Question about Maytag Washing Machines
WASHER DRUM IS FULL OF WATER
WASHER DRUM FILLED WITH WATER THEN SHUTDOWN. NOW THE MACHINE WILL DO NOTHING.
  • brandt4149 Feb 16, 2009
    THERE IS A FILTER BEFORE THE DISCHARGE PUMP? WHERE IS IT LOCATED AND HOW DO YOU GET TO IT TO CLEAN IT?
  • 121 Answers
Check water filter first,then pump
Posted on Feb 16, 2009
Clothes washer does not fill.
How to Fix Washer That Won't Fill With Water ' Washing ...
www.partselect.com/Repair/Washer/Not-Filling-With-Water/
If not, then remove the hose from the faucet and inspect the screens for dirt accumulation or damage and clean or replace as necessary. If your washer still doestake water then you should next look at the water inlet valve located on the back of the machine.
Washing machine not filling with water - YouTube
? 7:28
https://www.youtube.com/watch?v=SwQe7--htAw
Aug 25, 2010 - Uploaded by how-2-repair.com
If your Washing machine is not filling with water this video willhelp you. ... *The spin cycle and drain WORKS
Nov 28, 2015 | Washing Machines
Have a Kenmore Elite top loading machine and the water starts to fill the drum and it empties out as it fills, so the drum only fills half way. No agitation or spin. Because it just sits there with the...
this sounds like the fill up censer is blocked up,,,its a cheep fix,,, its only a pipe that fills with water and at a set point it stops filling the washer, but if the pipe is partly blocked it throws its self into a wobely?? and thinks its over full so it starts to drain this water out
a good pear of lungs should blow any muck out this pipe
Jun 06, 2010 | Washing Machines
Hotpoint aquarius wma58 1400. Full of washinh. Full of water.
pull your washer out. put near door if poss then put the waste pipe down to floor level to empty the water. if there is to much water in the drum it will not spin try your pump
Jun 21, 2009 | Washing Machines
Drum not turning
My problem is the same as colins my hotpoint wm63 is starting okay i.e. water fills up but drum is not turning. I can hear it clicking through the cycle but drum doing nothing. i to have just put in new carbon brushes but still no joy please help
steve
Apr 08, 2008 | Hotpoint Aquarius WD63 Front Load...
Washing Machine Hoover H100M fills too much water in the drum.
this is 1 of 2 solutions  2 this problem the first thing to check is the vacuum system or it is a split in the pressure switch hose
Mar 05, 2008 | Hoover AAA140 Front Load Washer
Bosch WFX Excel
You have to replace the water inlet valve, the valve where water enters your machine.
Jan 22, 2008 | Bosch Exxcel WFX 2467 Front Load Washer
Drum filling with water when machine switched off
what you refer to as the overflow cap is the cover to the filter which you should remove regularly and check. however nothing to do with your problem. the water could be coming from two sources: first, if the drain is plumbed in under the sink, water can flow into the machine every time you empty the sink. the cure is to put the drain hose up as far as possible in a swan neck. secondly, the intake water valves could be leaking and the only cure then is to replace them
May 04, 2007 | Zanussi IZ12 Front Load Washer
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
