Question about Micromark Refrigerators
Instructions my daughter bought me a new omelette express maker MM 9878 for Christmas a couple of years ago and I have never used it. Got it out of the cupboard to use today and find that although it is unopened there do not appear to be any instructions inside the box. Can you help? I am sure it is very simple but if there are a few pages I could down load it would be much appreciated.
  • Mark Egan May 11, 2010
    I do not have a manual, but using this appliance should be rather easy.
    First, each side can probably hold either 1 or 2 full egg omelettes.
    2nd, use any omelette recipe that you can find. I use 2 eggs and 2 teaspoons of water, salt, pepper. Add any other toppings you would want included (make sure the toppings are all precooked.).
    Heat the MM 9878 for at least 5 minutes before pouring egg mixture in. There may be a light on it just like that found on a waffle maker.
    Experience will dictate how long to cook for.
    Clean up with a sponge soaked in warm soapy water, then clean water, dry, and store.
    Reply back if you have further questions.
the dr
  • 447 Answers
SOURCE: Ice maker not making ice.
These Icemakers have plastic gears on the modules that are breaking, also some have thermostats that are malfunctioning. I recommend haveing an experianced tech look at the unit to see if you need the new upgraded indoor ice maker.
Posted on Jan 15, 2008
SOURCE: Caffe Nabucco BCO70 Espresso & Coffee Maker
go to this link http://www.delonghi.it/Int/USA/customer.html
you can download the manual
Posted on Apr 21, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Instruction manual for Belling Combi oven BEL-CJSS25
Did you try this?
Lines are open Monday to Friday 8am - 6pm and Sunday 10am - 2pm.
Belling Customer Care: 0871 22 22 503
Or maybe this?
Belling Product Helpline
0871 22 22 635
Product Helpline Open Times
Monday to Thursday
9am - 5pm
Friday
9am - 4.30pm
Spare Parts
0871 22 22 506
Posted on Nov 25, 2008
SOURCE: i have a gn 6210
I actually took my GN 6210 apart (not recommended)--the battery is _not_ easily user-replaceable, as it appears to be directly wired to other components. I think when the battery is dead, it's the better part of valor to move on to a newer model.
I suggest http://www.amazon.com/Samsung-WEP200-Bluetooth-Wireless-Black/dp/B000GAO9T2/ which, at the time I write, is very highly rated and is only $25, $5 after rebate. But long after that deal goes, there will be other good headsets cheap, though few with the cool mobile/landline joint compatibility. (I'm mobile-oriented, myself.)
Posted on Dec 02, 2008
sharcnet
  • 2130 Answers
SOURCE: Need instructions for garmin 255w
Please use this link. The manual for the 205W will work just fine for you.
https://buy.garmin.com/shop/store/manual.jsp?product=010-00718-20&cID=137&pID=13431
- Jim
Posted on Dec 09, 2008
Turn it on, won't do a thing, just stopped. Lights up, thats all.
Hi Carol - Sometimes, a product just reaches the end of its life. A product that sees daily (or more use) for 7 years is a pretty good run. Assuming you have cleaned and maintained it, there little more that the end user can do. These makers are more complex that the old "Mr. Coffee" or percolator that used to adorn everyone's countertop; and will often cost more to repair than it's worth. You will find it is easier and quicker to replace it with a new one and probably makes more sense than investing good money in a 7 year old coffee maker.
Dec 08, 2015 | Keurig B100 Coffee Maker
My pressure washer appears to have died.
does the motor have rust in it??the motor can be replaced
Jun 18, 2015 | Bosch AQUATAK GO Pressure Washer
I have the Mr Coffee Keurig model BVMC-KG5. It has only been used probably used less than 15 times. Now the water just drips out. Cleaned it per instructions which did not help. The machine was bought from...
It depends where the water just "drips out". It could be a leaking hose, or it could be the parts weren't put back together properly after you cleaned it. More information would be helpful.
Download Mr Coffee BVMC KG5 Manual
Feb 01, 2014 | Saeco Odea Go
I have an ESP 7 All in One printer, which I bought a year ago for a Christmas Present. The printer works fine, but the red color has faded. I have run the clean printhead program, but there was not any...
Sounds like the printhead needs replacing. If all the cleaning doesn't work and you're using new carts, then it could well be that.
If, however, you haven't used it for some time, they are prone to block up solidly with dry ink.
Dec 30, 2010 | Office Equipment & Supplies
Where can i get instructions for a Micromark MM52121 Tea Express?
Hi, did you find any as I'm in the same boat and as Micromark have folded can't find instructions anywhere
Thanks
Dec 28, 2009 | Coffee Makers & Espresso Machines
My daughters v. smile will not turn on
The ac adaptor has to be set to the correct voltage , there should be a small adjuster on the mains plug.
1.5v for each battery ( regardless of battery size ); so 6v for a 4 battery , 9v for 6 battery , etc.
Oct 15, 2009 | Vtech V.Smile TV Learning System (Pink)
Need instructions for a Krups Household Coffee/Espresso Maker
Go o krupsusa.com and click on "instructions" they should have it
Dec 11, 2008 | Krups Small Appliances Espresso Machine
Refrigerators Logo
44 people viewed this question
Top Micromark Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Micromark Refrigerator Expert? Answer questions, earn points and help others
