Question about Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV
SONY WEGA KDF-50WE655
REPLACED LAMP BUT TV DOES NOT LOOK AS SHARP AS BEFORE..I DID ACCIDENTLY TOUCH THE LAMP AND PUT 2 PRINT MARKS ON IT ..I WAS GOING TO CLEAN THE LAMP WITH GLASS CLEANER BUT WAS AFFRAID OF DAMAGING IT.. CAN THE LAMP BE CLEANED ...
  • 1 more comment
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    regarding sharp picture as it was before, clean screen from inside and there would be One Lens and Mirror too to clean.
    There is no need to clean lamp surface but in case you want to clean lamp, do it with dry cotton cloth.
  • Mark Egan May 11, 2010
    Clean the lamp with alcohol. But if you've turned it on already, the damage has been done. Clean it anyway.
    There is probably a focus alignment, either mechanical or electronic, but I am not familiar enough with the TV to describe or help you further.
    Novelist:
  • 184 Answers
Did you replace your lamp with a generic lamp? Many generic lamps do not produce as much light as OEM lamps do. Also, you may have a separate issue causing the picture to appear less clear than before. Check my solutions to other Sony LCD owners who have had problems with their optical blocks( light engines)
michtech
Posted on Feb 16, 2009
I HAVE REPLACED MY BULB OM MY KDF-50W655 AND MY TV IS WORKING AGAIN, BUT I HAVE TRYED TO RESET THE TIMMER TO THE BULB THRU NMY CONTROL....BUT CAN'T SEEM TO MAKE IT WORK...
I have installed the new lamp and the the led power light comes on green and than turns flashing red. What is the next step in this repair?
Mar 21, 2011 | Sony Grand WEGA KDF-50WE655 50" Rear...
My Sony 3LCD tv picture and sound goes on and off, what's wrong?
How old is your TV have you replaced the lamp already this lamps are made to last a avarge of
2-4 years of use if you have not replaced the lamp before that would be the first thing to do but if you already replaced the lamp recently and have this issue then it will be a BALLAST issue
I found the lamp you need just incase
http://www.discount-merchant.com/SearchResults.asp?Search=KDF-50WE655
PLASE RATE THIS SOLUTION AS I DO THIS FOR FREE !!!!!!
Oct 13, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
I turned the tv on. The green power/stand by
Question shows its Sony KDF-50WE655 dlp tv that has lamp inside and it seems its time to replace lamp.
Did you replaced lamp in tv recently?
If not, replace it. Lamp replacement procedure would be written in user manual and please buy Sony original lamp for better result.
Thanks.
Mar 04, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
I replaced the lamp and my tv still don't work
i have a sony kdf-50we655 tv and replaced the lamp. it still does not work green light blinks and then it powers down right away.
Feb 25, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Replaced lamp in Sony Wega tv - Sony xl-2400. tv
hello make sure the lamp and the cover is fitted securely, when you've done this the tv should be ok
shaun
Nov 09, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
KDF 50WE655
3 times blink means Lamp Cover is not placed back that was removed while replacing lamp, make sure lamp cover is fixed securely in its position.
Thanks.
Sep 28, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
How do I replace the lamp in my sony lcd projection tv Sony Model kdf-50we655
TV has 2 thumb screws on lower corners, loose these screws and take off lower front part, there is lamp cover under that removed lower long part at TV front, remove lamp cover, lamp is in front of you, lose its screws and pull it out.
Slide new lamp and put things in reverse order, job is done.
Lamp replacement procedure is also mentioned in User Manual of TV and if you want to download copy, click Sony Support.
Thanks.
Sep 27, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Overheat issue on kdf-50we655 sony tv
http://www.techlore.com/article/15444/Understanding-Sony-Television-Blinking-Codes/
this link tells about the blinking and how it's an self-diagnostic system that the tvs are programmed with. the number of blinks indicates the problem.
Jul 27, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Tv shutting off then comes on
your lamp is going out, they last around 2 years, on the average, this is easily replaced by you, door is on the right side of the tv, you can take the lamp out, if it has a bubble on it, it is getting ready to go out
Jan 09, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV Logo
87 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
