Question about Ricoh Aficio 1035 Copier
SC322 on Ricoh Aficio 2035
Already changed laser unit, and still get same problem? Any other suggestions.
    Problem Solver:
  • 13 Answers
Forget the laser unit your developer is shot... machine cant detect vsp and vsg... therefore gives a laser error... replace developer run developer initialization in sp mode copy sp drum... should solve the problem
Posted on Mar 09, 2009
Did you replace entire unit? or just polygon motor? Code is related to the Laser synchronization detector board, and/or LD Unit. You must perform laser beam pitch adjustment after replacement (400 /600 dpi). SP2109-1 and 2109-2
Posted on Feb 17, 2009
Xerox 275, anyone know how to need to calibrate the control panel?
Posted on Jun 21, 2010
How do i clear code sc322 on nashua aficio 2016
Code SC322: Laser synchronization error
The main scan synchronization detector board cannot detect the laser synchronization signal for more than 5 consecutive 100 ms intervals.
Causes:
• Poor connection between the LD unit and the BICU board
• Damaged cable between BICU and LD unit
• LD unit out of position
• LD unit defective
• BICU board defective
Error Codes Ricoh Aficio 2016
Jan 04, 2015 | Office Equipment & Supplies
Sc 322 error
The first this I would do is remove the the front access door, and then the panel that is behind the access door to gain access to the laser unit. Most likely what you have is a bunch of toner and/or developer all over the laser sync board. Use a toner vacuum to clean this up, and your problem will most likely go away, unless there is something wrong with the board itself, but this is rarely the case. It's almost always buildup on the sync board.
Below are the details of the SC322.
SC322: 1st laser synchronization error
The 1st laser synchronization signal
cannot be detected by the main scan
synchronization detector board even if
the laser diodes are activated.
• Poor I/F harness connection between the laser synchronization detector board and the LD unit.
• Laser synchronization detector board out of position and angle of reflection not correct
• Laser synchronization detector board defective
• LD unit defective
If you don't know what any of this is, call a professional, as you could mess the MFC up even more by messing around with it.
Jun 13, 2013 | Ricoh Aficio 2035 Copier
Help fix error code sc690 on ricoh 2035 copier
SC690 - A GAVD block I2C bus error.
An error is detected in the GAVD communication I2C control register of the GABIC2.
• I2C bus on BICU defective.GAVD IS THE laser controller loacated on the laser unit.
Nov 01, 2011 | Ricoh Aficio 2035 Copier
Erro sc322
i told that many times 322 is laser unit is defeactive specialy sychro 1 defective try to replace laser unit
Jan 27, 2011 | Ricoh Aficio 2035 Copier
Ricoh Aficio 1035 gives ERROR CODE SC322. CANT TAKE ANY COPY OF IT, PLZ HELP
that mean laser unit have proplem synchro 1 can't detect do with me 2109 and 2108 via sp mode if it's not work out change it
Jan 14, 2011 | Ricoh Aficio 1035 Copier
Codigo sc-322-000 copier ricoh aficio 450
sc322 is an error generally caused by a component in the laser unit. However, sometimes a faulty door switch can cause this error as well. The switches in question are the three micro-switches that change state when the right door is opened or closed. They are located on the front right side of the copier, above the fusing unit and behind a plastic cover. If you can remove these switches and test them individually, you can probably find the faulty switch. If not, you can replace all three as a set and hopefully the sc322 error will go away (once you reset the machine).
If replacing the switches do not fix the error, then the problem lies somewhere in the laser unit, possibly with the polygon mirror motor, but your best bet is to replace the whole laser assembly if you can.
Hope that helps!
Oct 22, 2010 | Ricoh Aficio 450 Copier
Ricoh aficio 2035 sc 322 (unidad de lazer en buenas condiciones) ?que mas puede ser ¿
sc 322 is a laser unit problem. find a ricoh technician and clean the laser unit or replace it. this laser problem is hard to solve usually.
Sep 28, 2010 | Ricoh Aficio 450 Copier
After sc326-00 my copieur ricoh aficio 350 put on his screen sc322-00 and not work, how cold i resolve this problem
Laser Synchronization Error(1 & 2)(sc322 & sc326)
· Laser synchronization detector board out of position
· Laser synchronization detector board defective
Also check if any cables are loose and also if the laser unit is dirty.-Clean it.
Feb 09, 2010 | Ricoh Aficio 350e Printer
I need solution to aficio 200 error code sc322
sc322 is a Laser synchronization error:
Means that the laser synchronization signal cannot be detected by the main scan detector board.
Possible causes:
Poor connection of the interface harness which connects the laser synchronization detector board and the BiCU board.
Laser synchronization detector board out of position or is defective.
BiCU board is defective.
Unfortunately,unit needs service.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 19, 2009 | Ricoh Aficio 180 Laser Printer
Ricoh Aficio 1035 Copier Logo
1,981 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
