Question about Whirlpool ARC4030 Stainless Steel Top Freezer Refrigerator
Whirlpool ARC4030 fridge freezer all lights flash and alarm beep
Our bulb went in freezer section, then alarm and flashing neons appear several times a day - even after replacing bulb, and now freezer section keeps warming up (dare not put freezer food in it) but fridge seems to be ok. Turned it all off for 1 hour but problem still persists, fans and all lights flash when doors open.
Has anybody got this same problem - or do you know the solution?
please help - its about 3 years old and no warranty
SOURCE: Whirlpool SD20 Freezer Intermittent Temperature Malfunction with Alarm Alert
Apologies, the above two guest comments are mine, not sure what happend!!
Posted on Nov 26, 2007
  • 263 Answers
SOURCE: Whirlpool Frost Free 460 door open alarm
http://www.repairclinic.com check how to repace it with the schematic diagrams you'll see how
Posted on Jan 01, 2008
  • 165 Answers
SOURCE: Fridge turns on and off and beeps
You need a tech to check the problem, it seems to be some kind of electrical short or, if the fridge has an electronic control module, it may be the source of the proble.
Posted on Jul 21, 2008
SOURCE: whirlpool gold refridgerator light not working and is making funny noise
Had the identical symptoms with my Whirlpool Gold GS6SHEXNB00 side-by-side refrigerator. Had a technician come on site, indicated it was the "circuit board/ timer" (Whirlpool part # 1394052). Board is accessible from behind fridge (lower left side in a white plastic housing to left of compressor).
Swapped the board out (noticed a scorched circuit on the old circuit board). Lightbulbs now work, temperature readouts also good to go.
Posted on Jul 30, 2008
  • 1462 Answers
SOURCE: got an american whirlpool fridge
may be a indication only but on many fridge-freezers, 2 flashing lines ,means power interuption
Posted on Sep 17, 2008
My Westinghouse freezer has an alarm beep that goes off every now and then and the only way to stop it is to turn off the fridge completely. In the fridge section the temperature panel flashes the...
Often these have door alarms. If the door isn't completely sealed shut then it will alarm and cause the temperature/thermostat to blink to warn of "warm" temperature inside the fridge
Mar 04, 2015 | Westinghouse Refrigerators
Whirlpool WBM39MW alarm when door opened
Just had one of these with the blinking light, fan pulsating and no cooling. The fault is the power supply section in the control module at the back. It is a 2uF 400VAC capacitor going open circuit. make sure you replace this capacitor with something equal or better rated - it is critical
Jun 17, 2012 | Whirlpool Refrigerators
I have a Whirlpool side by side fridge freezer with ice maker and water dispenser which is about 3 years old. Model number I think is WSC5533. Recently I had an interior lamp bulb blow in the fridge which...
HI,
You may have a failing door switch which is causing this problem, if you remove the bulb and close the door, the the red light out? If so, its possible you bulb is fine, you door switch has failed.
I hope this helps
Jul 26, 2011 | Whirlpool Refrigerators
Freezer temp. 3 green lights flashing.
the flashing lights can be fixed by first turning the fridge off at the mains then turning both dials to economy ( this results in the fridge making a ..beeping sound). finally turning both dials fully in anti-clockwise to the off or zero position ( resulting in the fridge light bulb - going off).
Then lastly turning the dials back to our desired setting....(bulb light comes back on)
Now we only have the center green light on and NO FLASHING.
Jan 19, 2010 | Whirlpool Refrigerators
Whirlpool fridge freezer ARC 4030?
Look to have the control module repaired / replaced.
Hope this helps
Dec 02, 2009 | Whirlpool ARC4030 Stainless Steel Top...
Freezer alarm and signal light comes on daily
The beeping and light indicates the need for a new battery (9v)
May 22, 2009 | Kenmore 20.6 cu. ft. Upright Freezer 24092
 if posible try turning off over night, if its ok when you start it back up after 24hours, defrost not happening, ice builds up air flow is restricted
Oct 18, 2007 | Whirlpool ED2FHEXN Side by Side...
Whirlpool ARC4030 Stainless Steel Top Freezer Refrigerator Logo
251 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
