Question about Meade LX200R 8 in. (600 x 203mm) Telescope
Smart drive won't work
The smart drive on the telescope wont work. I checked the adapter and replaced the battery, but when I switch it to own nothing happens.
What eles can I check?
  • 3,186 Answers
Sorry for late response -- I just found your posting.
You did not say which Meade telescope you have -- however-
There should be a light somewhere on the telescope that lights up when the power is on-- if this is not glowing-- double check your batteries-- better yet use an outside 12 volt power pack and the proper Meade cigarette lighter style plug.
No power --- nothing will work-- Meade has a customer service phone number here-- on their web site-
http://www.meade.com/support/contact.html
Posted on May 20, 2009
Fisher and Paaykel Smart Drive 708 not working once filled with water.
You need to check your lid switch & out of balance switch for
corrosion and replace if faulty.
Your out of balance switch is under the big yellow motor controller
OOB switch Is where the grey plate is on this picture.
Mar 03, 2013 | Fisher and Paykel Washing Machines
99 sable won't start, replaced battery,starter,alternator, but still wont even crank. code reader also said map sensor so it was reset worked for alittle but now nothing
If the car does not have a security system, I would check for voltage at the starter from the battery and from the key switch.
The power from the key switch goes thru the neutral safety switch before getting to the starter.
Sep 06, 2012 | 1999 Mercury Sable
My camera wont come on
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Nov 27, 2011 | Nikon Coolpix S203 Digital Camera
Hp nc4200 won`t start
There could be a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
If this did not work, try also disassembling the laptop & make sure that all main components are seated properly. Also make sure that all ribbon cables interconnecting the various components of the laptop are tightly connected.
Dec 28, 2009 | HP Compaq nc4200 Notebook
Autostar wont turn on
Unless Sam's has a batch of all bad telescopes???? Check that you put the batteries in correctly. You may have one or all reversed?
and or try a separate 12 volt power source if they included a cable. If not return the scope again!
Nov 15, 2009 | Meade DS-2114 ATS (325 x 114mm) Telescope
IBM thinkpad T30.The power button turned on then nothing boot up power LED light is on.Some time it boot up and run but then it won't do it nextime after it been power off. Battery for BIOS is good, Main...
There could e a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
Try also to reseat the main components of the notebook: the battery, the AC adapter, the memory modules, & the hard drive.
After that try switching it on & see if the problem was fixed.
Nov 14, 2009 | IBM ThinkPad T30 2366 Notebook
Initializing Smart Drive... forever
I have a similar telescope, and there is nothing that gets dislodged by nudging. HOWEVER a major problem is with the Declination drive gears. They are plastic and can loose a tooth really easy. If the is a problem, then you should hear 'skips' when the drive is moving the motor. Smart drive moves the telescope to read the feed-back position dist, and to see the 'home' position magnet. If the sensor is out of place then it will do as you see.
Aug 20, 2009 | Meade LX200GPS Telescope
Total loss of power from battery compartment
There are a couple of things you can try to get it working again. First double check the battery orientation so that they are in the right direction then pry out the battery terminal tabs slightly to get better contact.
If it still doesn't work, try connecting to an external battery or AC adapter if you have one. If it works that would eliminate the power switch as a problem and isolate it to a battery compartment problem.
I own a couple of the Nexstar telescopes and I only use the internal batteries for quick testing. I always go with either an external battery or power adapter when I'm using it outside for observing. It gives you more consistent and reliable power than using the small batteries. The external battery I use has a ******** it, so I droop it across my tripod. The added weight creates better stability.
I hope this helps.
Good luck and clear skies!
-jodair
Mar 18, 2009 | Celestron NexStar 8i (600 x 203mm)...
Power getting to laptop but it won`t switch on
I am giving you a step which you should try once and see if it makes any difference.
Method (Power cycle)
You need to remove the battery, adapter and any other device connected to the computer (May be any additional cards or any wires as for Ethernet or speakers or external mouse/keyboard).
Nothing should be connected at all.
Now Press and hold the power button for 25 seconds (It wont show anything). This is a step to release any static charges developed, which may surely caused the kind of issue you are facing.
Now connect the battery and the adapter and check whether it works or not.
Let me know the response as well.
Hope this should help
Regards
Sammy
Sep 03, 2008 | Computers & Internet
Meade LX200R 8 in. (600 x 203mm) Telescope Logo
120 people viewed this question
Top Meade Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Experi
Level 1 Expert
Greg Cann
Greg Cann
Are you a Meade Optic Expert? Answer questions, earn points and help others
