Question about Casio Parts Cash Register PC Desktop
Departments 6-10 not working
I can't figure out how to use departments 6-10. I am trying to follow directions in manual. It says to depress dept/shift key and department number.
  • 737 Answers
Hi.
Most registers that use a shift system require you to type the price (no decimal point), then press shift, then the dept.
If this doesn't work, then please let me know the brand and model and I'll try to help.
Mark
Posted on Feb 17, 2009
XE-A202 prints out all depts. on X/Z reports. Want it to only print depts. used that day
By default, it skips zero values so someone has turned it on. Look in the settings of your manual for print zero departments or zero skip departments
Jan 31, 2017 | Retail Supplies
Currently my 1999 SL1 Saturn will not change gear, and I mean that the shift stick doesn't register there being any gears at all. It's stuck in third gear when it broke and now I'm trying to...
YOU NEED A HAYNES REPAIR MANUAL IT CAN HELP YOU, YOU HAVE TO REMOVE CONSOLE, PUT SHIFT LEVER IN SECOND GEAR AND DISCONNECT THE CABLE END FROM THE LEVER.DEPRESS THE TWO TABS ON THE CABLE HOUSING USING PAIR PLIERS REMOVE THE CABLE FROM THE SHIFTER.YOU HAVE TO MOVE CARPET UNDER DASH AWAY FROM SHIFT CABLE,YOU HAVE TO GO UNDER HOOD REMOVE AIR INTAKE DUCT ASSEMBLY DISCONNECT THE CABLE END FROM THE SHIFT LEVER ON THE TRANSAXLE YOU HAVE TO DEPRESS THE TWO SHIFT CABLE HOUSING RETAINING TABS AND DETACH THE CABLE HOUSING FROM ITS BRACKET ON THE TRANSAXLE.
Aug 09, 2011 | 1999 Saturn SL
I'm working with a PCR T2100 and trying to re-program the unit price for each department. I have the manual so I've read the key set to pgm, press 1, subtotal, * (dept #/dept shift for upper departments),...
Turn the key to PGM mode. Type the new price without decimal point e.g 500 Press the dept key (item) you want to change. Press SUBTOTAL Turn key back to REG and test it.
If anyone needs a Casio PCR-T2100 manual, try here: http://the-checkout-tech.com/manuals/cashregisters/Casio3.php
Nov 19, 2010 | Casio Parts Cash Register PC Desktop
Hi Mark. You instructed me to set the department names but i haven't got a clue if where is department key like the ones for Flat PLU button key. Please help! Thanks. Clarence
Sorry, I didn't know you hadn't worked with departments yet.
Key to program 2 SUBTOTAL Now type the dept number on the numeric keys (i.e just press 1 for dept 1) 05 SUBTOTAL Now type the new name for that dept 00 (double zero button) CASH SUBTOTAL
Sep 27, 2010 | Casio Parts Cash Register PC Desktop
Hi Mark, I start setting items with amounts to flat Plu001 – 006 and for test purposes I link to Department 1 – 6 as well e.g. flat PLU001 link to Dept 1, flat PLU002 link to Dept 2 upto flat PLU006 link...
In that case, you want to check that you have linked them correctly.
Turn key to program. 6 SUBTOTAL 304 SUBTOTAL 1 CASH 6 CASH CASH
This should print the status details for the first 6 PLUs. Check to see that the department link is the way you programmed it.
Sep 22, 2010 | Casio Parts Cash Register PC Desktop
Flexion1: Casio Cash Register TE-2400
You don't need to use the PLU button when operating in REG mode. The PLU button works like a flat PLU button except it allows code entry, so if you press flat PLU button 27, it is the same as typing 27 and pressing PLU. The PLU button is used to access the PLUs that aren't on the keyboard as flat PLUs. Since the machine has a lot more than the approx 70 flat PLUs on the keyboard, you would use codes and the PLU button to look up the others. The reason you needed to put the PLU button back was to allow us to use it in program mode where it is used to call up a PLU for editing (in this case to change dept link). The departments do not need to be on the keyboard. they are really just placeholders in the machine that total up the linked PLUs so you will only see them on your daily report when it has totalled at the end of the day. Try linking a PLU to a department as I showed you before. Then use that PLU in REG mode. Then do a daily report and it should show a sale in the department you linked the PLU to. I know it is confusing, but just link your PLUs at this stage and then you will start to see it happen as you use the machine and take reports.
Jul 17, 2010 | Casio Parts Cash Register PC Desktop
Flexion1: Casio TE-2400 Cash Register Solution
Ok. it looks like you have a dept or item assigned in place of your PLU button. You just need to replace it with the original and then you can try linking the depts again.
Turn key to program mode 4 SUBTOTAL 48 Now press the PLU button SUBTOTAL
Now try the programming for department link again and see if it works this time.
It sounds like you don't have the programming manual. you should have two manuals if you are programming the machine yourself. There is no programming in the user manual except for quick setups so it is for operating only. You should have this manual as well for the programming: http://the-checkout-tech.com/manuals/cashregisters/Casio_TE-2200_and_TE-2400_dealers_manual.html
If you look at the preview, you will see that this manual has all the system programming in it. I assumed you had it when you were mentioning the VAT breakdown programming. It is pretty much essential for anything you want to program in future so I recommend you grab it and have a look at the table that I mentioned for transaction key programming on the CASH button
Jul 15, 2010 | Casio Parts Cash Register PC Desktop
Casio TE-2400 Cash Register- Keyboard Orientation
Hi. The previous owner just had PLUs linked to the depts that suited them. to link PLUs to depts,
Turn key to Program mode.
3 SUBTOTAL
1166 SUBTOTAL
Now type the PLU number you want to link. E.g if you want to link PLU 6, then press 6 on the number pad (don't press the actual PLU, just type its number on the number pad)
Now press the button marked PLU. It should be near the other function buttons.
Now type the department number to link to. Use two digits. E.g to link to dept 5, type 05 on the number pad.
Press CASH
Press SUBTOTAL
As for NO SALE button, does it actually show the command NO SALE, or NS on the display when you press it? It may have been removed from the keyboard. Does the drawer open when you finish a sale normally?
There is normally a setting in key features for VAT breakdown on the CASH button. Make sure this is set so that it prints the breakdown. Add on means you sell at a tax exclusive price and the tax is added on to that by the register. Add in means you sell at a tax inclusive price and want the register to show how much of it was tax.
Hope this helps. See how you get on.
If anyone needs a Casio TE2200 or TE-2400 manual, try here: http://the-checkout-tech.com/manuals/cashregisters/Casio4.php
Jul 11, 2010 | Casio Parts Cash Register PC Desktop
Price subtracted from total.
Hi.
Sounds like dept 2 is set as a negative department. You need to change the sign of dept 2 to positive. Should be under department programming in the manual.
Jun 18, 2009 | Casio Parts Cash Register PC Desktop
Casio Parts Cash Register PC Desktop Logo
47 people viewed this question
Top Casio Retail Supplies Experts
Electroboy
Electroboy
jackcity
jackcity
Level 1 Expert
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
