Question about Sony VPL-VW100 (Ruby) Multimedia Projector
Problem with Sony VW10HT
Have a similar problem with my VW10HT. Lamp was replaced a few months ago, picture was bright last time I used it. However now it does not start, lamp cover light, lights up and green light flashes. Also there about 4 to 5 clicks but then nothing.On the blogs you mentioned that you might have a possible solution that you can email to. Please send it to if you can.Thanking you in advance.Regards.
2 Suggested Answers
SOURCE: Sony VPL-ES3 Multimedia
Hi Marsat!
Actually both the filter cover and lamp covers have a long straight plastic part which is inserted in small hole. At the end of the holes are micro switches. When you fit the filter cover this switch is pressed and projector knows that it is ok to turn on. Similarly if lamp cover is loose the micro switch is not fully pressed resulting in this message. Tightening it presses the micro swith and the indication vanishes. In your case if plastic parts are intact, lamp cover screw is fully tight, filter is clean and properly seated with a click sound, then may be some micro switch has malfunctioned and you have no option but to take the projector to some qualified repariman.
Posted on Jul 13, 2008
Screen flickering
A number of possible reasons--from brightness/contrast set too high to a issue with the power supply of the set--a expert would have to examine the set--you might want to call Sony to see if known issue with this model.
Oct 29, 2012 | Sony Grand WEGA KDF55E2000 55" Projection...
The power light is red and the bulb light is blinking red
OK...Did you replace the lamp with a Sony original? If you did, then carefully check that the door is closed properly.
May 28, 2010 | Sony KDF-E55A20 55 in. LCD Television
Sony KDS 50a2020. Tv Seems to Dull. not a setting.
Two possibilities:
1. The lamp. When did you last replace it? They will dim over time and lose focus, clarity, brightness and sharpness. If it has been 18-24 months, and this is your main tv, consider replacing it.
It's a F-9308-860-0. They go for about $175.00.
2. Let's say you follow my advice, put in a new lamp and the picture is still dim, dark, dingy and fuzzy? Then you, my friend, need a new Optic Assembly. The thing your lamp shines into and the thing that gives you a picture to look at. They can fail or wear out for all sorts of reasons--too many for me to type out now. But, suffice to say, if you have recently replaced the lamp (less than 6 months) and are experiencing a drop in brightness, consider getting on the phone with Sony. Even if you are out of warranty, your set is covered against Optic failure until June 30, 2010.
Hope this helps.
Jan 21, 2010 | Sony KDS-50A2020 Television
Picture brightness is about 1/2 as it used to be what is the cause?
If its Sony KDF-E55A20 TV then it sounds that lamp in TV is getting weaker, time is coming to replace lamp.
New lamp will bright the picture again as it was before. Lamp replacement is easy and procedure is written in user manual.
Please buy Sony original lamp for your TV safety.
Nov 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
Picture is dark
Adjust video settings:
  1. Press Wega Gate
  2. Select Settings
  3. Highlight Video
  4. Press + to select
  5. Adjust/increase the brightness.
  6. Press Wega gate to exit.
If picture is still dark, you need to replace the lamp again. Sony recommends that you replace the lamp:
  1. After approximately 8,000 hours of use.
  2. When the screen becomes dark or the color becomes unusual.
  3. When the lamp indicator on the front of the TV flashes.
Aug 22, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
VW10HT screen filled with horizontal lines until unit warms up (5-10 minutes!)
I have a similar problem with our projector. It help to reverse the output for some reason. When reversed, all horizontal banding disappears.
Jan 22, 2008 | Sony VPL VW10HT Multimedia Projector
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Jul 28, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony VPL-VW100 (Ruby) Multimedia Projector Logo
90 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
