Question about Frigidaire FEF336BC Electric Kitchen Range
I want to chang my gas oven but i can not fin the gas valve to cl
I want to ghang my oven ,but i can not fond the valve to close the gas
    Champion:
  • 244 Answers
Please. If you can't figure this out, hire a pro to install new unit. Sounds like you lack the skills needed and gas can go kaboooooom.
Posted on Feb 16, 2009
I have current out of my thermostat but no gas flow to burner
Thermocouple sending pilot flame to allow gas to pass through gas valve?? Is it dirty try cleaning it
Jan 12, 2016 | Vulcan Hart GH60TC Griddle Tope Heavy Duty...
CANDY GAS OVEN - INCONSISTENT GAS FLOW- ( BRAND NEW)
First, Change your technician.
There is a part that senses the heat from the ignited gas, usually quite close to the flame on the oven burner where it first ignites. It is called a generator and it produces about 1/3 of a volt, that holds the gas valve open only while the flame is lit, as a safety device. Pressing the knob at the time of ignition bypasses this by holding the valve open, after releasing the knob then the system relies on the presence of an oven flame to hold the valve open. Check the generator at the point it enters the oven control valve, is it loose? Maybe it is faulty or the oven valve is faulty. Any real technician can identify the the problem easily.
Oct 31, 2017 | Candy Washing Machines
Hotpoint gas stove. burners work, oven and broiler do not.
Probably the safety valve. This unit broils and bakes off the same gas burner. A spark ignitor lights the pilot and this save gas because no standing pilot is needed. It takes a few minutes for the thermocouple bimetal combo to release the gas. When the temp gets to the desired rate then the bulb on the oven control closes off the flow of gas. To recap: The flow of gas comes from a regulator along a rail which supplys the gas to the top burners and the oven control. older models had pilot light tubing going down to the oven and to the top burners. This newer style uses a spark module to light off the top burners and the oven. So when yall turn the the oven on the spark ignitor lights the pilot first and then after the mercury bulf thermocouple heats up the bimetal inside the valve opens allowing gas to flow out to the pilot and ignite the gas burner. the temp rises and the mercury bulb oven control expands closing off the flow but not the gas safety valve. I would suspect the safety valve on this one.
May 09, 2011 | Hotpoint RGB528 Gas Kitchen Range
My gas oven heats very slowly and sporadically. It often smells like burning plastic when heating. The oven is about 9 years old and did not have this problem until recently. What could be wrong? Might...
Good morning, your oven most likely has a weak igniter. That would keep the gas safety valve from opening properly. It will get close to the required amperage but valve will only flutter and not allow enough gas to ignite. Hope that helps.
Jan 29, 2018 | Maytag CWG3100A Gas Single Oven
I have a GE Spectra XL44, model #JGBP40BEC4WH gas oven. The 4 burners on top work but the oven will not. I replaced the oven safety valve (dual type 1), thinking that it was stuck and not directing gas to...
Most likely, you're oven igniter is not getting hot enough to open the gas valve to ignite the burner. It glows like normal, but does not reach the temperature required to open the gas valve. Replace the igniter. Before you replace that, make sure that the small shutoff lever on the appliance regulator was not accidentally closed, which would turn off the gas to the oven, while still allowing gas to the stovetop. The silver lever should be sticking straight out or up. Douglas
Sep 12, 2010 | GE JGRP17 Gas Single Oven
Uneven cooking. how to adjust vents
Bend fins outwards to decrease airflow towards center of oven, bend fins inwards to increase airflow towards center of oven. Open gaps to increase airflow to an entire tray, close gaps to reduce airflow to an entire tray.
Only make small adjustments, trial and error may be required.
Sep 09, 2010 | Baxter BXA2G Stainless Steel Gas Single...
We have a 6 burner, nat gas cooktop....all unit light but the igniter clicking will not stop...unplugged it . question: all mechanics are closed is this safe gaswise?
What happens in this style ignition system is that the thermostat or electronic control switches power to the oven ignitor and gas valve circuit which are connected in series (one after the other). As power flows through the ignitor it heats and draws current (measured in amperage). Once the oven ignitor draws a specific amount of current the oven valve opens to allow gas to flow to the oven burner where the glowing hot ignitor (glow bar) ignites it. Power must continually flow through the ignitor and oven gas valve for gas to be released into the oven burner to create a flame. Once the set temperature is achieved the control stops all power to the ignition circuit which causes the ignitor to dim and the oven gas valve to close, stopping any burner flame. Cycling on and off continues to maintain the specific temperature the control is set for.
Jan 09, 2010 | Microwave Ovens
Dynasty oven fails to get enough gas to light.
I think you are talking about the oven safety valve or thermal valve. before you change you oven safety valve, I would check the Amperage on the oven ignitor first, install AMP meter on one of the ignitor wire, it should draw above 3AMPs, if not then you have problem with the oven ignitor and not the safety valve. we hardly change the safety valve, I'll try to change the ignitor first. Have fun.
Mar 28, 2009 | Dynasty DGRSC 30 Gas Kitchen Range
American Range ar6b-24rg
If you oven temp is off by +- 50 degrees, thermostat needed to be change. to check and adjust the oven thermostat usually we place the oven thermometer in the center of the oven, run the oven at 350 degrees for minimum 30 minutes and check the oven temperature, It should be +- 25 degrees, if it needed adjusting, there is the adjusting slot screw in the center of the thermostat stem, to adjusting it ( do not turn thermostat stem during adjusting ), turn adjusting screw counter clockwise to raise the the temp, clockwise to lower the temp, turn it a little at a time and wait 15-30 minutes before do the next adjustment until the temp match with the oven knob. To adjust the oven burner air and gas mixture, first turn the air shutter close, you will see yellow flame, then open the shutter until the yellow flame disappear and them open it a little more, now you are done. For the oven uneven cooking? you may have a bad oven burner tube, during operation some of the flame may be lift off, disappear or flame being uneven, you can check it with the kick panels off to see the flame, if these are the case, you needed to change the oven burner tube,
Feb 04, 2008 | American Range AR-4B-36RG-CL Gas Kitchen...
Frigidaire FEF336BC Electric Kitchen Range Logo
49 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
