Question about Lexmark T630 Laser Printer
Prnter jam I had a printer jam and cleaned out the paper and still says printer jam when I try to print
  • maegc May 11, 2010
    What is the error code? Did the paper tear when you tried to remove it? Was there more than one paper jammed? Did the error code change after the inital jam was cleared?
  • 320 Answers
If you are getting a 202 error check the 2 sensors on the fuser for a broken or stuck sensor flag. make sure the flags move freely you should be able to hear these snap back. the one on the right is clearly visible the other is about 2 inches in on the left side of the fuser and is set in abut 1 inch under the exit roll assembly.
Posted on Dec 07, 2009
  • 610 Answers
Check in the fuser unit.
Posted on Dec 01, 2009
Paper jams on epsonXP605 expression printer
Printing photos from the back feed? Using special photo paper? Try cleaning the paper rollers that feed the paper. They get slick.
Sep 03, 2014 | Epson Expression XP- 605 Inkjet...
False paper jams and multi sheet feeds
multi feeds and jams are mostly caused by static electricity in the paper. ALWAYS fan paper top and bottom to remove static and "aerate" the paper before putting in prnter. Doing that will reduce the problems you are experiencing.
Please rate my help++++Thanks for using FIXYA
Oct 22, 2009 | HP Photosmart 8150 InkJet Printer
Epson cx3800 paper feed problem
no you might have a paper jam somewere and mabe you ink rollers are dry you might have to tell the printer to to a pre test and clean and if there is a paper jam it should be a slot on the back by the roller should be a tap that shows the tollers look for a pice of paper jammed somewere in the roller you migh have to take the paper out to inspct it for a paper jam and if none mabe the print heads are dry and it dosent feed the paper then could be it ok clean the print heads tell the printer to to a roller clean and then after that if no paper jam no were try printing a page take all the paper out and feed it manually and if it prints then some printer want feed if you have filled the paper tray up try putting less and then try
Jan 29, 2009 | Epson Stylus CX3800 Printer
Printer paused-unable to read
HI there,
1. First, clean your printer. Get some spray-n-wipe cleaner and a clean cloth and clean the entire inside of the printer. Also ensure your paper isn't dirty. Now print a test page. Does the symptom persist?
2. Remove all jammed paper. Check the paper tray first. Look closely at the paper rollers nearest where the paper exits the printer; this is a common source of jams. If you’re trying to print labels, they will often jam just before exiting the printer.
3. Try to print a test page. Does the printer still jam? If you can find no source of the jamming, check the printer's message display window and refer to your user’s manual to look up the printer error code.
Oct 04, 2008 | Brother HL-2070N Laser Printer
How to correct error 5100 in canon pixima ip 1800 prnter
Hi You can Try
If you still look at this web then have a go
Error Code 5100
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
Sep 27, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Paper Jam
Sep 16, 2008 | HP LaserJet 4mv Printer
Everytime I try to print to my PIXMA 9000 I get an error from the print spooler that the printer is not responding. THe print job starts to print, stalls after a few lines.
OR=
1. Check the printer and/or the software to see if "manual feed" is selected. If manual feed is selected, the printer may be looking for paper in another tray.
2. Reseat paper. Ensure printer is on-line. Check for paper jams or obstructions.
3. Likely suspect: paper-out sensor is damaged or broken. Consult a computer repair shop.
Sep 16, 2008 | Office Equipment & Supplies
Copier canon mf4150 says it has a paper jam, but there is no paper jam.
Image and text printed multiple times and are overlapping
Is the R1800 the only printer that you have on ythis mac?
If it is make sure it is directly connected to your mac via a USB or Firewire cable.
Trash epson folder from Mac HD-Library- Printers
Delete Epson printer utility from Mac HD- Application folder( if you have both delete both icon.
Under prnter setup utility delete the r1800 printer
Go to finder click on file the find, type com.apple.print, if it find anything drag it all on the trash, it will not disappear from the window ( the prefs and . cache files)
download the latest driver for your r1800 from epson website
epson12113.dmg - 10.3MB - posted on 12/20/
then reinstall it, after reinstalling try to readd th printer and make sure under print using it will say Epson SPR1800 series. If you see guten print/ that is a third party driver. dont use the gutenprint. then try to print, update me for the outcome
Apr 08, 2008 | Epson Stylus Photo R1800 InkJet Printer
Lexmark T630 Laser Printer Logo
452 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
