Question about Westinghouse 22" Widescreen LCD Flat Panel Monitor
Computer monitor wont turn on
I have an Westinghouse 22 in model l2410nm and it stopped working. Power wont cycle on at all. I am at a crossroads, is it the inverter or another solution? Thank you in advance
  • bluize70 Feb 16, 2009
    Have the xact same problem just today. can't figure out how to get the damn case open on it...removed three screws on bottom but cannot open the case... any ideas?
  • MariaMUll Feb 17, 2009
    Montior just stopped working and while it is powered up[ it gives a message that says checksource and connection. It is connected properly and turned on but it will not display. Frsutrating for sure.
  • 3,051 Answers
Hi there :
You may want to want to check with the manufacture but some of these have a i fusable link in them my triton had the same thing happen and i called the manufactue and got the location for it and and replaced it my self .. hope this is of some help regards mike
Posted on Feb 16, 2009
Westinghouse monitor l2410nm display comes on then dissapears
you must check the power supply board, look for a bulging electrolytic capacitor which may cause of voltage drop.
Mar 29, 2013 | Westinghouse 24" L2410nm 1920x1200 16:10...
22" flatscreen LCD Westinghouse TV.
try use a lowest resollucion 720p and after change to 1080
Sep 20, 2011 | Westinghouse 22" Widescreen LCD Flat Panel...
My new Westinghouse Widescreen TV just went black. It wont turn back on. What causes this? The blue light that tells that it is on wont come on either.
Sounds like a fuse to me most computers solder or mount it close to where the power comes into the monitor or you can take it in to best buy for a fee they can do it for you.
http://www.youtube.com/watch?v=4W_m7FOEV7k
Terry
Apr 15, 2011 | Westinghouse 22" Widescreen LCD Flat Panel...
I got the westinghouse LCD monitor model L2140NM several years ago. Yesterday the monitor got hit on the screen and it does not work. How much would it cost to repair? the screen is cracked and needed to...
hi, i'm actually looking for a broken westinghouse l2410nm monitor to fix mine. if you're interested in selling yours shoot me an email at mymaries1806@gmail.com. parts are hard to find for this monitor especially the screen itself. thanks for you consideration.
Sep 04, 2010 | Westinghouse L2410NM 24 in. LCD TV
24" monitor fails to turn on.
problem with the connector form motherboard to monitor
just remove all connections from ur monitor then only connect power cord. switch on the monitor, if it on or off reply me to my id i'll sure to correct ur problem prajwal_yes@yahoo.com
Jun 17, 2010 | Westinghouse L2410NM 24 in. LCD TV
Moniter just stopped working. when you power it up
johnharold3, You didn't say, but I hope it's coverd by a warranty or some kind of service plan. If westinghouse can't or won't help you out, then get back here on fixya and someone will give you some help. You are not an electronic's technician or BSEE, If you were you would not have posted the symptom listed above, but would have already troubleshooted and possibly even repaired the unit. Johnharold3 you will also need to see some youtube video clips of LCD monitor disassembly,just so you can see what is inside a typical LCD. It may also be of interest to you to find out what are the top two or three reasons why so many LCD monitors (all brands) are failing prematurely. Well, anyway, it seems that the only options you have will be to trade in and get new, OR repair your current unit. Bye for now.I'm louie12fix on fixya or lmistyrel @aol.com
Sep 25, 2009 | Westinghouse 22" Widescreen LCD Flat Panel...
I need instructions to install L2410NM monitor came with no instructions
Here is the link to install your monitor:
http://www.westinghousedigital.com/pdf/105_User_Manual.pdf
Jul 03, 2009 | Westinghouse Computers & Internet
Westinghouse L2410NM replacement LCD panel
WDE may or may not have parts for our dead monitors. They gave me the following phone number: (562) 236-9800. I have no idea if they can look up part numbers for us if we can't locate them somehow ourselves. I don't see a service manual anywhere...
To the guy who wants to get the front bezel off: it just snaps off once you unscrew the 3 screws from the bottom on the back. I succeeded in getting all of the plastic case off, but then I was looking at potentially destroying the foil shields before getting it further apart.
Mar 10, 2009 | Westinghouse L2410NM 24 in. LCD TV
The screen comes on fine but then dims????
Hi there, I have the same monitor, but mine has a broken screen. It's probably the inverter chip, that makes your contrast bright.
Jan 03, 2009 | Westinghouse L2410NM 24 in. LCD TV
Westinghouse L2410NM monitor dead
What about the fuse? Sometimes there is a fuse on the circuit board.
Jul 03, 2008 | Sceptre X9G-NagaIV 19" LCD Monitor
Westinghouse 22" Widescreen LCD Flat Panel Monitor Logo
299 people viewed this question
Top Westinghouse Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
Alun Cox
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
