Question about AudioBahn A2200HCT Car Audio Amplifier
Ground wire has burned plastic cover on my amp
Well i guess the ground wire was kinda loose and the wire was making contact with the plastic cover in witch the wire goes into on the plastic cover on the amp and it has melted the plastic cover on the amp where the ground goes in and the plastic cover on the ground wire aswell what can i do 2 fix this problem
    Problem Solver:
  • 10 Answers
What type of terminal is on the amp. screw or slip on type?
The plastic does not carry any type of ground. If your ground wire was melted, that means you have a 'hot' wire shorting across the ground somehow causing a short. This causes excessive heat like an 'arc' welder.
You might want to check your power wire to make sure its not making any contact to ground. Make sure any foreign debris is not causing a 'bridge' between the 2 posts.
If your terminals (or place where you hook up power and ground wires) are in good shape, re-wire and turn on the unit.
Posted on Feb 16, 2009
Changed starter solenoid and now mower won't start?
Make sure wires are not reversed on solenoid. If they are you may have to replace it again.
Mar 07, 2016 | Cub Cadet LTX 1046 KW 46" 21.5HP Kawasaki...
What causes the TV to go black and then when I touch the back it comes back on
Loose wire or a short in a wire. Open back of TV and proceed with caution and observe the area in witch your concern may be and check for loose wires or wires that maybe split or broken also check ground wires and make sure they are tight be carefull not to ground any wires as this can damage or completely destroy your component..
Dec 12, 2014 | Televison & Video
Anybody know how the horn wiring behind airbags is supposed to go? 1998 Chevy cavalier 2.2L. I'm replacing the airbags cover and don't know where the wire and ground goes...(
It is really very simple. The horn lead with the plastic connector and the spring pushes in and turns to lock in the large round hole at the upper left center of the steering wheel. If you look into the hole, you will see the contact down in there with a plastic "tube" with a slot in it for the horn connector to go into.
The ground clip (wire with brass or steel clip on it) simply pushes into the hole in the steering wheel center near the bottom (It grounds to the steering wheel center).
Feb 21, 2012 | 1998 Chevrolet Cavalier
Batterys corroded clean up contacts now unit does not power up
Jenko, How bad was the clean up of the battery contacts, lot of corrosion? Now it possible to have broken wire to the battery compartment.
If you are mechanical inclined and have some experience with electronic. Here what you do. Remove the front lens. There will be four screws on a concentric ring. Remove the screw and the ring. This unit comes apart in the approx middle. Also, from the front end look for a white Teflon ring with one screw it goes around the image intensifier tube. Remove the screw this will allow the image tube to ability it to move back along with the rest of back frame Be careful here all the wire are white Teflon coated ,all the same color. These wires are HV, and are rated at 2KV with small current. There's a battery tube on the upper right of the back housing. Lots of wire that go to the two switches. Take a pick and gently remove some of the rubber trim cement that was used. The only wire to be concerned about is the ground wire. The positive wire you can see from the back of the back frame housing. There is a aluminum ring that is threaded for the battery cap. Now there is slot cut into the battery tub just under the aluminum threaded ring, you can see the wire. This is the positive wire.
If you don't have the room, remove the plastic cover over the on/off and IR witch cover. There will be six little screws under the plastic cover, remove the screw and the back plastic switching component can be remove the from inside. Make sure all the cement has bee remove.
It is really critical here. take some wire indicators tags. make a picture of the printed circuit board and every where a wire is attached put a tag on the wire and mark the location on the your diagram where that one with its tag is locked. Your are going to find that there are many ground wires to different shielding plates. I can't says it enough, mark those wire and its location on the printed circuit boards
If you need to remove the green image intensifier tube. There a wire teflon cap and cover that goes the voltage multiplier around the image tube. Just gently pull down the white cap, and turn it inside out. Take small pick and remove dielectric jell from inside the cathode. One the jell is removed, then gently pull on the white wire and it will pull out about 3/8 of inch. The voltage multi-
plier ignitor wire is solder to the cathode wire, desolder it. All components then can be laid out.
Check for broken wires. send me another message and I will tell you components to check and how to fire the cathode ignitor. stewbison.
Aug 04, 2011 | Night Owl Optics Cyclops Compact NOCC3...
How do I remove the wires from an existing wall phone jack and then rewire to a new jack
pop the front cover off write down witch color wire goes to witch letter on the plastic change to same, most phones line need two wires green and red, but 4 are hooked up black and yellow, for a second line, hook them all up just in case the other wires had a problem and the phone company switced to the other two
Sep 09, 2009 | Lands Phones
Brake light goes out and seems contacts from it being plastic is the problem. Bulb is good could it being contact overheating?
if u unplugged it from the rear light you should see terminal 1 (brown wire) being chaffed and loose. this is the ground wire. make a a new terminal and ground it to the rear light itself, u should see a male pin coming out of the aluminum chassis (fix it there). This should solve your issue.
Jun 20, 2009 | 2001 BMW 5 Series
One of my turntables only has sound coming out of left speaker..
one of your phono leads ether red or white is nakered.plug them in one at a time and see witch ones workin,then youll no the dodgy one.when you pull out leads from your mixer you can sometimes break cables free from the fittings if pulled by the wire.you wanna re soilder a new lead on to deck or pull back the sheath plastic covering the fitting and reconnect the cables(the insulated wire goes to the pin an the uninsulated goes to outside ring)gd luck
Jun 13, 2009 | Technics SL-1210 Turntable
Electrical problem with the dash.
This wiring problem can be much more costly, and time consuming, than you want to take on.
Professional mechanics cringe, when a wiring problem of this magnitude comes their way!
It's probably a bad ground for the instrument cluster.
The instrument cluster housing is plastic. There is a flat, thin, 2 to 3 inch wide, piece of plastic that is the wiring harness for this instrument cluster.
In this flat piece of plastic, are thin flat copper strips. These are like wires, to conduct the electricity to the gauges, lights, and the rest of the instrumentation.
Since the plastic instrument cluster is not metal, and therefore it can't be used as a Ground source, the flat piece of plastic I mentioned above, has a Ground wire to it. May be more than one.
This ground wire/s could have corrosion on the terminal end, where it attaches to the truck body.
Bad ground, everything goes haywire. The ground wires, might loose on the terminals used for the flat piece of plastic.
Another source of a bad ground problem overlooked, is that the cab of a truck receives it's,
Main ground from the engine.
There should be Two ground straps, coming from the firewall over to the engine. Sometimes, when the upper part of an engine, or the engine is replaced, the mechanic neglects to reinstall these ground straps.
Sometimes just one ground strap is reinstalled, and this is No good!
Also both terminal ends of these ground straps are a good source for corrosion to develop.
Corrosion makes a bad contact.
I myself would take the truck back.
Apr 19, 2009 | 1998 Chevrolet S-10 Pickup
Ground wire burnt plactic cover on amp where wire goes in
REPLACE THE WIRE MAKE SURE IT DOSE NOT RUB AGAIN REPLACE FUSE IF THAT DOSE NOT WORK SOME COMPONENTS MAY HAVE BURNT UP HAD TO SAY WITH OUT LOOKING AT IT TAKE THE COVER OFF SEE HOW BAD IT IS GOOD LUCK
Feb 16, 2009 | AudioBahn A2300HCT Car Audio Amplifier
AudioBahn A2200HCT Car Audio Amplifier Logo
293 people viewed this question
Top AudioBahn Car Audio & Video Experts
Professor_V
Professor_V
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
