Question about Protron PD-DVR100 DVD Recorder
Picture is black and white
When i turn the protron(pd-dvr100) on the picture is immediately black and white.the tv is color.i can't figure out how it got this way.at first, it was color!
    Sergeant:
  • 226 Answers
If you have it connected to the 'antenna input' on your TV, change the channel up or down, and then back to 3/4 as appropriate. Sometimes the signal from the machine does not match exactly what the TV is looking for, but the TV will figure it out after you change the channel up or down. The AFC (automatic frequency control) will then try to re-tune the channel.
If you have it connected using the composite, and r/w audio, then you likely have a problem inside the DVR.
tom
Posted on Mar 09, 2009
I have a Protron LCD 26" TV model#LT26CIPI...The tv was working great turned it off on night and in the morning turned it back on to sound but no picture just a Black screen...when you change channels
Since its a LCD take a flashlight and have the room as dark as possible and with the light look to see if a very very faint image of the picture can be seen or not---many of these sets use a "back light" for the brightness and if that's not on.......
Dec 11, 2012 | Protron PD-DVR100 DVD Recorder
Tip
Protron DVR100 Manual Download
Download Protron DVR100 Manual
Have you lost your Owner's Manual for your Protron DVR100 DVD Recorder?
Would you like a digital copy of the Protron DVR100 DVD Recorder Users Guide for easy searching of terms and quick reference?
The Protron DVR100 DVD Recorder manual is available free in pdf format, just follow the link below (& Click FREE):
I hope that helps.
________________________________________________
on Jun 14, 2010 | Protron PD-DVR100 DVD Recorder
My tv video displays black and white input
check the compatible system, like if NTSC, PAL or SECAM.
Jul 19, 2012 | Protron PD-DVR100 DVD Recorder
No power on protron pd-dvr100
There is something you can try first.
With leaving something like this condensation tends to form on the circuit boards.
To remove this put the dvd into a warm room, plug it in for 2 hours, and see if thats cured it.
Nov 02, 2009 | Protron PD-DVR100 DVD Recorder
Screen is Perfect just Black and White only...No Color
well a dvd player is only going to playback the media it is reading. So if the dvd is a reproduction of a b/w western then b/w is correct but if you play a dvd from the present then it should be in color unless the tv it is connected to is faulty. Try connecting to another tv to see if problem repeats on another tv
Aug 15, 2009 | Protron PD-800 DVD Player
I was in the setup screen for the Protron PD-DVR-100 and chose progressive scan for the output. Then the screen went half black and half white. The trouble shooting in the manual send to put it back to...
If your player has the red blue green video inputs on the back plug your video cable into one of them the picture will be a bit distorted but you will be able to see enough to change it back. I did this one time with mine.
Aug 13, 2009 | Protron PD-DVR100 DVD Recorder
Didn't get a manual when purchased. How are the cable set up from the tv to the dvd r
The easiest way is to only use the Yellow (video) Red (audio right channel) and White (audio left channel)
The colors match up on player and televison. Than just turn the tv on and turn it to the input or AV channel.
Jun 06, 2009 | Protron PD-DVR100 DVD Recorder
No picture on tv when i turn on dvd. get split screen black & whi
Give this a try. Using your user's manual, locate the "Configuring your recorder" section. Under this section there will be "System setup - general" subsection. Being that you are unable to see anything on your tv display you will need to use your manual as your display. Press the "SETUP" key on your remote. Once again using your manual as your display, scroll down to "Restore factory settings" and press "ENTER" As long as you are located in North or Central America and using interlaced video outputs you should have your normal display back.
Hope this helps.
Nov 24, 2008 | Protron PD-DVR100 DVD Recorder
Protron pd-dvr 100 problem
Does Anyone have any idea, where I can buy Board replacement parts for my PD DVR-100
Sep 13, 2008 | Protron PD-DVR100 DVD Recorder
Protron PD-DVR100 DVD Recorder Logo
111 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
