Question about Bialetti Mukka Express
THE HEATER UNIT-UPPER PART JOINT LEAKS
I've made sure that I have not cross threaded the upper from the heater unit. I've also been extremely careful with the coffee, so that no ground coffee ended up on any of the threaded edges. I even tried lower heat settings on the electric range in an attempt to reduce the leaking.
Put some drops of machine oil at the point the two parts join and srew it and unscrew it four times. then you make coffee again!
Posted on Mar 05, 2009
How easy is it to change a heater core in a2003 Kia sedona
It is in no way easy. But if you want to try, here are the instructions....
3.5L Engine
  1. Before servicing the vehicle, refer to the precautions at the beginning of this section.
  2. Drain the cooling system.
  3. Disconnect the negative battery cable.
  4. Remove the heater hoses.
  5. Remove the driver air bag module.
  6. Remove the steering wheel.
  7. Remove the turn signal assembly.
  8. Remove the upper and lower steering column covers.
  9. Remove the A-pillar upper trim.
  10. Remove the instrument cluster trim.
  11. Remove the instrument cluster.
  12. Remove the A-pillar lower trim.
  13. Remove the hood release handle.
  14. Remove the left lower trim panel.
  15. Remove the multi box.
  16. Remove the audio panel.
  17. Remove the ventilation control panel.
  18. Remove the radio.
  19. Remove the glove box.
  20. Remove the center console.
  21. Remove the audio system speakers and mounting bolts from the top of the instrument panel.
  22. Remove the side covers.
  23. Remove the T-bar mounting bolts.
  24. Remove the bottom mounting bolts.
  25. Remove the instrument panel wiring harness connectors.
  26. Remove the instrument panel.
  27. Remove the heater unit.
26096060-nraukxomtaildozoxjjbr22p-1-0.gif 26096060-nraukxomtaildozoxjjbr22p-1-1.gif
To install:
  1. Install the heater unit.
  2. Install the instrument panel.
  3. Connect the instrument panel wiring harness connectors.
  4. Install the bottom mounting bolts.
  5. Install the T-bar mounting bolts.
  6. Install the side covers.
  7. Install the upper mounting bolts and audio system speakers.
  8. Install the center console.
  9. Install the glove box.
  10. Install the radio.
  11. Install the ventilation control panel.
  12. Install the audio panel.
  13. Install the multi box.
  14. Install the left lower trim panel.
  15. Install the hood release handle.
  16. Install the A-pillar lower trim.
  17. Install the instrument cluster.
  18. Install the instrument cluster trim.
  19. Install the A-pillar upper trim.
  20. Install the upper and lower steering column covers.
  21. Install the turn signal assembly.
  22. Install the steering wheel.
  23. Install the driver air bag module.
  24. Install the heater hoses.
  25. Connect the negative battery cable.
  26. Fill the cooling system.
  27. Start the engine and check for leaks and proper heater operation.
Feb 15, 2016 | Kia Cars & Trucks
Water heater
Guessing that you have 240Volt residential non-simultaneous electric water heater? And that you have 30 amp breaker and 10 gauge wire. And that water heater is located within 100 feet of breaker box. And there are no leaks running hot water out of tank. And that you installed fully brand NEW elements of same wattage as old elements. And that fully brand new thermostats were installed, and wiring exactly duplicates wiring that was present before. And that factory-insulation was re-installed over elements and thermostats.
1) Guessing the 'hot water shut off' means the ECO red reset button located on upper thermostat keeps tripping and cutting off electric power to water heater?
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
http://waterheatertimer.org/images/WH-w-combined2-1000.jpg
http://waterheatertimer.org/How-to-test-water-heater-wires.html
2) If the ECO is tripping, then water is getting too hot, or there is shorted wire located near the upper thermostat, .
Typically replacing both thermostats and replacing elements will solve this problem .... assuming that new thermostats and elements are good, and wiring correct.
Double-Check your wiring on upper and lower thermostats.
Test wires for short.
Make sure factory-insulation is re-installed over thermostats so cool room temperature will not affect temperature reading.
Check that thermostats sit flat against steel tank.
Many short draws hot water can also cause stacking event that will trip circuit breaker.
3) Add comment and say what you find using checklist above.
Be careful to explain findings fully, using same words found on links above, so illuminated diagnosis can be made.
Dec 28, 2012 | Water Heaters
Upper thread keeps breaking on Brother ULT 2001
the tread gets stuck on in the thread take up arm, there is a joint ware the arm is rived to gather, the thread get caught between arm and the rived sheet steel . . take little silicon gasket and fill in the joint so thr thread can't get stuck where its rived
Jan 13, 2012 | Brother ULT2001
Water heater is not working after a power outage
it is possible it needs a reset. 1. turn off the breaker to make sure there is no power to the unit 2. open the top cover and there will be a red button like this http://www.tonyhoover.com/wp-content/uploads/2010/03/water-heater-upper-thermostat.jpg push it. It may have a plastic cover over or around it, leave this in place it is insulation for the wiring.
close it up carefully and then turn on the power and see what happens.
Aug 13, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Reliance electric water heater - A 95 [1995] Model 5 40 / 3500 W Max. - 240 AC Volts. Checked upper element and thermostat [fine]. Lower element and thermostat have lot of corrosion due to...
The salesman at the hardware store should be able to confirm my answer.
Match up the voltage, wattage and thread size and you should be good.
My element burned out two years ago and aside from draining the water, the job only took a few minutes and I was back in service.
Gary
Dec 15, 2010 | RELIANCE ELECTRIC WATER HEATER
How to replace heate core 1988 buick reagal
REMOVE OR DISCONNECT
  1. Negative battery cable.
  2. Drain cooling system.
  3. Upper firewall weatherstrip.
  4. Upper secondary cowl.
  5. Heater hoses from core.
NOTE Blowing out residual coolant from inside the heater core will prevent coolant leakage into the passenger compartment when the heater core is removed.
  1. Sound insulator.
  2. Rear seat duct adapter.
  3. Heater duct.
  4. Heater core cover.
  5. Heater core.
INSTALL OR CONNECT
  1. Heater core.
  2. Heater core cover.
  3. Heater duct.
  4. Rear seat duct adapter.
  5. Sound Insulator.
  6. Heater hoses to core.
  7. Upper secondary cowl.
  8. Upper firewall weatherstrip.
  9. Fill cooling system and check for leaks.
  10. Negative battery cable.
Oct 21, 2010 | 1988 Buick Regal
How to replace a heater core
Heater Core Removal & Installation Front To Remove:
  1. Make sure you have the anti-theft codes for the audio and the navigation system, and then write down the audio presets.
  2. Disconnect the negative cable from the battery.
  3. From under the hood, disconnect the heater valve cable from the heater valve. Turn the heater valve arm to the fully opened position.
  4. When the engine is cool, drain the engine coolant from the radiator.
  5. Disconnect the inlet heater hose and the outlet heater hose from the heater core.
  6. Remove the mounting nut from the heater unit. Take care not to damage or bend the fuel lines, the brake lines, and related parts.
  7. Remove the dashboard.
  8. Remove the evaporator.
  9. Remove the mounting bolts and remove the heater unit. Front heater unit honda-10-00-4128.gif
  10. Remove the self-tapping screws and the clamp.
  11. Carefully pull out the heater core so you don't bend the inlet and outlet pipes.
To Install:
  1. Using care, install the heater core to the heater unit and secure.
  2. Using care, install the heater unit and tighten mounting nuts and bolts to 7 ft-lb (10 Nm).
  3. Install the evaporator.
  4. Install the dashboard.
  5. Connect the inlet heater hose and the outlet heater hose to the heater core.
  6. Connect the heater valve cable to the heater valve.
  7. Refill the cooling system with engine coolant.
  8. Adjust the heater valve cable.
  9. Make sure that there is no coolant leakage.
  10. Make sure that there is no air leakage.
  11. Connect the negative battery cable.
  12. Perform the power window control unit resetting procedure.
  13. Enter the anti-theft codes for the audio and the navigation system, and then enter the audio presets.
Rear To Remove:
NOTE: The rear blower motor, the rear heater core, the blower screen, the rear blower resistor (heating/air conditioning system) and the rear power transistor (climate control system), the rear air mix control motor (climate control system) , the rear mode control motor and the rear expansion valve can be replaced without removing the rear heater-A/C unit.
  1. Remove the self-tapping screws and the clamp, and then remove the bolts and the rear evaporator lines with the rear expansion valve. If necessary, remove the rear expansion valve. Use a second wrench to hold the other fitting on the valve so the rear evaporator lines won't twist. Leave the first fitting loosely connected so you can use it to hold the valve while you loosen the second fitting.
  2. Remove the rear heater hoses.
  3. If necessary, remove the rear blower motor, the rear heater core, the blower screen, the rear blower resistor (heating/air conditioning system), the rear power transistor (climate control system), the rear air mix control motor and the rear mode control motor.
  4. Remove the self-tapping screws and the lower housing.
  5. Remove the self-tapping screws, and carefully separate the left upper housing from the right upper housing. Remove the rear heater core.
To Install:
  1. Replace the rear heater core.
  2. Attach the heater hoses.
  3. Make sure no air is leaking from the left upper housing and the right upper housing fitting and from the upper housings and the lower housing fitting.
  4. Before reassembly, make sure that the rear air mix control linkage and door move smoothly without binding.
  5. Before reassembly, make sure that the rear mode control linkage and door move smoothly without binding.
  6. Reassemble the housing.
  7. After reassembly, make sure the rear air mix control motor runs smoothly.
  8. After reassembly, make sure the rear mode control motor runs smoothly.
  9. Refill the cooling system and make sure that there is no coolant leakage.
Oct 16, 2010 | 2005 Honda Pilot
Replacing heater fan motor in a Toyota Previa
Removal & Installation It may be necessary to remove the upper radiator shroud to perform this procedure.
  1. Open and support the hood.
  2. Disconnect the negative battery cable and wait at least 90 seconds to proceed working on the vehicle.
  3. Disconnect the power steering and coolant reservoirs.
Disconnect the coolant reservoir
4. Disconnect the coolant reservoir and power steering brackets from the side of the heating unit box.
Remove the coolant reservoir bracket from the side of the heater unit
aa7a886.jpg Separate the power steering reservoir bracket from the side of the unit also
5. Remove the two bolts that attach the upper and lower portion of the heater box. 6. Disconnect the control cable on the side of the heater unit box.
Disconnect the control cable on the drivers side of the unit
7. Remove the eight nuts retaining the unit.
Remove the nuts (8) from around the heater unit
There are 4 nuts on each side of the unit
8. Disconnect the heater control valve bracket from the heater box.
9. Separate the top of the control box from the bottom.
Separate the upper case from the lower
Dec 02, 2009 | 1993 Toyota Previa
Replace upper ball joint 2003 silverado 1500
The ball joints on both 2wd and 4wd upper are pressed in you need to remove snap ring and using a hammer pop out the old one out this is after you seperate the upper arm from the spindle. To install the new ball joint you should use a ball joint press that you can rent at most autoparts shops
Aug 09, 2009 | 2000 Chevrolet Silverado
I need to install an evaporator core in 1997 xj6. Any tips or suggestions?
Ok , I will try to guide you as simple as I can :
1- Remove the Heater / Cooler unit this is how : * Disconnect Battery ground cable
* Recover AC gas or empty it in open space
* Drain radiator coolant only
* Remove instrument panel for access
* From under the hood disconnect AC pipes at the evaporator , by removing bolts , discarding O-Rings and make sure to install blanking plugs so that no dirt goes in.
* Disconnect heater hoses from heater matrix pipes , by releasing the spring band clips and make sure to blank the pipes
* From inside the car , remove driver footwell duct , by removing the screw and then removing the duct
* Remove upper steering column lower fixing , nuts and bolts
* Remove upper steering column upper fixings (Bolts) , and allow column to rest down o the floor
* Cut cable tie which secures console harness to LH blower duct
* Remove LH fan motor duct (screws)
* Remove passenger side footwell vent (nut)
* Cut cable tie securing console harness to RH blower duct.
* Remove RH fan motor duct (screws)
* Disconnect Heater/Cooler Connector
* Disconnect drain tubes from Heater/cooler assembly
* Disconnect A/CCM connectors
* Remove evaporator pipe support bracket fixing.
* Remove Heater/Cooler assembly fixing , by removing lower nut and upper nut
* Remove tape securing RH rear footwell intermediate duct joint. Remove duct to clear access
* Remove tape securing LH rear footwell duct
* Remove Heater/Cooler assembly from car.
2- Remove AC control module 3- Remove evaporator pipe seal plate 4- Disconnect heater tempreture sensor 5- Remove footwell servo motor from heater/cooler unit * Disconnect connector
* Remove screws
* Remove motor complete with bracket
6- Disconnect evaporator sensor connector * Detach heater/cooler connector
* Detach evaporator sensor connector
* disconnect connector
7- By now you can see one upper and one lower case * Remove heater/coolent unit upper case from lower case
* Remove screw
* Remove 15 clips
* Remove upper case from lower
8- Remove evaporator from case * Remove sensor and clip
You are done , make sure to replace all seals that you see to make sure that every thing is ok and you do not have any leaks after installation.
Installation : Reverse order and after installing make sure to do a pressure test to make sure that there are no leaks
Jul 12, 2009 | 1997 Jaguar XJ6
Bialetti Mukka Express Logo
272 people viewed this question
Top Bialetti Coffee Makers & Espresso Machines Experts
Ross Keen
Frank Russell
Frank Russell
Bill Boyd
Are you a Bialetti Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
