Question about AudioBahn A2300HCT Car Audio Amplifier
Ground wire burnt plactic cover on amp where wire goes in
Well i guess the ground wire had been making contact with the plastic cover on my amp where the ground wire goes in and has burnt the plastic cover on the the amp where the wire goes in and it also burnt the plastic cover on the ground wire aswell now my amp dont work .... how do you think i can fix this problem
  • Perry Babin May 11, 2010
    You should first 'try' to get a replacement from Audiobahn. If that's not possible and the metal of the block isn't damaged, you can straighten it and solder it back into the board but you'll need a relatively high power soldering iron.
    Does the board look damaged?
  • 55 Answers
REPLACE THE WIRE MAKE SURE IT DOSE NOT RUB AGAIN REPLACE FUSE IF THAT DOSE NOT WORK SOME COMPONENTS MAY HAVE BURNT UP HAD TO SAY WITH OUT LOOKING AT IT TAKE THE COVER OFF SEE HOW BAD IT IS GOOD LUCK
Posted on Feb 21, 2009
Changed starter solenoid and now mower won't start?
Make sure wires are not reversed on solenoid. If they are you may have to replace it again.
Mar 07, 2016 | Cub Cadet LTX 1046 KW 46" 21.5HP Kawasaki...
How do I wire 110v from a 220v box?
You have two wires in the box that will read 220 plus
volts to the ground wire,the box if grounded & to the
white neutral
So pick one of those wires,(black or red ) for your short
recepticle slot & gold screw & the white neutral goes to
the silver screw & longer slot
Put a wire nut on the other 220/240 wire, if it isn't going to be used
Have to ID the breakers for the wires first & know what is on
those circuits.
Will need to change the breaker out if your running a dedicated
120 volt circuit & then you will have an open space you will need
a plastic cover for, when you remove the 2 pole breaker
Nov 18, 2014 | Dryers
Just got 84 lasharo rv ac blower dont work cant find fuze
If a GM chassis and problem is dash air, remove the power wire from blower (under hood) & apply 12 volts directly in order to confirm blower even works. Next, pull blower relay harness & check for arcing/burnt wires & contacts (usually the culprit this year GM). If good, trace wire to relay and check for 12 volts at relay (be sure to use a test light) and do this across the ground and power wires to relay and, relay to blower. Bad grounds and burnt contacts on relays are more of a problem than fuses during these years.
Oct 26, 2013 | Cars & Trucks
My brother mfc 440cn had a paper jam & after i removed the paper "unable to print 50" & "unable to print 30" showed on the screen. i went to brother web site & went to the...
You have to open the printer and set it back into the ph carrier.
1) Remove Plastic wire covers from inside printers, and release plastic stay on lower edge, tilt cover to 90 Degrees 2) make a note of where each connector goes 3) release the Ribbon and 3 Multicolor cables, removing grounding screw, then remove scanner module by sliding it off the hinges at 90 degrees. 4) Remove Three Front Panel Screws, carefully leaver front panel upwards releasing front side clips.5) Remove front panel by disconnecting ribbon and wiring on both sides.6) Remove 6 Screws (2 on back, three at front and one middle right7) Carefully remove speaker cable (Red Connector) and lift up plastic casing, leaving printer uncovered.8) Re-Seat Encoder Strip.9) Re-assemble in reverse.
Nov 08, 2011 | Brother MFC-440CN InkJet Printer
2006 Chevy Equinox Smoke emitting from the steering column with smell of burnt plastic. I have popped off the harness cover but not been able to deduct source of smell or any damaged...
Turn signal switch is common issue, the plactic melts when the contacts overheat. look for discolored or malformed plastic, near wires and contacts.
Sep 21, 2010 | Chevrolet Equinox Cars & Trucks
2002 cadillac escalade, when i turn my headlamps on the dash lights go out
My guess is the head light switchitself is bad. Some headlight switches burn their own terminals off. Pull the cluster bezel (a Haynes manual shows how - get PN 36058 w/light blue cover), then the headlight switch & inspect the connector for signs of heat. If it's burnt, you'll need a new switch & at least a replacement wire terminal - probably the big plastic connector, too.
Hope helps (remember rated this).
Aug 12, 2010 | Cadillac Escalade Cars & Trucks
The main problem I have having is I am getting power to my AMP but no power to the subs. I tested my AMP and subs in another car and everything worked so I know my hardware all works fine. I had someome...
okay , well you need to make sure all your conections are in the right spots, and that your IN LINE FUSE, between your amp and battery, the big glass one is not burnt, just take a look at the metal piece inside , if its a sold metal piece its good, if its burnt in half like a broken bridge it needs to be replaced. the next thing is the fuse on your amp, you need to make sure it is not burnt also. Check your remote that it is hooked up to the right wire. then check that your sub/speaker wires are connected properly and secure. YOUR GROUND WIRE IS HUGE HERE also. MAKE SURE IT IS GROUNDED TO A GOOD SPOT, YOU MAY HAVE TO MOVE IT AROUND A FEW TIMES TO FIND A GOOD GROUND!!!! if you check all of these things, it should work fine.. you can fiddle with your amp and bass settings levels. turn em up so when it works you know it, but not too much you dont wanna blow nothing :)
Mar 12, 2010 | Car Audio & Video
Audiofonics adf-241 no power all wires connected fuses ok.
Hello pimprascalz,
Many amps will go into protect mode if one of the speaker wires is shorted or grounded, or if the voice coil(s) are defective. Try disconnecting the speaker wires one at a time and see if the amp still goes into protect upon power up. Likewise, some amps will go into protect if one of the inputs is grounding out. Again, to troubleshoot, disconnect them one at a time and try the amp. Next, make sure that the amp itself is not grounding. Most amps need to be mounted to a nonconductive surface. If the case contacts the frame of the vehicle, it can cause a problem. If the problem is not in the speaker wires or the input cables, the amp case is not contacting the vehicle frame, and you have checked your power, ground and turn-on leads, then the amp itself is probably faulty.
Hope this helps.
May 19, 2009 | Audiofonics ADF-241 Car Audio Amplifier
Ground wire has burned plastic cover on my amp
what type of terminal is on the amp. screw or slip on type?
The plastic does not carry any type of ground. If your ground wire was melted, that means you have a 'hot' wire shorting across the ground somehow causing a short. This causes excessive heat like an 'arc' welder.
You might want to check your power wire to make sure its not making any contact to ground. Make sure any foreign debris is not causing a 'bridge' between the 2 posts.
If your terminals (or place where you hook up power and ground wires) are in good shape, re-wire and turn on the unit.
Feb 16, 2009 | AudioBahn A2200HCT Car Audio Amplifier
GOODMAN MODEL CKJ30-1A
I think you mean compressor rather than condenser. Take the panel that covers the controls off the unit. If the clicking noise is the contacter, and it is engaging when the power is turned on, then follow the wires to the compressor, remove the little plastic cover and look for wires that are burnt or otherwise not making contact with the compressor terminals. If the wires are good and you have a volt meter, set it to ohms, TURN OFF THE POWER, remove the wires on the compressor. (remember where C,S,R, goes) touch the meter to any 2 terminals on the compressor. They all 3 should have continuity to each other. No continuity=new compressor. If the contacter is not making the clicking noise when the power is turned on, then you have another problem that I'll need more info. to help.
Jan 01, 2008 | Heating & Cooling
AudioBahn A2300HCT Car Audio Amplifier Logo
102 people viewed this question
Top AudioBahn Car Audio & Video Experts
Tygh Duval
Tygh Duval
Colin Stickland
Colin Stickland
Jerry Naidoo
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
