Question about Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television
Yellow tv screen
My tv screen is yellow, months ago it started as a patch of yellow on the left side, now basically the whole screen is yellow, i was told it is dust, i also was told this panasonic tv you just cant take the tv to a repair man and just blow the dust out.i was told it would cost me at least $600 or more to get the dust out.
  • kunnu_patel Apr 07, 2009
    I have a Sony XA21M80 and my color keeps changing from normal to having more yellow or brighter. It flashes back and forth in no regular pattern. It keeps changing as per the picture. If background in scene is bright then it appears bright. If background dull then suddenly it changes to yellowish. The subtitle colors keep changing from “bright white” to “yellowish white” as per scene.
  • jane967 Apr 11, 2009
    Yes, except this has just started so it has not moved to cover the whole screen.
I have the same problem. I had to take the whole thing apart and found that the red filter has a burn pattern in it. I am still trying to find a red filter for it.
Posted on Feb 18, 2009
I have a 42 in Sony HDTV model # KDF-42WE6555. I notice a few months ago a blue line down the left side. TV still wking good. Today I notice a yellow patch on the right side. TV is still wking good except...
i have the same problem but mine has a blue line surrounding the screen the tech took out the fly wheel part from inside this part has the 3 main colors with strips the blue side strip if you look at the glass it has the problem you see on your screen you have to replace that one section
Mar 10, 2011 | Sony Grand WEGA KDF-42WE655 42" Rear...
I replaced the main lamp 6 months ago. Now I have blue on the right, yellow in the middle and normal color on the left. I also have a ghost image of tree branches on the whole screen.
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixilation even vertical lines.You will need to replace the light engine. Found it here:http://www.discount-merchant.com/SONY-1-758-484-22-p/1180916.htm Have a blessed one!
Mar 31, 2010 | Sony Grand WEGA KF60XBR800 60" Rear...
I have a 46 inch sanyo lcd 1080p that is only 2 years old. A few months ago we started getting a black screen only on part of the tv. It would show up off and on. some days all the time and others not at...
I'm having the same problem with the same TV. I called around to repair shops and I guess it's fixable. Haven't taken it in yet but I was told it most likely is a bad module. But this seems to be a really common problem with this television
Feb 04, 2010 | Sanyo DP32746 32 in. LCD Television
I have a black patch on my tv lcd tv screen
If it is just in one small area it is the LCD panel. If it is a whole left or right side it is a blacklight invertor.
Sep 07, 2009 | Samsung 37 in. Flat-Panel LCD HDTV
Blue haze and dull yellow patches on screen
The light engine in your set has gone belly up. It is a very expensive repair. Good news is that on a whole bunch of models like yours Sony has extended the waranty on the light engine. Check with a local authorized Sony service center and give them the model & serial number and you might get a free ride. If I were a betting man I'd take odds on 'you're in luck'. LOL
May 28, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Yellowish spot on the lower left hand corner of tv screen
Good Day, There is a device that can be used to correct your concerns. Symptoms can be correct by EE PROM CORRECTION TOOL:
LSUQ0100. Instructions included. Try calling 1-800-458-6053. It's under $100.00 and takes about 1 hour from start to finish. Good Luck, big IRISH.
Jul 07, 2008 | Panasonic PT-52LCX65 44" HDTV
Yellow Line at the Top of Screen
Try doing a system reset. Not sure it that's the term they use but that option basically resets the tv to factory default settings. It's in the menu somewhere. I've done the reset twice already for a similar problem. Solved it each time.
Jun 05, 2008 | Toshiba 42HP95 Television
Horizontal ines---original post got wiped. Sorry.
leaky cap(s) in vertical circuit. shouldn't be more than $125 (plus taxes) parts and labour
May 14, 2008 | JVC AV-27230 27" TV
Blue Streak
I had the same problem w/ the same TV about 6 months ago. You need a new optical engine. Hopefully you are still under warranty. Once that was replaced, the tv looks great.
Dec 26, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television Logo
1,535 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
