Question about Leapster Learning System
There is no volume on the leapster 2
Even though the volume is turned all the way up there is no sound. I put new batteries and tried it with a fully charged battery back but no luck! Is there a mute button? Help!
  • 1 more comment
  • freebyname Feb 19, 2009
    I have exactly the same issue. Any solutions?
  • Anonymous Mar 04, 2009
    no sound on mine too
  • shawn May 27, 2013
    any solutions I have the same problem
SOURCE: How do I get the batter cover off a Leapster?!?!?!?!?
If the battery compartment lid is not sliding out after you have loosened the screw, press the coin in the gap created from what short distance it did slide, and use the coin to force the battery compartment forward. Mine was really stuck, and this did the trick after some serious effort.
Posted on Dec 26, 2008
SOURCE: dark screen on leapster
There are two buttons on the Botttom of the leapster. One is brightness one is dark. You probably turned it to dim.
Posted on Dec 27, 2008
SOURCE: Leapster pen not working
1) Ensure that a cartridge is not inserted 2) Hold down the Hint (?) button while turning the unit on. Continue to hold the Hint button down until the LEAPSTER menu appears. 3) When the LEAPSTER menu screen appears, press the A button 4) Touch each of the crosshairs that appear with the stylus 5) Restart unit
Posted on May 15, 2009
  • 18 Answers
SOURCE: Won't turn on.
call customer service 800-701-5327 they might be willing to replace it even after warranty has expired.
Posted on Oct 13, 2009
  • 110 Answers
SOURCE: When we inserted a new game cartridge (Pet Pals
its not recognizing the game, contact is probably dirty. take an eraser and rub the contacts of the cartridge and get them super clean, blow out ALL the debris and that should fix it.
good luck!
Posted on Jan 29, 2011
I gave my son a leapster explorer about a month now and it's volume just stopped working and it wont hear anything.
there are three basic reasons why the leapster explorer won't bring out sound.
1. Defective speaker
The speaker of your leapster explorer maybe defective, this can make it not bring out any sound. Disassemble the leapster explorer, check the speaker part, test the speaker with a AA battery. If you hear any sound using the battery, then it means there is nothing wrong with the speaker.
2. Loose wire connection
Disassemble the leapster explorer, check the wires connecting the speaker to the board. Check for any wire cut, or loose connection which can cause the speaker not to bring out sound. . 3. Sound IC/Card/Board
If non of the above is the cause of the problem, then it means the leapster explorer is having a defective sound ic/board/card. There is an IC on the board of the leapster explorer which is responsible for sound. If this ic has a shot, there won't be any sound. If this be the cause, I think it's high time to took the leapster explorer to a repairman because this requires skill.
I hope the above is clear. If not, please let me know for further assistance.
Regards.
Aug 10, 2011 | LeapFrog Leapster Explorer Learning Game...
My son's Leapster Explorer suddenly has no sound. If you hit the increase sound button, nothing happens. If you hit the decrease button you see the volume bar on the bottom of the page. Do you know...
I had same problem, just fixed it by a little hack. The volume up switch is broken.
1. Remove accessory door on bottom. 2. Remove all screws on back. 3. Open back cover.
Looking at the exposed board, there are 2 volume switches (back to back). Directly next the switches are four contacts: the upper 2 are for volume down, the lower 2 are for volume up.
4. Place the battery pack on the board and hold it down. 5. Press the power button to turn on the unit. 6. Use a small wire to jump the volume up contacts multiple times to change the volume to maximum (or desired level). 7. (Optional) Remove the volume buttons and throw away the rubber cushions to prevent the volume from changing. 8. Replace everything back in place.
Jun 14, 2011 | LeapFrog Leapster Explorer Learning Game...
Hello. My daughter's Leapster 2 sound has stopped working. She has only had it brand new since Christmas. Can it be fixed?
Have you tried putting new batteries? If yes and still has no sound then look for the warranty and bring it back to the store where you bought it so they can repair it for free.
May 15, 2011 | LeapFrog Leapster 2 Learning System
The volume button doesn't work on our leapster explorer. It shows that the volume is at the lowest point, but it will not increase so we can hear it. We tried replacing the batteries and that didn't...
Mar 17, 2011 | LeapFrog Leapster Explorer Learning...
The sound my son's brand new Leapster 2 is not working. Batteries are brand new, volume indicator shows it is all the way up. Is there any hope for it? What do I do?
I am having the same issue. Devasted child as birthday gift won't work. After you choose name the screen goes blank. Please help:(
Jan 05, 2011 | LeapFrog Leapster 2 Learning System
The sound on my sons leapster 2 has stopped
1.You can get a full refund 2.you can contact customer service 3.buy another one whith your refund:)
Oct 15, 2009 | LeapFrog Leapster 2 Learning System
Leapster 2 unit turns on, warning msg re. seizures and flashing lights stays for a few seconds then shuts off. Has new batteries. my daughter has the same problem with hers it turns on and brings up an...
We have 3 Leapsters. The old green model and 2 newer models. Our green one started doing that not long after having it. But it still works and if it shuts off, then we just turn it back on again. When I called up c/s for Leapster, they sort of make it difficult to return. And then I was not promised a new one, but it could be new or refurbished. I let it go. Now w/ the 2 new models, I believe this has happened. I've questioned if my kid's are accidentally hitting the power button. I have seen the green one power off before. I purchased the $10 plug in's. So worth it. No more batteries. And we haven't had any issues. So perhaps it is the batteries. Call up Leapster though and see what they have to say. Good luck! :)
May 26, 2009 | LeapFrog Leapster 2 Learning System
My son has a leapster 2 but cant play anymore..........
check your CPU whether it has space behind it for proper working of fanOR put a new ram
Mar 26, 2009 | Leapster Learning System
Dark screen on leapster
Nov 11, 2008 | Leapster Learning System
Leapster Learning System Logo
551 people viewed this question
Top Leapster Toys Experts
thegtw
Michael Vincent Cruz
Dennis Crouse
Are you a Leapster Toy Expert? Answer questions, earn points and help others
