Keeps showing F61 - Audio Players & Recorders
  • Scott Frye
    Scott Frye May 11, 2010
    HI...
    What model are you referring to?
    Thanks
  • Badal
    Badal Jul 26, 2014
    sa-ak87
  • 336 Answers
Panasonic error code F61 is for an output /power problem. Most likely it will need the output ic replaced. But check that the fan(s) are running a bad or stopped fan will also cause F61. Replacing the IC is best left to a technician and Panasonic is the only supplier that I know has the part.
Posted on Feb 17, 2009
AFTER A FEW SECONDS MY SYSTEM SHUT DOWN AND SHOWS ME F61 ON THE SCREEM
  1. AFTER A FEW SECONDS MY SISTEM SHUT DOWN AND SHOW ME F61 ON THE SCREEN
Oct 25, 2010 | Panasonic SC-AK300 CD Shelf System
F61
That code means the audio amplifier IC´s are dameged and need to be replaced
Jan 23, 2010 | Audio Players & Recorders
SA DT310 showing F61 and closing down
the F-61 code means your audio outputs are bad you must have it repaired
Dec 19, 2009 | Panasonic Home Theater System System
Stereo system technics sc-dv150 showing fault f61 how do i
f61 is a bad voltage code. I will probably need an output ic or a voltage ic.
Oct 15, 2009 | Audio Players & Recorders
F61 on dvd
audio amplifier IC damaged need to be replaced
Jul 23, 2009 | Panasonic DVD-F61 Multi-disc DVD Player
F61 continues to stay and shuts it down it won't open the door
check the output wires for short circuit.anyway remoove all he bufalls.and re oparate .if problem solved check the one by one connecting.
email me i can help you.
roshanw@ccl.lk.
Jan 06, 2009 | Audio Players & Recorders
My panasonic turns on but shows the letter f61 what does that mean?
F61 just means 'power fault'
Generally a fault with either audio power amp ic (IC 501) or power supply ic (IC 502).
May also be the fan if it has one make sure it is clean and can spin freely.
Hope this helps. Thanks
Sep 13, 2008 | Panasonic Televison & Video
I have Panasonic SC-AK750 Mini System and of late it keeps showing F61 on the screen before it switches off. do you know what it is
The F61 indicates protect mode. This means that a problem was detected inside and the unit shuts down to prevent further damage. This is usually the output amp pac or the regulator IC. The amp is attached to the heat sink in the rear of hte unit and should be marked RSNxxx.
Dan
Sep 11, 2008 | Panasonic Audio Players & Recorders
Error code F61
Please describe your f61 error code problem:
Aug 09, 2008 | Audio Players & Recorders
System keeps shutting down
Code F61 can point to trouble in the audio output ic chip, are the loudspeakers connected correctly no short circuits.Also check that the cooling fan operates.
Sep 08, 2007 | Panasonic SC-DT310 System
824 people viewed this question
 Grubhead
Grubhead
