoint red works fine thank you
Its a convergence problem. You may want to check the site www.tvrepairkits.com. I fixed a philips 60 inch tv in 45 minutes, The convergence chips were bad! Thanks a million. You guys saved me 250.00 bucks. I'll be recommending you to everyone I know!
Aug 18, 2009 | Televison & Video
Can not get pip to work
Pip has its own tuner, try getting a cable splitter to split the signal into the tv. If you have digital cable you may need a second cable box to do this. If your cable provider still sends an analog signal the splitter will work.
Jul 10, 2009 | Toshiba 53H71 53 in. Rear Projection...
Audio on my GE television has went crazy
Well you going to need a new tuner! Let me tell you now that digital is out or is comming your not going to find the part!!! Well if this has RCA inputs your in luck you buy a digital box around $60 bucks then put the tuner on it and you in luck and you saved your TV!!
May 25, 2009 | GE 31GT660 TV
HATACHI IS OUT OF FOCUS
This can be a number for things. Believe it or not dust or cig smoke in LCD and pix tube projected TVs turns up looking a lot like focus error. Is the focus bad or do you have a convergence error (red, blue or green shading) Is there any smearing or blooming to the pix? The other comment for you is the TV is 9 years old I personally consider this very close to the life of the product. A simple good pix would tell volumns for someone like me (may need some resolution on the pix).
Apr 17, 2009 | Hitachi Televison & Video
I have a hatachi 60 rear projection tv, the cable port on the back of the tv is broken, i pulled the back off the tv and pulled off the silver box, the f-connector that goes to the incoming cable line, is...
This can be soldered back into the tuner if the board in the tuner is not broken. If you need a new connector any electronics supply store will carry it.
Apr 14, 2009 | Televison & Video
Televison & Video Logo
364 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
