Question about Acer Aspire 5315 Notebook
Bluetooth device not found
Hi in my acer laptop i could not able to use my bluetooth sevices.
when i install the blue tooth software that time i shows me bluetooth device not found pls insert the device. but in my laptop bluetooth is having bluetooth by default.
  • Anonymous May 05, 2009
    hi me too facing the same problem in my Acer Travelmate 2310
    Even re-install the driver.
  • 265 Answers
Try reinstalling the drivers again my friend
Posted on Feb 16, 2009
Blue tooth buton not active does it have blue tooth or is that just a button
Try installing the bluetooth driver from the driver disc that you should get when you bought the laptop. If it says bluetooth device is not found, push the bluetooth button once and try again. If it still says that the device is not found, then most probably your laptop have no bluetooth.
This is true for some Acer laptops that I've meddled with. I did what I said, assumed that there's no bluetooth device, only to have it confirmed by the owner that the seller already mentioned that his model have no bluetooth.
Apr 11, 2010 | Acer Aspire 4730-4947 Notebook
Bluetooth is not found in the control panel of my laptop
goto start and type bluetooth in search...if bluetooth drivers are installed ull get some icons like bluetooth, bluetooth devices etc.....try clickin bluetooth devices.....n u can try to connect with ur mobile.....if it doesnt show anythin u may have to install bluetooth drivers....hope this helps...
Mar 07, 2010 | Lenovo ThinkPad R61i 14 inch widescreen...
How can I operate bluetooth on my acer laptopextensa 4630
First you need to install the bluetooth driver software [that can be found on the acer CD that came first time with your laptop or just look here ] , then reboot your system . after that turn on the bluetooth buttons on your laptop and on the device you want to connect your laptop with for example [Cell phone ] . make on of them look for the other . then you need to pair them , so that you don't need to do that again .
Just look around in the software that you already installed and problem will be solved .
your rating is very important for me , that's why I've helped you .
good luck .
Jan 12, 2010 | Acer Extensa 4620 Notebook
I dont know if i have bluetooth device in my laptop acer 5220 extensa. There is a button dedicated for it though. when i slide it to activate it gives me a message '' No Bluetooth Device Found''....I tried...
This might sound stupid, but did you activate the blue tooth on a other device so that there is a device to scan for? I am saying this, because my pc gives that message when it does not find any other devices to connect with, although the blue tooth on my pc works fine.
Really hope this can help you.
Best regards
Oct 18, 2009 | Computers & Internet
Hello, acer 5535 Laptop, internal bluetooth problem
your laptop uses a foxconn bluetooth set. Make sure you have the proper driver for this device. Go to Acer support and make sure the driver is up to date. May look something like this:
Fox_brm_2.0 F/W 300
I believe this laptop is still using the bluetooth standard 1.1, so there shouldn't be an issue with finding another bluetooth device. Just make sure that the other devices are in discovery mode or they won't be seen regardless. Discover mode should be able to be accessed through the options tab under bluetooth. Good luck, ParrotHead PC Repair
Sep 06, 2009 | Acer Aspire 5535-5050 Notebook
I have Aspire 4730Z acer laptop. but can't install blue tooth. when going to install driver from utility CD showing no device found. let me clear how can I resolve the problem i am trying to bluetooth...
The 4730Z does not have bluetooth onboard. The bluetooth button is there because the 4930,model shares the case and some hardware with your 4730Z. hardware with the 4930 which does have bluetooth. You will need to add an internal bluetooth device or USB bluetooth dongle if you want bluetooth.
Apr 27, 2009 | Acer Aspire 4720 Notebook
Please anyone solve my problem?
this problem generally occurs with blue tooth devices.
before reinstalling device driver
  1. shut down your system properly
  2. turn on your system.
  3. turn on the switch of bluetooth
  4. now try to reinstall the driver
  5. after installing driver restart your system.
Apr 22, 2009 | Acer Aspire 5500 5570-2609 Laptop
Acer aspire 6920
go into control pannel, blue tooth devices look through the fomats and if you have bloue tooth it will show up. set up and go. is it 6920G its there
Jan 10, 2009 | Acer Aspire 6920 Notebook PC
Blue tooth device is not working
check if your device is enabled, you can do this by ---
right click my computer..-> properties--> hardware tab--> device manager --> right click on the blue tooth icon and clcik properties. --> check if enabled..
if it is enabled check if bluetooth is enabled at startup { type msconfig in RUN in start menu, click startup tab..check if it is enbaled in startup}... or else you have to manually switch on bluetooth each time u intend to use... hope it helps.
hope to get rated as helpful...
Dec 31, 2007 | Computers & Internet
Bluetoooth on acer 5052ANWXMi
hi there,
i have a new acer aspire 5052, i have installed windows xp,
the problem is that cannot install bluetooth, i get errors like "Device not found"
and when i switch on the bluetooth button, the display shows "no device"
your help will be greatly appreciated
kesava rao
Nov 30, 2007 | Acer Aspire 5050-3242 Notebook
Acer Aspire 5315 Notebook Logo
330 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
