Question about Kenmore 62602 Electric Dryer
Kenmore 90 Series Model 11060912990 Dryer won't start
When pressing the start switch, dryer sounds like it wants to start (as long as you hold the start button in), but it won't start, and eventually it stops even trying to start.
-Terminal block looks fine
-Start switch tested fine - contnuity only when switch pressed.
-Door switch tested fine - continuity with light when door open, continuity with the other terminal with the door closed.
-Timer Motor tested fine - meter read about 2400 ohms
-Thermostats tested fine - continuity found in both
-Centrifugal switch tested fine.
1-2 5-6 5-3
Out Continuity Continuity Resistance
In Resistance Resistance Continuity
Anyone have any thoughts?I have a 90 series dryer & when I push the start button the dryer won't start
  • hunt1328 Feb 16, 2009
    I have a 90 series Kenmore dryer that won't start when I push the start button.
    gopi20 suggests that I check the fuse......which is located where?
  • Kenmore Master
  • 19,396 Answers
There is a starter capacitor on the control board, near to where the start button connects to the board, that has blown, repair the control assembly or replace it.
You find replacements here.
Posted on Feb 17, 2009
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Most were tested, would there be a starting capacitor? If yes have you checked that as well?
Pls post back result/update. Good luck and thank you for using FixYa.
    Genius:
  • 2,920 Answers
Have you tested the motor itself to see that its operating correctly?
Posted on Feb 16, 2009
    President:
  • 1,214 Answers
There is a centrifugal switch inside the motor that must close also.
I suspect it has failed in some way. I do not know if it is user replaceable.
Reply back what you find. I am unable to find the wiring diagram for it at this time to confirm the connection points for you. I will be happy to help you further if you reply.
  • 137 Answers
The start switch on most dryers are "momentary" switches.
Did the circuit stay open after you released the start switch, or was only open when you held the switch? If it was only open as long as you held the switch closed I would say you have a faulty switch.
You sure tested everything, great job.
    Brigadier General:
  • 3,614 Answers
better to test the whole control board.
let me know
    Master:
  • 848 Answers
Check the fuse
  • gopinath pasupathy Feb 16, 2009
    thermal fuse located in back on the exhaust duct
    President:
  • 2,110 Answers
UNplug the dryer, pull it out from the wall, and remove the service panel. Use a flashlight and look around for signs of anything having burned, and smell around to see if you can identify what might be burning if you can not visually see any burning.
If you plug the unit back in while your back there, have someone start the dryer and see if you can see what might be the problem.
I am suspect the motor may be failing, but it's hard to see what's happening through these teeny-tiny little wires.
Where to find fuses. My dryer is not heating up.
Does your dryer have power? If yes, then check (1) the flow of air outside the house from your dryer tube and (2) your circuit breaker panel for each circuit in the house (I've not seen fuses/breakers built into dryers -- though that could change). Then check (3) your heating element, (4) thermostat, (5) high-temp thermal cutoff switch, and (6) for debris in the air flow path to / from from the centrifugal fan.
Here are 3 resources that helped me with my Kenmore Series 90 Dryer:
No Heat? - http://chris-doityourselfrepair.blogspot.com/2011/10/kenmore-90-series-model-110-clothes.html
Looking Inside My Dryer - http://chris-doityourselfrepair.blogspot.com/search/label/Disassembling%20Kenmore%20Dryer%2090%20Series
Exterior Exhaust Duct - http://chris-doityourselfrepair.blogspot.com/2013/08/cleaning-out-and-replacing-exhaust-duct.html
Oct 10, 2014 | Kenmore Dryers
My Sears Kenmore 90 Series takes too long to dry cloths
First you need to make sure that the lint trap is completely clean. I don't mean just taking the screen off and making sure there isn't lint on that. You need to take the cover off of the back of the dryer and remove the shute the lint screen slides into. That can be backed up and it's quite common. Also when that happens it tends to blow out the fuse that is located in the same general area. It's about an inch long, white, with two wires connected by plug on terminals. Make sure you unplug the dryer if you're going to check that. Remove the two wires and with an electrical tester check for continuity across the two terminals. If there isn't continuity you'll also need a new fuse, Hope that helps.
Mar 20, 2013 | Kenmore Dryers
Kenmore 90 series dryer..motor won't turn..hear the klicking sound..kind of hums...but won't turn. changed motor..same problem
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 11, 2011 | Dryers
Dryer doesn't always start, and doesn't keep running
your have a dieing dryer motor,weak weak to turn the drum anymore,the model number is inside the dryer door if you want to try and find one cheap on ebay-mike
Feb 23, 2010 | Kenmore Dryers
check motor (you have 2.4 Kohm ) very high read
for motor must be lower.Check capacitor if hawe.
Feb 15, 2009 | Kenmore 62602 Electric Dryer
Kenmore dryer replaced heting element now it does not blow any air
HI danon this dryer its common to have the blower wear out, it slides on the motor shaft, and what they do is wear out the flat in the blower. that could have caused the element to fail. check the blower thanks the appliance doc. please rate my answer. thanks
Sep 30, 2008 | Kenmore 62602 Electric Dryer
Kenmore Dryer 90 Series will start but suddenly stop...
what starts and stops? the entire dryer or maybe the drum? Do you do anything to make it restart other than pushing the start button? This initially sounds like a temperature switch is opening and resetting after it cools. If you can describe the problem a little more in detail it would help.
Jan 27, 2008 | Kenmore 659 Electric Dryer
Kenmore 62602 Electric Dryer Logo
87 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
