Question about Apple iPod classic MP3 Player
Ipod is frozen...will not even connect to the computer.
The computer and connection are fine as other ipods still work.  This ipod was connected to my car.  The screen is sort of split at the bottom.  half says the last song playing, other half says ok to disonnect?
  • 728 Answers
Try this which should reset your ipod: First, toggle your hold switch back and forward and put it back to the off position. Then press and hold the menu button and the center button simultaneously for about six seconds and the screen should go blank and the apple logo should appear. After that it should work.
Posted on Feb 16, 2009
  • 3 Answers
When my ipod nano kept freezing i was told to flick switch so that it is unlocked, then hold down the menu button and the middle button until the apple appears on the screen. after this my ipod worked fine, and it doesn't delete your files either.
  • 268 Answers
Try this which should reset your ipod: First, toggle your hold switch back and forwardand put it back to the off position. Then press and hold the menu button and the center button simultaneously for about six seconds and the screen should go blank and the apple logo should appear. After that it should work.
Posted on Oct 18, 2011
My ipod is frozen and the buttons dont work the unlock button is frozen and the ipoda1236 EMC no. 2174 screen wont turn off
Hi lastonsarah
If you have forgotten the code or put the wrong code in your ipod, you can unlock the Ipod by doing the following:
Connect your IPod to the primary computer you use it with (the first one Ipod synced with), and open iTunes.
When you disconnect iPod from the computer, it will no longer be locked.
If you can't unlock Ipod using either (the code or connecting it to the computer you use to manage its songs). . . you can restore your ipod to factory settings using ipod Updater.
Please note that this will erase all data on your ipod.
Afterwards, you can add your music and data back to your ipod.
If you want to change the primary computer that your Ipod is associated with, do this:
1. Restore your iPod. WARNING: The restore process cannot be undone.
All of your songs and files will be deleted.
Always make a backup of your important data.
2. Connect your ipod to the computer that you want to be the primary computer.
3. Open iTunes and synchronize.
If you can't unlock your ipod and you don't have access to the primary computer, your only option is to restore the Ipod, which will erase all music and data.
Please take time to rate me
Bud
Apr 22, 2013 | Apple IPOD 8GB MODEL NO. A1236
Tip
The battery of my iPod is not charging
<p>When you buy an iPod, the device comes with cables that connect the charging device to the computer. When the iPod battery is low, you can recharge by plugging into your desktop or laptop. But sometimes, when you connect your iPod to your computer, the battery charger. According to Apple's site, some problems may prevent your iPod from charging properly. <br /> <p><br /> <p>1. Connect your iPod USB charging cable only one USB port on the computer itself. External port devices, such as a USB hub, do not provide enough power to recharge your iPod. <br /> <p><br /> <p>2. Connect the iPod firewire charging only one firewire port on your computer. Like USB, Firewire ports are not enough of a load to the battery of your iPod. <br /> <p><br /> <p>3. Disconnect the computer from sleep when the computer set to sleep after a certain time. An iPod can only load on a computer that is connected and not in sleep mode. To enable sleep mode on most computers, you can move the mouse or press the power button once. Hold the power button, which usually turns off the computer. <br /> <p><br /> <p>4. Turn the iPod off and on when the unit is frozen. A frozen iPod is not charging. If the unit is still frozen when you turn it on again, restart the iPod by pressing the "Hold" switch to "On" and then back to "Off" and press and hold a "Menu" and "Select" buttons simultaneously or " Start "and" Menu "button. Hold the buttons until the Apple logo appears on the screen. <br /> <p><br /> <p>5. Set the system up-to-iPod charger so that when using a Windows 2000 computer. In preparation for the system to load the iPod device to the unit with the charging cable, launch iTunes and "iPod" in the left pane to "Settings" tab to go, check the box next to "Enable Disk use", and click the "Apply" button. Once the configuration is in place, the iPod will charge as normal. <br />
on Aug 09, 2011 | Apple iPod touch
Why isnt my ipod charging?
iPod's battery doesn't charge
Several things could keep your iPod's battery from charging. The major causes are listed below in logical order. Check each one to see if it's what's keeping your battery from charging.
Low-powered USB port
iPods that connect to USB ports require a high-power USB port.
Keyboards and some USB hubs will not charge iPod. Connect iPod directly to the computer or to a USB AC power adapter. Click here for more information.
Connect directly to computer
If you connect iPod to something that connects to the computer (like a USB hub or FireWire drive), connect iPod directly to the USB or
FireWire port on the computer.
FireWire port on a Windows PC
The FireWire (IEEE 1394) ports on some Windows-compatible computers may not be powered, and consequently won't charge iPod when you plug it in. Check here to see if the FireWire port on your PC can charge iPod.
Your computer goes to sleep
Your computer can only charge iPod when it's turned on and not asleep. Make sure your computer is on and not set to go to sleep when you want to charge iPod. Tip:
Some Macintosh computers can charge iPod even though they're asleep.
If your sleeping computer doesn't charge iPod, don't worry, just wake it and let iPod charge.
hope this helps
Aug 14, 2012 | Apple iPod touch
IPOD 2GB Nano display doesn't work
try pressing the reset button on the ipod. if it still freezes, the ipod has problems
Jul 31, 2010 | Apple iPod nano
My ipod it showing a message that of : connected
If your ipod is frozen on the screen with this message then you might have disconnected your ipod from computer while it was either syncing or playing.
Anyways, make sure your ipod is not connected with the computer and on the ipod, press and hold the middle and menu button together until you see an apple logo on the ipod's screen.
Let go the buttons when the apple logo appears on the screen. That step reset your ipod and in most cases that fix the issue.
In case you still have the same problem even after that step, then call AppleCare at 1800-275-2273
Hope that answers your question
Apr 05, 2010 | Apple iPod nano
My screen is on language selection and does not let me scroll or anything i think its frozen.
If your iPod is frozen or won't turn on, the steps to reset it vary by model.
  1. Toggle the Hold switch. To do this, slide the switch to Hold (an orange bar appears) and then slide it back (orange bar is hidden).
  2. Reset the iPod by holding down the Menu and Center buttons for 10 seconds.
    • If the Apple logo appears on the display, connect the iPod to a computer and verify that it appears in iTunes and can play music. If the iPod appears in iTunes and can play music, no further troubleshooting is needed.
    • If the Apple logo does not appear or the iPod is not seen in iTunes, connect the iPod to a power source by either plugging it into an Apple iPod USB Power Adapter or directly into a computer's USB port.
  3. Let the iPod charge for at least 20 minutes. Note: If the iPod is connected to a computer, make sure the computer does not sleep, standby, or hibernate during the 20-minute charging period.
  4. After the iPod has charged for at least 20 minutes and while it is still connected to the power source, toggle the Hold switch again as in step 1.
  5. Try resetting the iPod by holding down the Menu and Center buttons for 10 seconds.
    • If the Apple logo does not appear or the iPod is not seen in iTunes, try putting the iPod into disk mode and restoring.
  6. Try putting the iPod into disk mode.
    • While in disk mode, connect the iPod to iTunes and try to restore.
    • If the iPod is still not recognized by iTunes, the iPod should be serviced.
    Hope i helped you.
Thanks.
Aug 06, 2009 | Apple Ipod Nano Second Gen. Green (4 GB)...
Its frozen and the buttoms are not working
Please wait for your ipod to discharge all the power it has.it might even take 2-3 days to discharge the power Then after the ipod is completely empty (which means its off and needs to be charged) you can connect it to your computer. Please make sure your computer is scanned from viruses. You can also scan your ipod from viruses. Never unplug your ipod before it completes synchronizing. You dont need to worry! its normal for ipods to behave that ways :)
Jun 02, 2009 | Apple iPod nano MP3 Player
My Computer and iTunes does not recognize my iPod Touch
Try resetting it while it is connected. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears.
If you have not already tried, I would also try the other ports on the computer.
Are you running iTunes 8?
And what kind of computer do you have?
Jun 01, 2009 | Apple iPod touch
Ipod problems
First and foremost, make sure you have the latest software INSTALLED.
If your iPod is frozen or won't turn on, connect your iPod to your computer, then press and hold the "Menu" and "Select" buttons simultaneously for 10 seconds to reset the iPod. Resetting an iPod will not affect your files or preferences.
If your iPod fails to hold a charge and it's more than a year old, you may need a new battery. If it's under a year old, I would suggest sending it in for repair.
Oct 14, 2007 | Apple iPod shuffle MP3 Player
Apple iPod classic MP3 Player Logo
111 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
