Question about Cuisinart Coffeemakers
The male plug in the base of the pot has broken
Where can I buy parts? or is a direct solder job the only way to keep using my fovorite coffee pot?
  • 1 more comment
  • adunn509 Feb 16, 2009
    Hanover, VA not far from Richmond, VA
    the electrical probes in the base of the coffee pot. one broke the plastic and pushed in under the pot,
  • adunn509 Feb 17, 2009
    they sell replacement componets, but not the part I need,
    thanks
  • royzee May 11, 2010
    hi where are you?
  • 134 Answers
Hi
if you go here
http://www.cuisinart.com/parts_accessories/index.php?cat_id=3
With your model number you should be able to order direct
Good luck
Posted on Feb 16, 2009
How can I fix my 55 cup Farberware coffee urn FSU 255 model and it won't turn on. Any suggestions? It's always worked well before--this is a new issue.
If it will not perk or even get warm, the main heating element (usually in the middle of the pot) is probably bad. Get an ohm meter and read the resistance directly at the pot terminals (looking into the pot) (before taking the pot apart). If you get a infinite reading (or in the thousands of ohms), the perk heating element is probably bad. On my small pot, that element appears not to be replaceable...but pull the base off and see.
If you pull the base off, you will likely see three components; main perk heating element in the middle of the pot, "keep warm" element - may be covered in braid) skirting the edge of the pot, and finally the thermostat that allows the pot to perk for 7 minutes then opening up the circuit to allow current to both of those elements in series just to keep it warm.
Although I don't have a pot exactly like yours, in my smaller pot, the "keep warm" element (covered in braid) and the thermostat (little button pressed by a spring and screw against the bottom of the pot to sense temperature) can be replaced...go to Goodmans.net.
Jul 23, 2014 | Farberware Coffee Makers & Espresso...
Why doesn't percolator run long enough
The thermostat in the base of the pot needs replaced...it is the little round thing pressed against the base of the pot. (You can see it after removing the base of the pot.) Pull off the leads and remove the screw holding it in and get a new one at goodmans.net ($10 including shipping...I just got one from them.)
You should take a picture before removing anything to make sure that you get the leads connected up correctly.
You have a main perk element and a keep warm element in the base of the pot. Plus a thermostat pressed against the bottom to sense temperature. Upon plugging in a cold pot, the thermostat reads zero ohms and applies 120 volts all to the perk element. Then when the thermostat senses a high enough temp, it opens and 120 volts is still applied to the perk heating element, but this time through the keep warm element (about 200 ohms or so). So now the perk element although hot is not hot enough to continue perking, just keeps your already perked coffee warm.
On a cold pot, you should read about 17 ohms looking into the pot...on a warm pot (with the thermostat opened up) you will read in the hundreds of ohms.
May 11, 2014 | Farberware FCP280 Stainless Steel...
3 prong plugs becoming loose
Hi, You have a pot that was made in China. to fix the problem you have you have to replace the base. You can try to get one at Goodmens.com or Repair Shop.com. The China pot is very very inferior to the USA pots. I suggest buying a USA pot on eBay. The China pot is like owning a boat. Good luck . Ron
Jul 23, 2010 | Farberware FCP280 Stainless Steel...
Hi, My coffee pot just stopped working. When I plug it in, it doesn't do anything. I used to make coffee pots at General Electric and know not to get it wet. I don't have this one too long. Any...
Did you leave the house while it was pluged in? If so you need a fuse. Easy job, take the base off and you will see the broken part. Go into eBay and go to Farberware coffee parts, You will get all the parts you need and all the answers. Ron
Jul 03, 2010 | Faberware FCP280 Coffee Maker
My amp fell forward and the (knob side) hit the ground. Now there is no sound, but everything lights up.
You have probably broken some of the pots. You will need to take it in to be serviced or if you have experience take the amp apart and take the circuit board out. Examine the solder side where the control pots are. Hopefully you didn't break the pots themselves and the solder joints just need to be redone. Also look for broken traces near the pots. They look like little roads which they are for electrons.If they are broken you can bridge them with short pieces of tinned wire and if the circuit board is cracked it can be Crazy glued. Look for all the broken parts and don't miss any. If the pots are broken, Take the broken ones into an electronics supplier and ask for exact replacements. If its a tube amp look for tubes that are loose in their sockets and broken tubes. Absolutely do not work on the amp with it plugged in to the wall (no power running to it) If its anything worse than that, take it in to be repaired as you need schematics, test equipment and direct replacement parts to do a proper job. Hope this helps.
Aug 27, 2009 | Music
Doesn't perk long enough
Hi you have a pot made in China, 1 of 2 things are broken. 1 the thermostat, 2 the keepwarm element. 9 out of 10 times it is the thermo.You can not buy them in the USA. I have a auction on eBay and I cab make the parts out ob USA parts. Mt eBay name is ron622c, you can take a look. Go to Farberware coffee pot parts. Good luck. Ron
May 22, 2009 | Faberware FCP280 Coffee Maker
Broken cable tv port on Mitsubishi CS-27209
Yes but repair shop charge alot
for this , and it's easy repair .
You can buy some solder , 40 watt soldering iron , Male coax plug from Radio Shack and
resolder two connections and save 100.00
RADIO SHACK HAS THEM
IT ,
Dec 16, 2008 | Mitsubishi CS-27209 27" TV
I need the plastic base for a Faberware FCP 240-A 4 cup Percolato
ok heres a simple fix if you dont have the money for replacement or cant find parts
J.B.weld from auto parts store this stuff if strong enough to fix a cracked engine block so im sure the pot can get fixed this way
Dec 06, 2008 | Faberware FCP240 Coffee Maker
Broken see thru knob P/N 30595
you can try using rear view mirror adhesive, available at auto parts stores. Get it very clean with alcohol first.
Jun 10, 2007 | Faberware FCP512S Coffee Maker
Plugged hose that has the "ball in the cage"
Why can you not find a replcement pot for this coffee maker
Jan 01, 2007 | West Bend 56870 Coffee Maker
Cuisinart Coffeemakers Logo
35 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
