Question about Dell Inspiron 2200 Notebook
Windows will not start/run.
When I restart my computer the dell start up screen shows, then it just turns black with a single white cursor in the upper left corner. How can I get it to run?
  • 3 Answers
Try tapping the F8 key while starting up the computer to see if it will start in safemode. If the computer will not start in safemode you may have a failed hard drive that needs to be replaced. If you do get the computer to start in safemode backup all your data and then perform a CHKDSK (check disk) on your hard drive by right clicking on your c drive and going properties and then to tools then checkdisk.
Posted on Feb 16, 2009
Why a black screen on xps l701x w7 i7 1.73
Black screen - no flashing white cursor in the upper left corner - no picture at all, i.e. the initial Dell start-up screen doesn't show up either:
- LCD is dead or isn't getting a signal - not an easy fix; or
- the LCD isn't being sent a signal - holding down the function [Fn] key and press display Function key to toggle through its settings (LCD panel only, Rear VGA output only, both LCD and VGA output)
Black screen - flashing white cursor in the upper left corner - the screen goes black after the windows loading screens come up but before the windows login screen comes up - it is probably a windows video driver problem. Try starting in Windows Safe Mode with VGA. Press [F8] after the Dell startup screen disappears to access the windows startup menu
Oct 19, 2014 | Dell XPS Computers & Internet
My laptop will not turn on. It begins to start normally with the Windows screen, but goes black with just the cursor showing, then goes into a kind of sleep mode with the cursor grayed out. When I plug...
Put the Windows disk in and repair the drivers. Should be easy follow on screen instructions, if not use the DELL OEM disk to start and do repair. I have a Dell Inspirion it did this b/c of a virus. I just did a repair WIN7 and all is good now.
Jul 10, 2011 | Dell Studio 17 Laptop
Hi My dell vostra 1500 laptop is not getting started.It is showing a black screen and cursor flashing in.Pleases suggest what could i do to get my computer back in shape.
this is most likely a startup(bcd boot)error. the only way to fix this is to run setup from your recovery partition (shift f10) when starting up the computer or use a windows 7 install disk and select repair my computer when it comes up instead of installing. let the program go through the first repair attempt to repair startup and then restart the computer without the disc in the drive. should repair the problem, but if not you can alway reinstall windows. heres a tip...stop downloading illegal movies/software because this happens when you download torrents and viruses.
Feb 01, 2011 | Dell Vostro 1500 Notebook
Too many! Where do I start.... 1. The Wifi connection does not work, although blutooth is on and the blue indicator light is illuminated. 2. When the pc is idle for some time, the screensaver does not...
This can happen when there is two problems.. One the computer might have been affected by virus.. Or the other thing might be the OS corrupted.. Try to get into safe mode and check if the system is working fine.. If it works well there try to do a system restore to a place wr it was working well.. If in safe mode also it doesnt work well then go ahead and reinstall the OS...
Sep 24, 2010 | Computers & Internet
Black screen with blinking cursor upon start up
You don't say what Windows are you using.
Anyways, it seems like you have a corrupted BOOT problem.
On Windows Vista and Windows 7, you can insert your Windows installation CD, and choose the "Repair my pc" option.
Windows will do it automatically fro you, and you'll be up and running in a couple of minutes.
Dont forget to rate this answer if it helps.
Jul 18, 2010 | Dell Inspiron 531s Desktop Computer
Does dskchck & freezes if cancelled goes black & only cursor show
That's a common problem with'll need to restart your computer. Start back up in safe pressing F8 at the boot screen. then restart your computer normally through the start menu. After this I would find a good copy of Windows XP Professional and back up my data, and install XP over vista.
Dec 15, 2009 | Alienware PC Systems Alienware Aurora High...
My dell inspiron 1525 has a black screen with a white cursor showing
First, I want to know if you sees the Dell logo after turning on the laptop? If yes then this is no boot issue.
1. Immediately run the PSA. Make sure laptop is off. Press and hold down the Fn key, while holding down Fn key press the power button at the same time just once. Once the Dell screen loaded you can now let go of the Fn key. Check if the PSA will run short test for the LCD, RAM and HDD. When full color displays on the screen just press Y. PSA will continue. Just take note of any error code will appear on the screen such as 0141, 0142 and 0146 these are HDD failure errors which means HDD needs replacement. If the test says no errors found then proceed to step 2;
2. Try restarting the laptop once you see dell logo then keep tapping F8. Select last known good configuration. Press enter key. Just wait and check if laptop will load Windows. If not then, restart laptop keep tapping F8 try to select safe mode check if it will load Windows. If not then prepare the Windows OS disc the one came with your laptop.
3. While laptop is on insert the Windows OS disc. Restart the computer. On the Dell screen keep tapping on F12 to show boot menu. In the boot menu select CD/DVD ROM Drive. Press enter then keep tapping on space bar until it will say Windows loading files, please wait.
4. In the User Interface it will show you some options to select. Once the Install screen comes up look on the lower part select Repair Your Computer. If will ask you to do Startup Repair, please do start up repair. If fails try the System Restore. If fails then step 5;
5. If you have important files in your HDD then back up your files first. After backing up of files you can now install the Windows OS. Here is the process in installing the Windows OS. Insert the Windows OS disc, restart the laptop, keep tapping F12 on Dell screen, on boot menu select CD/DVD ROM Drive.Install the Windows OS. Just complete the installation.After the installation install the laptop drivers.
Dec 10, 2009 | Dell Inspiron 1525 Notebook
Black Screen
Sounds like your graphics adapter isn't working correctly or there's a problem with something in Windows (I'm assuming you're running Windows XP). If so, restart your computer and hit F8 until you get a menu. Select Safe Mode and see if it boots up correctly. If it does, note any error messages you may receive and then shut it down. After shutting it down, let it start up on it's own and see if you get your picture back.
Jun 14, 2009 | Dell Inspiron 1420 Laptop
Windows wants to start but...
try to reinstall the OS.. ths will solve the problem...
Feb 20, 2009 | Dell Inspiron E1505 Notebook
My XPS 1530 will not shutdown, it only restarts
Try running chkdsk /r and then restart the computer. to do that, click on START, RUN, in the open field, type 'cmd' and press <enter>. A dos window will open. At the blinking cursor, type 'chkdsk /r' and press <enter>. You will get a message that the drive can't be locked and do you want to run it the next time Windows starts. Type 'y' and press <enter>. Now shutdown the computerand restart it. Chkdsk will run and it may take some time. Depending on your installation, you will see a blue screen that will show the progress. Sometimes the screen will stay black and the hard drive light will flash. That's ok. Let it run until Windows loads. Wait until it is completely loaded and then try shutting it down normally.
Good luck and let me know how it works out.
Feb 07, 2009 | Dell XPS M1530 laptop. TUXEDO BLACK. 15.4"...
Dell Inspiron 2200 Notebook Logo
Alun Cox
