Question about Delta RP1001-BL Classic Kitchen Soap/Lotion Dispenser...
Kwc kitchen soap dispenser wont work
I have made sure it is not clogged, just wont pump soap out
Sorry but you need new one, the cheapest I have found is KWC America 504 938 000 Primo Lotion Soap Dispenser on amazon. I hope this was helpful, cheers
kwc kitchen soap dispenser wont work - kwc-kitchen-soap-dispenser-wont-work-atj332yoy54aaiam5221rt21-2-0.jpg
Posted on Nov 28, 2014
  • Anonymous Nov 29, 2017
    Great Fixx it Hint: I used a bag tie from the market to shove into the small hole where the soap comes out. Worked Perfect Kudos to jaugust33. Thanks for your FIXX
Replacing this is not a very good option since KWC dispensers are expensive. I fixed 2 of these that had chunks of copper corrosion inside the thin spout, blocking the flow of soap. To fix it, pull off the metal head, flush warm water into the hole at the base and end of the spout, and run a thin wire (bread tie, etc) through it. The debris can be flushed from the end of the spout back into the base, since the end has a very small hole and the base has a much larger hole. This is only a 10 minute job.
Posted on Jul 06, 2009
  • mg smith Sep 09, 2012
    great solution. I knew that the problem was solidified soap, but doing everything from pouring hot water down the intake tube to boiling the head didnt quite do it, and I couldnt find a wire thin enough and strong enough to work in the spout until I tried your twistum wire. worked like a charm. thanks.
My kwc soap dispenser is not working. soap does not come out from the nozzle. have cleaned it; no improvement. suggestions?
Posted on Aug 31, 2010
    Champion:
  • 244 Answers
Replace it
Posted on Feb 16, 2009
Soap no longer dispenses automatically.
Mine would not work with the Costco brand (Kirkland) batteries. The light indicator came on but the pump did not work. Once I replaced them with Durcell, the pump started working. I'm guessing Energizer brand would work just as good.
Nov 22, 2013 | Umbra Otto Automatic Soap Dispenser,...
My soap dispenser wont pump soap
Are you out of soap? Does the pump go freely up and down? If the pump goes down a little and then stops its probably clogged. If this is the case just get a long piece of notebook wire and slide it through the pump and it may unclog it. Really a soap pump is a very simple set-up. Suction from one end brings the soap through the tube and out the actual dispenser. Hope this was helpful:)
Sep 20, 2012 | Grohe Soap Dispenser for Kitchen...
My grohe soap dispenser won't pump out any soap.
If the soap dispenser is not pumping the soap then the soap is to thick. You need to then the soap down some so it will pump.
Apr 01, 2010 | Grohe Satin Nickel Soap Dispenser...
Soap dispenser doesn't pick up soap
Make sure the clear tube is inserted into the pump head properly.Make sure the tube is not kinked. try filling the bottle full of water and try pumping the water out first. Sometimes the dispenser gets an air lock and takes a bit of continuous pumping to get it to work
Feb 24, 2010 | Price Pfister Marielle Kitchen Faucet with...
I have 2 American Standard deck mounted soap dispensers in my kitchen. 1 is for soap and the other is for hand cream. They both worked for a few years, but now neither one pumps. There are no leaks. I have...
All soap dispensers work on a siphon principal. There are o-rings inside these pumps and, over time, they dry out (even when surrounded by soap (which has an acid base)). Unless there is a way to dis-assemble these pumps and replace the o-rings, you may want to start looking for replacements.
Feb 22, 2010 | American Standard Contemporary Kitchen...
Kitchen sink soap dispenser won't pump
soap may be too thick or pump tube may not be touching soap in dispencer. try pumping same soap from cup
Mar 08, 2009 | Plumbing
KOLHER Soap dispenser won't dispence soap.
Pull the dispenser out. Put it in semi hot water foe a few minutes to clean it. Then put the pickup tube in a glass of water and pump it untill water comes out. They get clogged with soap after so long.
Good Luck
Kurt
Mar 01, 2009 | Kohler K-5988-2-7 Entree Self-Rimming...
Delta RP1001-BL Classic Kitchen Soap/Lotion Dispenser... Logo
3,475 people viewed this question
Top Delta Home Experts
Mike
Donni Steen
john h
Are you a Delta Home Expert? Answer questions, earn points and help others
