Question about Onkyo TX-DS787 Receiver
Internal battery on the Onkyo TX-DS747 RECEIVER
I found my internal battery on the Onkyo TX-DS747 receiver. The one terminal on the battery has corroded and I need a replacement.
I am based in South Africa and would like to know if anyone can assist with the specs of the battery.
I also have a problem when I turn on the amp. The speaker outputs keep on switching. (On and off on channel A) After a while this seem to rectify itself or sometimes I need to turn on the "A" speaker setting to get the sound. Any ideas on this?
Best regards
Willem
4 Suggested Answers
  • 103 Answers
SOURCE: fm tuner not workin in south africa
The unit will not outside the us.We have a different scan freq.
Posted on Mar 03, 2008
SOURCE: my onkyo tx ds747 is saying protect even if i dont
Hello
maybe you have defective power transistor output and this is shorted, or the problem is in the power section like shorted diode shorted capacitors or open circuit may cause this, and the STK IC if shorted you got protect warning..
Angel
Thansk...
Posted on Aug 02, 2009
hardrocko
  • 1476 Answers
SOURCE: I have an Onkyo TX-DS747 & everytime I turn
What it sounds like you are describing is the protection relay turning on then imediately turning off for the time period mentioned. That would indicate a possible short in the circuitry. Probably a capacitor that is intermittant or even a transistor about ready to fail. This is probably not something you can look for if you are not an electronic tech. Find a reputable shop and get it fixed before it quits and does more damage. Let me know how you make out.
hardrocko
Posted on Feb 03, 2010
  • 628 Answers
SOURCE: ONKYO TX-DS747 SWITCHES FROM A TO B SPEAKERS HOW
The problem could only be in the a/b switch, you may need to install a new switch.
Posted on Apr 06, 2010
What do I need to hook a HDTV up to an Onkyo TX-DS747 receiver
okay hello, you dont need a HDMI cable as it appears your receiver isnt equiped with that feature.The way you have to do this is if you have a source you run the video chord (yellow chord) then then left and right audio (red and white cable) run them from your souce such as satelite or dvd player or game console.you plug them into your input on your receiver then you run one video chord on the output port on your receiver this will put the sound through your receiver and put just the video to your tv.if your tv has a option to run audio out then you just reverse this pretty much.You run auudio left and right from the audio output on your tv to the input on your receiver.then on your menu on your tv make sure you go to speakers and set them to off and set it to output audio if this option is presented.
Mar 20, 2013 | Onkyo TX-DS747
Onkyo TX-DS777 does not retain settings after power loss
No internal battery, a large "SuperCap" on the main board acts as one. Look for C8007, 0.1 F, 5.5V.
Apr 26, 2010 | Onkyo TX-DS777
ONKYO TX-DS747 SWITCHES FROM A TO B SPEAKERS HOW DO I FIX IT
Apr 05, 2010 | Onkyo TX-DS747
I need a remote for tx-ds747
You can buy directly from onkyo website, Ebay or Do Google search.
Mar 23, 2010 | Onkyo TX-DS747
Left speakers are not working on my onkyo tx-ds575
Check the units internal "menu" settings for speakers and audio. beyond that, there would be an internal problem and neded service. Hope this helps
Jul 05, 2009 | Onkyo TX-DS575 Receiver
Water on board..ONKYO TX-DS797
i need this part. email me: eduardo@tomateverde.com
Jan 25, 2008 | Onkyo TX-DS797 Receiver
Onkyo TX-DS787 Receiver Logo
396 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Dennis McCollum
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
