Question about Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher throws food
Whirlpool dishwasher throws food on cleaned dishes. Seems to go throw all cycles properly, but dishes have food particles on them when it is complete.
    Champion:
  • 244 Answers
Check for filter on botton around pump and clean it
Posted on Feb 16, 2009
Dishwasher leaves behind particles from the rinse cycle
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes.
Hope this helps...
Daniel
Apr 17, 2011 | Dishwashers
My dishes don't seem to be getting rinsed. They come out "gritty" and none of the food particles are being washed away.
Hi
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Daniel
Mar 26, 2011 | Whirlpool KUDC03FVSS Builtin Dishwasher
Dishes do not clean, although the water is hot and the soap dispenses. Dishes and glasses have a cloudy residue at times, and dishes sometimes have small food particles baked onto the surfaces.
Hi
Feb 13, 2011 | Bosch Dishwashers
Even after a deep cleaning cycle I keep getting food particles on the inside of the glasses that sit in the top rack of the dishwasher. The unit is only 5 months old! Help!
Hi
Daniel
Jan 01, 2011 | GE Dishwashers
The dishes do not seem to come out rinsed, especially the glasses. There seem to be small particles of food left on them and overall everything seems coated with a layer of gunk. I've made sure that the...
Hi
Daniel
Dec 10, 2010 | Bosch Dishwashers
Dishwasher is throwing food bits back on dishes during wash. How do I clean out dishwasher?
While loading into the machine always remove the food particles from the dishes. The wash machine will clean the sticky oil grease only.
Check the drain filter in the machine and clean. Refer user manual.
May 17, 2010 | Frigidaire 24 in. FDB126RB Built-in...
Food particles are being thrown back onto dishes during rinse cycle and the rinse cycle is noisy.
i would suggest you dont put the food particles in the dishwasher in the first place,it sounds like you need to clean your filters out as it is a funny fault,
Apr 12, 2010 | Whirlpool 24 in. DU915PWP Built-in...
Whirlpool dishwasher has food particles baked on.
Heating element may fail. This will lead to the machine stopping part way through its cycle
Pumps. There are 2 pumps in most dishwashers. The drain pump,( which describes itself -it pumps the water out of the machine.)
The recirculating pump which forces the water at high pressure through the spray nozzles and arms. (This is how the cleaning action is performed)
These pump may either leak, or burn out. Either way, the only solution is replacement.
Mar 09, 2010 | Dishwashers
Kenmore elite dishwasher leaves food particles on dishes
If someone is putting dishes in the washer and obstructing the spray ams that would cause food to stay on dishes. After loading dishwasher and pushing in baskets make sure the spray arm doesnt hit any of the dishes causing them to not clean properly. If that doesnt work or is definately not your problem try removing the spray arm and seeing if it has food inside of it. Some times they get food build up in them and need to be flushed out.
May 12, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Film and food residieu remains on upper rack
Hi, is the wash arm underneath the upper basket turning freely and is it not blocked with any food particles? I've had items out of my dishwasher with a similar problem and it's been when the upper wash arm has been blocked or a spoon has fell through and prevented it from turning and washing properly.
Good luck.
Oct 04, 2008 | Kenmore 24 in. 16352 / 16354 / 16359...
Whirlpool GU2400XTP Built-in Dishwasher Logo
238 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
